Home » Archived » Visual Editor (VE) » design view in VE
design view in VE [message #69231] Wed, 27 October 2004 18:07 Go to next message
Originally posted by: lalikrish.yahoo.com
I tried creatind a java file with swing components using the visual class.
In the design view i dragged some buttons and some other components and
the soucr code is automatically generated in the source view. Once i try
to run it as applet i am getting error "Applet not found". And one more
once i close the file and reopen that again am not able to view the
components in the design view .. please help me on this .. thanx in
advance for ur help.
Re: design view in VE [message #69250 is a reply to message #69231] Wed, 27 October 2004 18:27 Go to previous messageGo to next message
lalitha wrote:
> Hi
If you made no change in the code by yourself, then you can only run your
visual class as Bean (or as Application when a main-method was created and
you set the right VM-parameter which is
" -Djava.library.path=/eclipse/plugins/org.eclipse.swt.gtk_3.0 .1/os/linux/x86 "
in my case).
If you want to open a class with the visual editor, choose it in the
package-explorer and "open with" visual editor.
spunti
Re: design view in VE [message #69268 is a reply to message #69231] Wed, 27 October 2004 18:50 Go to previous message
Originally posted by: myersj.nospam.gmail.com
lalitha wrote:
> Hi
Could you please attach the source code that fails to be rendered
properly in the VE?
- Jeff
Re: design view in VE [message #602366 is a reply to message #69231] Wed, 27 October 2004 18:27 Go to previous message
lalitha wrote:
> Hi
in my case).
spunti
Re: design view in VE [message #602374 is a reply to message #69231] Wed, 27 October 2004 18:50 Go to previous message
lalitha wrote:
> Hi
properly in the VE?
- Jeff
Previous Topic:design view in VE
Next Topic:Prevent adding into a component in VE
Current Time: Sat Jul 12 21:29:21 EDT 2025
Powered by FUDForum. Page generated in 0.04139 seconds
