Home » Modeling » GMF (Graphical Modeling Framework) » What controls the layout within a compartment???
What controls the layout within a compartment??? [message #69016] Wed, 25 October 2006 07:04 Go to next message
Sorry, that I keep poluting this forum with my dumb questions but I am
desperately banging my head against a wall here:
In the mindmap tutorial the layout of the Threads within the
ThreadCompartment is user controllable, i.e. the Thread(Node)s are
placed where the use clicked when creating them and they also can be
moved around later, e.g. grouped or re-ordered, etc. The ThreadItems
within the ThreadItemCompartment on the other hand are layed out in a
vertical flow or list layout, i.e. strictly one below the other and the
user can NOT freely position ThreadItems.
But what is controlling this difference??? Both compartments refer to
StickyNoteFigure and the only difference I can see is the Collapsible
flag (the outer is collapsible, the inner is not).
But even changing that flag does not change the different layout
behaviors of these two compartments! And there is nothing in the
..gmfgraph nor the .gmfmap file nor in the respective properties of these
compartments that seems to suggest such different layouts being used.
In my application I want to have the first behavior, i.e. I want to be
able to position child elements freely within a compartment, but I
always get the second behavior and I can't figure out, why...
Michael :-(
Re: What controls the layout within a compartment??? [message #69059 is a reply to message #69016] Wed, 25 October 2006 07:14 Go to previous messageGo to next message
Take a look at the mindmap.gmfgen model (Gen Editor Generator -> Gen Diagram
-> Gen Compartment). You'll find a property ListLayout which is set to true
for the compartment that holds labels (ThreadItems), and false for the
compartment that holds nodes (Threads).
- Rich
On 10/25/06 7:04 AM, in article ehngbt$mj6$1@utils.eclipse.org, "Michael
> Michael :-(
Re: What controls the layout within a compartment??? [message #69162 is a reply to message #69059] Wed, 25 October 2006 08:11 Go to previous messageGo to next message
Ah - indeed - finally some light at the end of the tunnel! Thanks,
Richard!
But that "bypass" can only be part of the story: since gmfgen is a
generated file: what controls whether this flag gets set or not?
Because, in my attempt to understand this weirdness and to make sure,
that the reason for the different behavior was not some "handmade"
modification after creation of the .gmfgen file (exactly what I did now)
I had actually deleted the mindmap.gmfgen-file as well as the entire
....mindmap.diagram project and had regenerated them both and still,
there was that difference in behavior between the two compartments.
So, there must be some flag or hint or something in one of these files
that go INTO the .gmfmap => .gmfgen transformation process, that control
this. Any idea?
Michael
"Richard Gronback" <richard.gronback@borland.com> wrote in message
news:C164BF3C.C40D%richard.gronback@borland.com...
> Diagram
> to true
> - Rich
Re: What controls the layout within a compartment??? [message #69203 is a reply to message #69162] Wed, 25 October 2006 08:24 Go to previous messageGo to next message
Take a look at the DiagramGenModelTransformer class in the
org.eclipse.gmf.bridge plug-in for where setListLayout(false) is called (the
default value is true).
- Rich
On 10/25/06 8:11 AM, in article ehnk8n$8uh$1@utils.eclipse.org, "Michael
> Richard!
> this. Any idea?
> Michael
>> Diagram
>> to true
>> - Rich
Re: What controls the layout within a compartment??? [message #69234 is a reply to message #69203] Wed, 25 October 2006 09:04 Go to previous message
------=_NextPart_000_000D_01C6F846.DD608FD0
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=original
I fully believe you (even without peeking into that code)!
But as I wrote: I had deleted and regenerated that file from the mindmap
example (and I just tried that again - just to make sure) and it was
again generated with the List Layout flag set to false for the
"TopicThreadCompartmentEditPart" - see the attached screen-shot.
So that leaves me with the question: what causes that default value to
be overruled in this case???
Michael
news:C164CFB1.C41C%richard.gronback@borland.com...
