Home » Archived » M2M (model-to-model transformation) » How to run ATL debug in Eclipse
How to run ATL debug in Eclipse [message #6131] Tue, 09 January 2007 04:10 Go to next message
Originally posted by: dorazio.nicola.yahoo.it
Hi all,
I write here to ask how to run ATL debug in eclipse 3.1.1
Best regard
Nicola D'Orazio
Re: [ATL] How to run ATL debug in Eclipse [message #6191 is a reply to message #6131] Tue, 09 January 2007 11:36 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Nicola,
You just have to run your ATL transformation launch configuration in the
"Debug" mode (instead of launching it in the normal "Run" mode).
If it does not switch automatically to the Debug perspective, you have
to do it manually. Then you can debug your ATL transformation.
Hugo
Nicola D'Orazio a écrit :
> Hi all,
> Best regard
> Nicola D'Orazio
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] How to run ATL debug in Eclipse [message #6205 is a reply to message #6191] Wed, 10 January 2007 04:51 Go to previous messageGo to next message
Hugo Bruneliere ha scritto:
> Hi Nicola,
> Best regards,
> Hugo
>> Hi all,
>> Best regard
>> Nicola D'Orazio
For what elements can I put the breakpoint? if I put it on a rule the
console say to me:
java.net.SocketException: Software caused connection abort: socket write
error
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(Unknown Source)
at java.net.SocketOutputStream.write(Unknown Source)
at java.io.BufferedOutputStream.flushBuffer(Unknown Source)
at java.io.BufferedOutputStream.flush(Unknown Source)
at java.io.DataOutputStream.flush(Unknown Source)
org.atl.engine.vm.adwp.ADWPDebugger.realSendCommand(ADWPDebu gger.java:34)
at org.atl.engine.vm.adwp.ADWPDebugger.sendCommand(ADWPDebugger .java:23)
org.atl.eclipse.adt.debug.core.AtlDebugTarget.breakpointAdde d(AtlDebugTarget.java:263)
etc......................................................... ...
Re: [ATL] How to run ATL debug in Eclipse [message #6250 is a reply to message #6205] Wed, 10 January 2007 09:37 Go to previous message
>> Hi Nicola,
>> the "Debug" mode (instead of launching it in the normal "Run" mode).
>> Best regards,
>> Hugo
>>> Hi all,
>>> Best regard
>>> Nicola D'Orazio
> console say to me:
> error
> at
> at
> at
> at
Hi Nicola,
Have you checked out the ATL debugging plugin as indicated in section
3.2.2 of the ATL Installation Guide?
See http://www.eclipse.org/gmt/atl/doc/ for getting the document.
Hugo
Previous Topic:[ATL] Loading metamodel by uri programmatically
Next Topic:[ATL] RSM UML2 how to get profile property values ?
Current Time: Sat Jul 26 09:16:30 EDT 2025
Powered by FUDForum. Page generated in 1.06749 seconds
