Home » Language IDEs » Java Development Tools (JDT) » Runtime Workbench Problem
Runtime Workbench Problem [message #69115] Fri, 27 June 2003 15:55 Go to next message
Hi All,
Im developing a plugin for WSAD v 5.0. Through the plugin im
authenticating myself to a server using RMI. The class file which does
this works fine when i add a main method to it and execute it. When i
launch a Run Time work bench and try to do the same using a UI (a simple
dialog box to accept username and password). It fails miserably..When the
method to authenticate is called through the UI it simply fails (its not
able tocreate the jndi initial context). As i told u earlier.. this works
fine when i dont do this from the runtime workbech... I have all the
required jar files in the runtime tag of the plugin.xml... Any idea why
this is failing. Im simply stumped. Any idea is appreciated.
Thanx
Ajay
Re: Runtime Workbench Problem [message #69136 is a reply to message #69115] Fri, 27 June 2003 16:01 Go to previous messageGo to next message
I've seen this question already in one of the forums - but I don't
remember which one it was. I think it was a classloader problem.
You code inside the plugin is being run using Eclipse's special
classloader. it may cause problems with the rmi classloader.
Genady
Ajay wrote:
> Hi All,
> Thanx
> Ajay
Re: Runtime Workbench Problem [message #69429 is a reply to message #69136] Sat, 28 June 2003 06:13 Go to previous message
HI Genady,
Thanx for your response. I really appreciate it. I did go through the
forums. I guess many people have the same kind of problem as me. I have
the RMI stubs pre compiled and available in jar files. Why should there be
problem in picking these jar files at the runtime. i mean this is really
weird. I also saw couple of posts mention something abt the security
manager. I guess this has got nothing to do with that.
I was tempted to use the plugin which you guys have developed but later
realised that this was more to do with the compilation and generation of
RMI Stubs and had nothing to do with making pre compiled stubs (in jars)
available at run time.. is it possible to achieve some thing like this.
thanx a lot for your time.
-AJay
> Genady
> Ajay wrote:
> > Hi All,
> > Thanx
> > Ajay
Previous Topic:javac option?
Next Topic:Passing environment variables to ANT
Current Time: Tue Jul 22 08:28:29 EDT 2025
Powered by FUDForum. Page generated in 0.02536 seconds