> called (the
> - Rich
Content-Type: image/gif;
name="mindmap.gif"
Content-Disposition: attachment;
filename="mindmap.gif"
R0lGODlhrARAA/cAAAAAAAgQCBAQEBAYEBgQABgICBgMDBgQEAgIGBAxWggQ YwwUYxAYaxgYawwh
awo9fCUUCCEYITEhECo8M0JCQjVNTiIwdy9HkE8xEFI5MYFAGaRBEVxCWWFC lL05OaxFcy14MS51
WD+OS0ifX3drP3NxaWWcWG6ncypso0t9rGRzp2qSuX5znH50tXuciHqWtaJm GbZxFrB2K59ySqec
LMWSJqiKWqaycZiCrp6WsJGftaynp6LGoabBwMPFocHOugAA/1Jr1hCMzlKM zlqMzlKM1lqUzgCU
1kqlzkqtzlKpzkql3lqU1lqczlqtzmucznNr1nt71oSUznOcznOlznucznul zn+pzpeTz62l54St
zpytzq2tzr2fyM6cxsqkzm+93Yyt2o6y1ozG75e425i565rF3pjO96W1zqXO zqW326LO4aXG76XO
75zO96XO97G5zr29xr3Gxsa9xq2t1q291q293ru43bLLzrrYxsbGxsjWxrrO 4MjS2bnb98Ps+dh9
FOCZGN1vXOKYSeqyNui7YuKlc+fBcu6ZiOW2ieTBh+fAoefOjP/Wf+PNpPPS of/ee//ehP/ejPfe
lP/elP/nhP/njPvvkObhrv/imP/rnP/nsf/vpf/0qv/vtf/3tdacxtatztqx 1u+9ve/GxufOvdbO
xv/Oxs7WxtbWxtbWzt7Wzv/Wzs7W1tbW1t7W1s7kw9bnwdPpztrmzurlzPfe vf/nvf/nxv/vvf/z
wf/3xv/vzv/3zv//vf//xv//zuec3tbG3t7G3s7O3s7W3tbO3tbW3uvS59be 3tbn3tLe69be797e
1t7e4uLg4PHk3N7v3ufn3u/n3t7n5+fn5+fv597n7+Tp8/fv1vfv3v/v3u/n 5+/v5+/v7/fv5/vv
787v/9b3/97v997v/973/+fv9+fv/+f33uf37/P35u/v9+/39+f3/+/v/+/3 /+////f37/f39/f3
//f/1vf/9/f////31v/33v/35//39///1v//3v//5///7///9////ywAAAAA rARAAwAI/gBNCRxI
sKDBgwgTKlzIsKHDhxAjSpxIsaLFixgzatzIsaPHjyBDihxJsqTJkyhTqlzJ sqXLlzAnUjD1r6bN
mzhz6tzJs6fPn0CDCh1KtKjRo0iTKl3KtKnTp1CjSp1KtarVq1izat3KtavX r2DDih1L1MXMfzHT
ql3Ltq3bt3Djyp1Lt67du3jz6t1rscRZU6gEBgYsuDDhw4MTG1aMeLHjxpAZ S348OTLly5YzV96M
mbPmzqA/i/ZMOnTp0aZTo159urVq16xfy45NG7bt2bdr496tu3fu37yB+w5O fLhx4ciLJz+uvDnz
58sHs/hryoH169iza9/Ovbt37hau/j+wHj78+PIOzKdfX/78g/bw07+3ML++ Bfr37ePfr79//v/7
3cefgAAKOB+AFwiYoAULJugggxA+KGGEFDpoIYMXXmDhhhp26OGHIIYo4ogk lmjiiSiOiMKHK17Q
4osargijizTKWOONKdCY44o7dsDjBTkGCeSQQhZJ5JFGpoCCCks2yeSTTkYJ 5ZRSLpnClVc+iaUK
WXaZApdfegnmmGKWyeWZYaKZ5ppotsnmm27GCeecca7wpZ0q4KnnnXfmqQIR fq4QaAqCFkpooIUm
mqeiKzS6aKOQRirppJRWaumllU4BqaYrcOppp6BqKmqopIr6whSaVpHqFKei iqqq/lPAquqsscY6
6624VqHrrrz26uuvVugabBXBFktsFVccm+yyyCJ7hRXLXiFtFVokGwa00oZR RRhXXOttt+ByK264
WohrbhjlhqHuuuy26+678L5LhrrzhlHvvPjaq2+++PZrLxkAlyFGGQEXTPDB ZCCscMIHN8www2aU
