Home » Archived » Visual Editor (VE) » Ask VE to write specific code
Ask VE to write specific code [message #69191] Wed, 27 October 2004 05:49 Go to next message
Originally posted by: txfen.hands.com.my
Hi guys...
I actually have my own tabbed pane (something like JTabbedPane), which
allows developers to add panels into it, in fact, it works exactly like
JTabbedPane.
You know when we drop a panel into JTabbedPane in VE, it will actually
generate the code .addTab(...) instead of the normal .add(...). But of
course, when I add a panel to my tabbed pane, it won't generate such a
code.
Wondering how i can achieve this. Any idea, recommendation, documents,
sample to share?
Thanks a lot guys~!
klutzie
Re: Ask VE to write specific code [message #69326 is a reply to message #69191] Thu, 28 October 2004 12:45 Go to previous message
Originally posted by: mendelgili.netscape.net
klutzie wrote:
> Hi guys...
> JTabbedPane.
> code.
> sample to share?
> Thanks a lot guys~!
> klutzie
Adding a tab to a tabbed pane is a bit different in VE than adding a component, as the addTab includes such things as
tab-text, icon, etc.
See ...\org.eclipse.ve.jfc\overrides\javax\swing\JTabbedPane.ove rride for more details on how the "tabs" feature is
created, as well as the override to use the JTabbedPaneDecoder, and the JTabbedPaneGraphicalEditPart.
If your tabbed pane extends the Swing JTabbedPane, it will get the settings from the override above. If it is not, you
will have to create an override file, and use similar overrides and decoder/editparts customizations.
Re: Ask VE to write specific code [message #602388 is a reply to message #69191] Thu, 28 October 2004 12:45 Go to previous message
klutzie wrote:
> Hi guys...
> JTabbedPane.
> code.
> sample to share?
> Thanks a lot guys~!
> klutzie
Previous Topic:Prevent adding into a component in VE
Next Topic:separate window
Current Time: Tue Jul 22 14:38:24 EDT 2025
Powered by FUDForum. Page generated in 0.05455 seconds
