Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [OCL] String Operations
[OCL] String Operations [message #69301] Mon, 29 January 2007 19:42 Go to next message
Originally posted by: irbull.cs.uvic.ca
Does OCL support String regular expression operations. I need to select
items whose name matches a particular regex. (Actually I just need
startWith) but I could imagine the need for more powerful operations.
Ian
Re: [OCL] String Operations [message #69398 is a reply to message #69301] Tue, 30 January 2007 07:47 Go to previous messageGo to next message
Ian,
OCL has its own newsgroup now: eclipse.modeling.mdt.ocl.
> select items whose name matches a particular regex. (Actually I just
> need startWith) but I could imagine the need for more powerful
> operations.
> Cheers,
> Ian
Re: [OCL] String Operations [message #69458 is a reply to message #69398] Tue, 30 January 2007 09:45 Go to previous message
Hi, Ian, Ed,
OCL defines the following operations on Strings:
size() : Integer
concat(s : String) : String
substring(lower : Integer, upper : Integer) : String
toInteger() : Integer
toReal() : Real
You can implement startsWith and endsWith using the substring operation:
context String
def: startsWith(s : String) : Boolean =
s.size() <= self.size() and self.substring(1, s.size()) = s
def: endsWith(s : String) : Boolean =
let start : Integer = self.size() - s.size() + 1 in
start > 0 and self.substring(start, self.size()) = s
In the latest build of OCL, you can actually implement def expressions of
this nature on the String library class! Or, you can follow Chris Lenz's
example on the OCL Wiki of extending the OCL Environment to add custom
operations to suit your needs:
http://wiki.eclipse.org/index.php/CustomizingOclEnvironments
I will need to update this example for M5 when it comes.
Christian
Ed Merks wrote:
> Ian,
>> operations.
>> Cheers,
>> Ian
Re: [OCL] String Operations [message #601742 is a reply to message #69301] Tue, 30 January 2007 07:47 Go to previous message
Ian,
> operations.
> Cheers,
> Ian
Re: [OCL] String Operations [message #601770 is a reply to message #69398] Tue, 30 January 2007 09:45 Go to previous message
Hi, Ian, Ed,
size() : Integer
toReal() : Real
context String
Christian
Ed Merks wrote:
> Ian,
>> operations.
>> Cheers,
>> Ian
Previous Topic:Generating EMF model with virtual attributes
Next Topic:Teneo: More than one class with same name
Current Time: Tue Jul 15 01:45:58 EDT 2025
Powered by FUDForum. Page generated in 0.06890 seconds