UUbEE0tM8cUWZ8xGxRtvHHHHZYDMhhkdlxwyGyinrPLKLLfcchsow8yGzDTH bPPMN9eM884692wz
YH7RBNh3RBft3XjrIX2eA0s3nTR5T6sn9XvyJR0ffvKZV96AXPvH9dcBvnfg exeIneADZT+INoRk
r4122wzCXXbcDq6dNt0V3i1h/oYYVti3hhhymOLghBceY4cz2qj4jSh0oKOL Pl4Q+eQr+mh545hf
rnnmnG/uY44qIHlB6KAPSfrojYO+JJAdqB7666aPLrvqrbPuJOpUQlk76U/i DmTuUmZppZZhzlm8
mnImT+fyyrcpKJ9+Hgro83lCryeXgk7/5fR/ds/993l+n/34f45vfvfZLxr+ o5US0cKlUUQaf6Pz
rzD//JxKASqk+u/f//+NAqCm9FeFTp1qBQQc4AoKqKpWIXCBp4ogqxrIwCqc yoK50pWtfsXBXRnr
g8dq1rKkwKxgXYGEzJIWCleoLW5J4Vrd2ha1srUtK3zrhuEKl7q6da5y8TBd /kCMlxDVJQYiiuFe
+koiv/bFRIGVIQwEg2LCpPhEJwZsYFdcmBYTxsWDReyLFUsYxjBWMTCC7GMT 85gaQ0YykoWMjSOL
Y8fciDKSucxlNYOZHnmWsz7y8Y8+A6Qf22AKVZhFaNUxmiK3ozTrIG074XGk eCYpNaZZUmvsqRp9
2EO1TWLtk/bpZNcA5DWxkdJAAaLPggh0oP8siGz4adB9HgQhv03olnS7pYbs xiG0iShwgPMQMA1H
TMIlzkMtMpHjJFc5Gi0TmYcbkjQXJ6PIYW5I17ymkK4Zus796HTgxBzmTqck JvmISq2TEu6s9Lt1
vm51XGod8Z7UOuHFM0zy/kxT7860JH6qYJ7D6xKZ5MS8gjYvTYAiFELb5Cbq Aap73ZPeP+1kqED5
iXsUtSgRGMXR9SWqURuFVEjftwL3Ta8F7otUSO1HP0nVD1MtbammXoq/RuXP pqDSnwJ3ulMGPrCA
UojVAoVKqwta0Fa2uuALdrXUDvpqWE61Agk9SCwTknCq0bqqtLa6VRl2C1ov pCG3vnrDbeVwXDtM
K7rWxcMhwquIRIyrXNdVLyXS665PnJcTj/ivvl6xX3vlYhcFO1gtRkyMCvNi xsbIMY6RwYxopGMa
3xhHOpZMjimzY2bvuDOWyQxnMBMKBUQ7M9IS0hRBQwsqstOBHXzhCzho/kEL QrfI7DwSkpZcT24z
eUmo9baS41maJzXJtKt18rj/KeUplxu2AqlybM9l29nOVku7qfK6cnPbdK+r N+vWLZgR2mUwfanL
DoV3RMMsZjGTmUwVQXNFoZNmN2kUTRsJKXLxlWaOPGej+Z6Oc7LjXDd9JE7Y JelI5ETd5UpnJAMD
KQXnHF2Q9mmlen7OdRKWUu6u5M42Da+fBhWoiJUX4oOeKaFnklP60oe9E//z oSy+nvbwBL4VAwqj
3rso+URq0UK9r3wfLWmlUArTmNbvfjDVqf8CmNMm7/SnD5xCAlsF1FWdKqgR nNUFY7XUDW4wg07t
FQiNlSxkYRWryLLq/rSm1UIZaqur4IrhWFso52zVGa08zLNa18rnIA4Rru2C 67yKiES7LlGvhIbi
wPR1sH8d7IhWHKxgCVbYSisMjGVcbMYy3ViPsXGybZyjyOIIx5PBEWUnW5lm X9bZPeIMLQwxSz4a
YhaUwXohtWZDIaeDSOywoBjHuAMWZPtPx0XSOwkg2m2xc9tmZ7KRkRQue/zx D+Fa27jwwY8ot73c
91C7Hsw15YBWWZ9VpjI/1K0JumfJXQrZ8t16+5veMkRvYQYTRMNMr3r3faL2 Ni5FOdJQfvNL3xYF
POA2qtHlYifwx23TmgTGL+TgGzsIry5ItXNd6kyXuiBh+ErnZCeE/kHu8Qe/ 7ktW6meFy5mmgPrT
nigf04c9fNAS27xNKGYTivEUp4duD3vQ016OLzooQxUKfevbaKCUXlL1TU/I Id3oSoEMKZKWlMiW
emmRcRq/mTY5Uv37FACdHOWysypVUG6glA1YqwQeVcsU1FVTJxhmqjr1hMMa od7NvOYT7t3vdUbh
