Home » Eclipse Projects » Equinox » Servlets with Equinox
Servlets with Equinox [message #69131] Wed, 28 June 2006 20:39 Go to next message
Originally posted by: ksshams.gmail.com
We are trying to move some of our RCP client's functionality to
servlets. However, we want to have the Eclipse plugins and API at our
disposal from the servlet.
I have checked out code for the following two projects:
org.eclipse.equinox.http and org.eclipse.equinox.servlet.api. I have
also completed the Quick Start Guide. However, I am unsure what to do
next. Is there any other documentation/tutorial/sample code that can
help me get started on this? I would sincerely appreciate any help or
guidance.
Khawaja
Re: Servlets with Equinox [message #69152 is a reply to message #69131] Wed, 28 June 2006 23:12 Go to previous messageGo to next message
Originally posted by: kgilmer.gmail.com
Hello Khawaja,
To get a better understanding of the OSGi http service, go to the
OSGi site and download the R4 service compendium.
URL -
http://osgi.org/osgi_technology/download_specs2.asp?section= 2
The file your are looking for is OSG_ R4.cmpn.pdf. This document
describes how to register a servlet, with some example code.
-Ken
news.eclipse.org wrote:
> Hello,
> guidance.
> Khawaja
Re: Servlets with Equinox [message #69258 is a reply to message #69152] Thu, 29 June 2006 17:33 Go to previous messageGo to next message
Thank you for the response. I have read through the Http Service
Specification part of the document. The sample code clears up some
details. However, I am still not sure how to get the http service up.
Here is my configuration file:
osgi.bundles= servlet.jar@start, http.jar@start
eclipse.ignoreApp=true
The servlet.jar and http.jar are obtained using the following steps:
1) download org.eclipse.equinox.http_1.0.0.v20060601a.jar and
org.eclipse.equinox.servlet.api_1.0.0.v20060601.jar
2) create a new plugin project (from a jar file) for each of them
3) Export each plugin as a jar file (http.jar and servlet.jar)
However, when I start osgi console, the http service does not start. If
I go on firefox and type in http://localhost, I get no response.
Here are my questions:
1) How do I start the HTTP service?
2) Is the registering of a servlet done through a plugin that also
contains the servlet?
3) Is there an application server, like tomcat, involved in this?
I would sincerely appreciate any guidance on the matter.
Khawaja
Ken Gilmer wrote:
> Hello Khawaja,
> To get a better understanding of the OSGi http service, go to the OSGi
> URL -
> -Ken
>> Hello,
>> guidance.
>> Khawaja
Re: Servlets with Equinox [message #69279 is a reply to message #69258] Thu, 29 June 2006 17:56 Go to previous messageGo to next message
Khawaja, a few things:
#1 If you are using Eclipse 3.2, you should be able to run the http
plugins inside of eclipse with the Equinox runtime profile. Have you
tried that?
#2 From the OSGi console, typing "ss" will give you a list of bundles
your OSGi runtime knows about. What do you see when you type "ss"?
#3 I think your problem may be in naming the jar files. I have a
working runtime with http bundle, and the directory looks like this:
rapsilla:~/Documents/temp/vbug ken$ ls
org.eclipse.equinox.common_3.2.0.200606251213.jar
org.eclipse.equinox.event_1.0.0.200606261442.jar
org.eclipse.equinox.http_1.0.0.200606261905.jar
org.eclipse.equinox.log_1.0.0.200606261442.jar
org.eclipse.equinox.servlet.api_1.0.0.200606261442.jar
org.eclipse.osgi.services_3.1.100.200606251246.jar
org.eclipse.osgi_3.2.100.200606251215.jar
configuration
-Ken
> Khawaja
> Ken Gilmer wrote:
>> Hello Khawaja,
>> URL -
>> -Ken
>>> Hello,
>>> our disposal from the servlet.
>>> do next. Is there any other documentation/tutorial/sample code that
>>> can help me get started on this? I would sincerely appreciate any
>>> help or guidance.
>>> Khawaja
Re: Servlets with Equinox [message #69299 is a reply to message #69279] Thu, 29 June 2006 19:57 Go to previous messageGo to next message
# 2) After I type in ss, I get the following output:
C:\jpl>java -jar org.eclipse.osgi_3.1.1.jar -console
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE system.bundle_3.1.1
1 ACTIVE initial@reference:file:servlet.jar/ [1]
2 ACTIVE initial@reference:file:http.jar/ [2]
osgi>
# 3) Do I need all the files that are in your bundle?
I changed the names to match yours:
osgi> ss
id State Bundle
1 ACTIVE
initial@reference :file:org.eclipse.equinox.servlet.api_1.0.0.200606261442.jar /
[1]
2 ACTIVE
initial@reference:file:org.eclipse.equinox.http_1.0.0.200606261905.jar/ [2]
osgi>
However, http://localhost still gives me no response.
Thank you so much for your guidance.
Khawaja
> tried that?
> configuration
> -Ken
>> If I go on firefox and type in http://localhost, I get no response.
>> Regards,
>> Khawaja
>> Ken Gilmer wrote:
>>> Hello Khawaja,
>>> URL -
>>> -Ken
>>>> Hello,
>>>> have also completed the Quick Start Guide. However, I am unsure
>>>> what to do next. Is there any other documentation/tutorial/sample
>>>> code that can help me get started on this? I would sincerely
>>>> appreciate any help or guidance.
>>>> Khawaja
Re: Servlets with Equinox [message #69318 is a reply to message #69279] Thu, 29 June 2006 19:58 Go to previous message
I will go ahead and try running with Eclipse in the meantime. However,
we would like to eventually run the http service without eclipse.
Khawaja
> tried that?
> configuration
> -Ken
>> Regards,
>> Khawaja
>> Ken Gilmer wrote:
>>> Hello Khawaja,
>>> URL -
>>> -Ken
>>>> Hello,
>>>> Khawaja
Previous Topic:http service questions
Next Topic:How to debug plugins in application server (bea weblogic)
Current Time: Sun Jul 13 10:33:23 EDT 2025
Powered by FUDForum. Page generated in 0.08256 seconds
