LTW and perthis/pertarget question... [message #69151] |
Mon, 08 January 2007 07:58 |
Hi -
I have a question regarding the use of perthis and/or pertarget with the LTW
and I was hoping someone might be able to help. I have an Aspect declared
with perthis(<pointcut>). When I weave the aspect during compile time and
run my program, the advice in this aspect is executed properly. When I
compile my aspects and classes using javac and then use the LTW to weave my
aspects at runtime, the advice in the aspect declared with perthis no longer
executes properly. The LTW emits info messages stating that the advice was
actually woven into the classes as expected, but the advice never executes.
If I remove the perthis declaration and weave at runtime with the LTW, the
advice will execute. Is this a bug?
There is one difference in the output from the LTW, the 'weaveinfo'
statements for the advice that does not execute have the words [with runtime
test] at the end of the line when using perthis, and do not have that
statement when perthis is excluded.
Any help or advice that anyone can offer would be greatly appreciated. The
weaveinfo output I am receiving for the two scenarios is appended to the end
of the message.
Paul
No per*(pointcut) declaration in LoginAspect
2007-01-05 07:40:21,031 INFO [STDOUT] [UnifiedClassLoader3@2c5b47]
weaveinfo Join point 'method-execution(boolean
com.kronos.wfc.platform.security.business.authentication.log in.KronosLoginModule.login())'
in Type
'com.kronos.wfc.platform.security.business.authentication.lo gin.KronosLoginModule'
(KronosLoginModule.java:262) advised by afterReturning advice from
'com.kronos.wfc.platform.aspects.tracing.session.LoginAspect '
(LoginAspect.java)
in Type
(KronosLoginModule.java:262) advised by afterThrowing advice from
(LoginAspect.java)
perthis(pointcut) declaration in LoginAspect
2007-01-05 07:59:19,937 INFO [STDOUT] [UnifiedClassLoader3@96c949]
in Type
(LoginAspect.java) [with runtime test]
2007-01-05 07:59:19,953 INFO [STDOUT] [UnifiedClassLoader3@96c949]
in Type
FUDForum. Page generated in 0.06514 seconds