CWEY1juf9azm0nMP3RovuAI6ifK6q13zykR+CQyw/5qipCO9xc4ftmKKZSwY I/vGL3r6jKiHo2Xt
eLJVpxqzd/zszUD7atD4BdYAyL3udS8Qv5TW9hSYWe//slrrXCAUx2jGHbZA bBV0wHHZqUdN6qGd
ZUvSOslupG+f/jbJaf/j2ZYMbj7+gUmsUQ25xRVl1kLZ7ftIv/3QPeV85hbL B+CkuglSt7rnJsu2
bbe7F0AP/kBt9HABA0ht/uAgAsgg/fAPexM4fwOB9sYh+sZvxlQiMOJvy3RM OyJNGoJwkTNxlgM5
9BVf4BQjIYhNA3ZNEndxs1NxotNgmEM7M+g75gRP8FRyFsclQOIkI2dOV4KD /yRh9TRyuDNyI6dy
T/JyS8gmLhdiNxeF//RzOtdih6JQzyMo1RNRLZaFSFdjSOcoT+dRPbZjR3eG 7LMCKLUoTFd1IxVS
NBVTRiaHmNJ1OPVAZUd2SqZTZ3dAQdUpBORARYUqXdZlGIRU/rvyZXXHQWQm BXlnZiLEd5GoQmw2
Q1y1QuViQzUkLpo4Z2ZFZ3imVop3Ln0mRI8XaKiYL2HAV3ZVeYwGaa8YWHkl WPZCaQhjaYX1eYi1
i5tGRqLXi54mWXSERqSGamywBiWzaqvGWZ41ezRza4cxENJBAf4gELt3jbtG AaE1ELlHEN1oCtMh
fIZEHdeRA6IQDHcgbMX2TMd2HTVRW7sFNdl3feqhW0ijHtJ2Hw7wjsCFbekB H+LGbaNEH9Q2kAUS
fwdJIOqmbeambrAUNxD5fxEZIQ0oIfTggBbwD/WQfw54kRuCIeQFTPlmgSTZ b4gzIgQHIinZIQEH
TfR1IzSS/l8tGZM0GXDx1YFCsoIvyGAweII5OU49eIPvRDoXlzodF3JAaITA c3IxVyXIYyVbEnNM
uCZISGLIQ5UmJoVvQj19ok9fwlBd6YUr9nN7YnTVUygzRnTmMz1jCFLhA1KS 8idY54aYMpeUonWT
UlN2WD8KhIdiV3Z7yHZNxkBnR5iFWCtbpmVI1VRGhUFg1kFQFULE4ohUVWZS lUJ8t0LM8mZSUC41
FC3aogVuRlafeHiJh1anWYrski6Nty6nuIpzVVdIdGhQVHn4MjC4mVeURkUF kzBYZIu4eGmKxYuY
xlinB2qftkbDWIyVZYwpc2qqhkezJ0htAGuDYRiCcXvW/ngQADB820gY3/iN qOAXMDN8QlN8DuAF
oMAFdDBszud8kqOP2fGO+2gT1kGf+Gmfu3WP5HGR/0Bt9fl9FiB99Ult3zce 9+ef6uaf5SF9BfkA
BlqQWWMBF+mgFFoTF3mh5DegCyl9NkEfNwGiIQpLD7k27/cgCpqR5KduDrp/ FhChDCKA/4k3/0AP
NEp++ZeAF0ltEsJLEiiBE3hv+FaSREoiMJKSBuchPVI5/xZwEveBCndN09Rw FAdgB6ZNMMiTpZNg
pLNgPRhyu6NO5eROKBBzNlhOG6cl8qRO/LSmxOOmVQmVWkJzx1OnWXmnzJM8 CUVjW3hjLnaF0WNR
EiVj/mqJPhiFY47SdImKhmIYl40yl0Rml3kJU0cmP5PSl37JZGFHdmjHUxe0 QKD6h2rndllWK4eo
QXKHqov4VLtimZLod5FoQiIULV7VmV5lLW72iTMEindWmqg5iubCmnzGeKdY RI5HV8hqaOpCefkS
RYHVL4CVRb25MMHZRZ/ni5k2eo6VaadHjJNVjKWWjHXUMq3HjCvzWXskM9AY jYMxjrjnGN05jrZW
ELs3EPKqa6rAa7B2HaHAB/56B3xgB3agBgRLBluABdpBn+74ffk5n993He2I NA1bnxTLjwSqbhVL
fvUZHjUhXO/3fg8wfuc3fu5Hfu/HoSKKsva3oe/X/qEryrIbCl3pNn3+gLKz lKH6h6M4i6MpG4A8
67M1kYAqqoAdWRMfaV7j5SEh+SEiibRFajjt5ZIzIiIv8kweKLVQyl4haE0T 13D/1YIMt4ISVzrc
hGBmGyTjlKYuSINDuU67IztLCac8OCU/mHIyhyZFqCYx9yZ7S1B4+rdVSIV/ ylA5F6jUo4V+mj7g
U6grFoZk2Kjlw4ZsCJcgRVJpOHWUYlJZBylIlimbwmRgd4dK9nWBeXY65YdD dWWdMqqr2ypBxUCG
GHeK6JiLGJlQRWaVmZl+h1WwylW32plcFbwtZEOdaJqIp3ht1VbDurytCZuu KXmSV2hLxKz8gmjO
/opFepW9wLm9wamLDpMxENOLpddpHBNZyikyqydHpiZHy8iMstdZfGSdBXGd qDVa2ymN9+t71Ymd
4jl8wle/58mvXtB8zwc499EA2kGgAZqfCosTkmSgD8s045ceBMqhG/t+F3yg JFvBHAyz04eyGzsf
ICuyJLuyJWuzIMui95fC5DcfI3ofC/ke+yfDL6uiKWsTG6miIfogN1GAHhmj L/uz3nW0QCo4TPu0
Fji1IFK1UXuSyXRwDQelHTJfXRs6EJdwNlnFULqksZNNBMalCEZxRAmmGJY7 HEdhWsKmSTglEtaU
dOumK2dPTtKETAhigHvHUphzWZgmexw96QOo/lfohWdJdGCodOITuYl6qD2G KCEll4v6ho8aKUSG
l5t7hzHFKXYIKplcunoIKgWkQEA1mEO1QIZJd6Yau6isqqtqd7arK3jnymj2 LHqXLFpwVTA0eCoE
ii9ELd5CvGUVinqGvGzlLsLqVo8naM9bL4nGRK5IeU60L9mrvdjLeZNWrcIJ RoiFrcUZMog1Mot1
vqonausLe68He+2rMnlkM3oEjYxBGNPxrvRrCvEajvsrjfUqEPmqjfh6SPtq HV3AB3cgsHbABgJN
sFsgBQnLsA/LwAvd0NzxSA0bsgpNsRK9sRlLHyU8wRirwgSpsRgNsxkJbipb kNJHwyfskPmx/pAL
2VwQcqIwXG03W8NGO7Q6XLMuejfWlbNxY7QKKqQgKaQ+7bQViMRI3MQuiXCS E8Un2bUB5rX1JTsi
+G/V9CPyFWCR02A9ebbrNDtpK5TwZDsUVk82KIQedztgsoM/+JV2u4RlOqdw 8oRuopV4PNcpBj1f
iWJ4/WJ+/IXoQ5aDfHSHnMjqA5dOR7ltuFKU+z6IjdiTOodyWKkuxXWR0peU bXZORkBDtSoVZLqk
TGVcNkGLeStNtcp2Z3dlZmay2rsidFWi2XcjVC2bCFai6S3IAoq+aryimNuq qS7F7C6vWazRS0Sz
uazNzFead3lShC/U7Ju32HnW6nnZymna/vox1J2cpSfO2N2corZZ5gq/KZPO 33md4j1877oY3Vm/
4S3P5y2e+mueqnUdOOAFOOB8y3TADcAA23GxDn2fERzRUMOfFyrBDv2OFkt+ F0nBJiugHayyJAzS
HwvTD97RJ3yyLGyz+OGQKI0gF97CQAyROr1/GbogPI2R3kU3PPrDM83TQmsh vhSBTotev0TUg2PU
UYvUL+khXHs4+xW1yURwAPYj9tW1Zbs6Uw1gCXZgYFzGZZqlSPlgZCrWbBxP KwfHpOPGPuimTWjl
99Ryd4uVdcq3c21Qg7unXPhzeW2Fe4J0CsW4fK2oj+u4TFfYjAopeWK5j4rY dimpW2ep/k3Gl5/b
Pzi1qYGpP6eLdqF86BJUmKn7dqeMK1/GZaQtLL9SZiOU2lrlLM6imW+Gq2v2 LXUmZzbUq6GYmsqr
vLzNeHJ1zHFVV9CritObaIjWrMw9zdhbrdaczZuGWKC3zcdpRqCWetltWeUM ndwde86YM7d2jedd
SGZR3vgbr7mW7Muu3swefPiqrwJxHRfgBV0An6t03wuAHQq6sPpJseSusIxk 7hut0CBc4Pa57hwL
0wqa4B760R/9oRTewiTN4ffHoR+q0jH7SgHS7xpZkB9e8Dr7oWgTDzCqgAiI kRg60z6bfwUoXvW2
IS2+Ny8+1DIeIjSeIvElpSf5TEm6/uP0JSQlOMVQbdVlm8U6Sbb8dTk+qdUO 9iVf6oK9s4NHqXFL
SYRafjtRKWFT4rdwPZUDJdd5fKcohiZe+HN9OlGH0teFiqhwjpZv6VFtuVIn FXVvGSnsQ1IrBdmP
zbl0eKkyFeidzKmdXMprpyoIVJhS9iqgjcqQzlSPyYhUZVV5R5mYmUKxnOm5 jC1hJXi7XC10ZnjA
TOqn/kOnvi69/Vbs8prCPfnD3ax8FVhUZNxWpGjAydwAU2m52HkEs82kv+uN 5evevJzLSVl2tJzR
6b7n+t3qbJ3KXhjaqd7Kft76K7+Q4b+nlVpDcx0q0AU5wALfvgDhDo9FA23x WI+9/pVbwPVs5ddJ
nNSgHJ41//geJxuQ4XbC8cf91IV/zUVuDUI2IR5L7IZL/AdvtqT+LP7iJMLx HT/jSxxNTO3xK59w
Ph7FT8xMWQsQFwSmuECw4AUUF1QITLgwIYoOKCAmJFjxoEWLExcSXLjx4kEV KDZCTCGyYMgOHFGk
iIhypUiTITvClEmTZkoVLFPknMlT5M6aQXf+lDmUJ0+jSHPuZKq06VOnUaFC 5UmE5wqnWFNgPbpV
hVWvVlWs2InVqlazY72SZft1bNuzWFfIdTv3rVm6c1cQsat3bgu+e/0KHjw3 8NwohRXPnbIi8YrG
iP1KYTyXMuQVlBtf3gz5ReMq/plXhCY9GjLpKVM+Uyb9ucqUKq5jw35dxfaL 2rZ17+bdm7eVKsCr
XNFNfLgU4MSvJJeipYoWKVeIh7Fi5YoU6tKph6myvXv3K9zDhAcvPvz5MOPV h1efnr2W9Onhx6df
n76Y+vjxk6HPP71//gAMo4wwxAgwDP4IPLAMMsowkIwEIWwQQQYbtJBBDC/U EEMzyujQQxBB/HDE
MkLssEM2REyRDRRR9HDFMlJcI0YW2ahxRRtzxFFHHnu0sY0cgfyRDSH/MeVI JJFE5UhVWKDAnySj
RLJJCoA0Usolj1zSSSBNUcUFCky50gEyybwAhy5y6MCCBhoo800445TzATnL /rQAzjvptNMBPfl0
4M48//QzUED/pDNPCx5IFFBFHfjnH0YjrcefRxe1VNFLF32A0kox9dQCUDMF VVFFL7D0glIXRRXU
VU19oFNTW33AVAtkjbXWWmfN9VaBZuW1VoGAFTZYYnmN9ViBkE12WWabdfZZ aKNtNiFmqU32IYaa
NeiCiJLddiGEOjgoW4UE6gihciH6aKJuz7XIoXY/8sgjjS5qSSGSymVpJX0L asmkFFTSKaWUdKIJ
35xwiilgmAIu2KeiWgLqKZymgjhgp6ayeGOpOoYKLKnSmhguFa46iiy3wEpL rrLqcnlluviqS6+v
5JLZsLxwvquvFgzr+a/B/n5W7LHHHJNssMQiE62xyDgTDTOml15aM8hYU20K 1lYb7erZanMNNtlU
040238rWTTjgktvtuuOUi67ttqNTbrrhrtOCbrezI+9u9J5b72/02BPcvfjY C2M++ezL7z7FC0Qw
PgEfFzBBMRQM0EEHLx9QQgIxhxBDAzPccMMOLywdxAZPFHH1FFWHscUYX4zR jNZXpH32HW+/kXYb
eWdjjR6FDHJIIotv4x8WSnChBBaWdyF550ug4J/lm2e++ujBtJH667u33noK iDxSejFNQaVO9NNH
v08/27+TTD37DHRQQQkV9ND7DR200UL5J9XQUWkqgKQKoKgKaClRfUpU/q4K FaYCyEAIJopWE8QV
rlpVwVjp6leo2qCvOAgsXw0rWR6MFrCWZUJppVCF0bIWupi1LXIlC1wGsda2 rDWRbFFrXuR6SLfS
xa2GoIsgOPyhQ+CFQ47Yi18Y6VdNUgISm8gEYQoRWEGWuLCC/asoUkwYw4RS sp8YJYoYI0oYpaKx
jHlMjRzjmFsmdhWvPKUtYckJWsZSxzuexWV6PMtWYDYzQO7lLnckjFx8FpfA EOFnikwkYPxStMUs
pjGQvIxeEuM0qYmGap1h2mc6CZqqmQY2W/taKbuWG9rgxjZgM1sreWMctcGS Ocqp23CeU7fmNAdv
4rEOecwThub8sjyB/mvP4NrTHsQdrnHxwU/j9OO4Zv5HmpKTpoIeZ6ABYfNy lcNmhTYHutGNLkOo
4xCGyEki1qVTdbCr0exiZyPcxbN38PTRjuqpI+EBSZ/FYwMF/PlPgAZUoAMF qI0ISlAbeclJ5TOF
+hyqPvatb0/we9P75oc/OuEPUfXTX6T8B6hFAfBPBRxpAgfYwAMq0IACHJWr LpgqCbKKVaWiqUst
GNMPZlCnvArhsSzo02SZcFg/VdYKjXrUaaWwhS4s17N86MJ4MURcTWUqu4g4 xHAF0arxete4mOiR
JCZxJhFRib5sEhG0agRgHFGJTHBCxYJURIw9matOgiKSoHQMr0Zh/gpUiNLX NQaWjUoBWVMKizKQ
VcUtRxFLy7yyRzzqcWUvA2RcapZHQ6aMZngxZNAiObRHHs1oo4WkXpQ2ScxU 5mmdwQxlNvmZpcFW
CpwkTWhm60nXZAY2u43Na3BDttvkxpW2EU5wbGMcWx4XOXBzW3Ov89zl4M1u duMO36obHiuMh5jD
/FsxCfddZcYnmc5k5jIPNM3JUZNymsNc6CrXoNBJCEEWCuc4xZm6cuLXRPtd J4hq518A665FOKIR
72i0u3v6SHj8xKfxGJxgHi04eBNu8JDaML4wGel8D31oAhxKJw+3j0zvc1/7 9FSo/PUvfxllFEdD
qikAfjTGJqWx/kptPNMKxjRUO04VTGWFQQdOUIO7suCQN2gsoorQgyh0FpOL hVQoQ7mFS11qDtF1
w6nS8FriwtZB0nrlrJorXd3CKkUOgsMj7rCrTHxXvULiL6veFSViBVhPxpjF m5CxIzopiUwg9lc5
/zUpTHkYGgd7aMF2LCpZgQpiI4vHOKKMLnTkYx4hGzND8rGzZnGkXQIzyMN8 dgWdFrUkRxuZ0rb2
1KtlNdVcHcqrjfK2o3yN1Wb929+usrfCHW4ri3sctdmyOsxt29zo5hzpYEc7 1vlOdXlpHmUDrrvo
8S54w7vMxTHumdF8XLcjt6ACJUhy6w3QhCYkOnTT177rPl27/vlbInS2Dt7+ ZWe9YdROfM/zwLmD
8IT36eB9BhzgAxc4PwV+cAezwUtgYuiSUOFw80Uc4g83HypSYXGMewnjqbh4 KszH8SypQhVH4vjF
P+5xj2eJ46YA+cmzJHGSq5zlWop5xWl+8yRZnOYvxznPs/TzmS+p4yz3uCos ngpVoNzhSE/5xY3O
9JUf/eNCD7rJS95xnV886yzPOMix/nWsb/zhYj+61rVeca0/3Otq/0HJLd72 VMAd7hsHe9mvfve7
x4Ljetd73jleir0DHvB/T8XgaVFywRde8Xgn+uDv7niidzzxgyf6zJtO8sTP vPIo17zHSY4kz2te
9J4HetVT/i4lJVke9KhPkh4i/voj7cEUro+S7KPketofCfesn33vab/7Jelh 97ufg++N/3sk5T73
SRo5k7z0fJE/H/oiH3n1qQ99JlVf+s13Pval/33uvx7o4W++9nnueu1LP/c8 5/7I0Z983cOf9/On
P+rDn/r651//++e/lDwf+tBbvfy7v/uLkgKckgHsPwXUv/GLOPOTPojTvpFD hQdsviWZwNTDQPHb
uZsDuomLuNPDv/4LwADkP59bvdJLQQ78QIhDPZ5bwPp7wfx7OfK5EgaMQROM EhmEvfk7QRj0wZfb
QR/kQSLcvx3EvyPEEhhcwpxjwiZMkhDsPxXcQKojQSgU/j0sPD3O47ygwz8A vEIsJMIgFMEndMEb
xDk0dEIFTEIpVEM3NEIEtMDu+z7WO0Des0Pee8H7u0ARlEEglBI8RED6C0Qz TMDtI0MDnMM67DlE
PEIh7MMe7EBJLMIx5MFKFMQ0fENNLMNKnMLSg0MdRMMXvMRLhL0hzMQ8REJR pLnwK0VTnEQxLMQy
PMNRlMQWVEEP3MDUu0UqbMKF0jAO1MVOhEVhTMNPPMZJPEVPTEYyJEVjlMVi jMZhLEJpDMVqhLlr
XEZmzEZo5EZqPMNZPMUcDEdItEYlJEZ0nEZnfEVvDEZt/MRtjEZEnEc1ZEMc NEdBLEVChMUk1EZG
xEd2/oTHcpRHVeS/8ltFB/zHVPxGf1REVxRIeFxHZJxFdpzHIWxBS9zGd9RI jrzGinxGa2xIXTTH
fhzIjMxEkXTEhfxHgaTEkHxJTiTGUrRHciTJbuTEGmxGm6TIjyRIlARIZQTK czxJl4TJnqxF1vND
hVxKpNRJimzKRqQ/pBTHlezIKRzJoGxHp0TFiETFJ1TKmNxJngTJWHxKo1zK ryxIq1xLtuzKgBxI
dUTItyxLsZxIehxJr0zLc/THmTzHPZRJtaTLadTLwITLuhRKrGTKwzRLxozK xvxJtJxKxCRKt5TH
R+RJu4xMhMzMb0zMnkRHypzMPyRIcRxMwPySDBNM/rHkR3ocTM7MSsdUy75k zaI8Spg0Tc2US8ik
S5B8yHQMy3YsTYCszdmMTbuUTIWMy3L0Tdr0TKi0zcdkTryUTt6sTupUTbT8 TOm8yNXES8x0TNj0
SNkUTQQ0zdecTLIES7BkSeBsytl0z6GEynWMTbKsT+tMTqdcz/T8TuMkTP2c T8XMTuZsyfU8zgA9
yfl8ztDUTuA0hZzsTwAwyQSluQht0ANF0PyMz620SPyk0A2FTACtyIkE0Mwk UaPkTlOoUA7VzbJ0
TQkFSBU1TBmFTkuMURo1SWOM0O30z8Z8Tvikz/u0UB990aqkURQl0o80UCQ1 0t1U0O78TAzdTPpE
/tHi3Mod7dDlxNEjHc0o7VIu3dIZLVEsnc7+7NDivFIzXVII5NEnPdMwBc8P ncvQ/MWMBAA7tdMU
zVMRLcM7xdMkiVBADcuX81NUUNGZtFEfrFAwTb0+lct11FE4TdE7NUxF5URE PcdGJc72lFQ/HdNB
dU5IbFRCxdM+VdFMxdJSvblAvdQDzRJTRZJALcdKFVJGrFRDhVVaxVIXrU8l 9czm9NUvXUzSHNMk
LVNdlcUjXdAVNVGfBE1f3VNiLdbVFNPchNbqtFZHfdNj3VZlnVBh9VZl5VYk RVMGbdVNbc5etVZw
xVbOlNYH5UEbPRJWTVJWLdTnm1WU7FRIJdJS/pxXaI1RNP1UJH3Vc11FfIVF gkXXmARYcbVXAWXU
KNHXWFUSfxVRhtWSCB25g2VXXDUfRc1YuQQA7kvXSozRfY24W63WdfXUgi1Q bVVXLcXROGXSmM1W
9hzXmmxRDa1W7wRNN91WZgXXn8VObAXWKX1ZoUXals1Sbl3XgB1PmyVaOXXa gpVZZoVZcwXagUTN
8ilZVU1Rje3UR8U5UeXUDI3VCp1UPc3TtFVbt/VTtZ1PfI1bt9XTST1VesVY tpVXuG1bUyVVsbVU
vV1bQFXbmpzbvi1cvoVbLzFc1kzZVd3b10tZs+XUW0VcUq3cuqVcn0vYVTXc TK1bu41NkR3c/s11
XJqF1qRdWqxt3dWVUeEMV2mV2hAN1yr92dddVqad3ZV1XaWd0aZlXd58XeJ9 Wd/91t9V2RXlXWPV
1KxN05vl2OCN2tp1xneFvVSNXHkVy9DF1YlFUUDV2IjVU3udWBuNVYdd2z0V XfVl24w12Y4d2+1l
3O2VXPtdW98k2I8lXDlERNSV3LQlXPvFV68Nwsgt3Ls1xVdNWMut3731XEmd 0QOeX++tYAoe3aMs
VfMd4KgV1+kF3g8uXuWtyf9sXnKVSCtt0GR1WejtWVeUXqwV4eMl1tzN3W5N Xhle1KnFYZw9V6od
YYV93nJ1Xub94ONdRzodxfN137glycvV/ttAhc0A9tspvmCHLdvFJVQLReDE 3WCUHdyB7F7x9dj5
xeIlOdmPbNQxllyHrVKwbeAAZuPPvdNWFEG/zVNVqOI/XVzLRV9bzbn9jeI8 PWM8VtcJlmPy9eMH
bt9LhN/sTWR8fNogLloUDmEe3s8ULuIe3mROvt0M9eCirGQYrt5Lbl1KNl4b 1uEcTl5TtuSGbd5X
BmIZLmJR/uEZVuWdNQWGs0Ggm1XtjV5C3mMKvlhRnOI8hlXx1WOwXeAv3lCv BVhmJuOOfWPKfGIH
VmYHVl/ujGNq9mLY3eA4Buf2dVRHrl/0zeaJvWbu8+UKhuB4dcYJLl8L5uAD 7t+e++Ml/jZVe5Zd
UjbiIV5lVwZhFgbi1N3hDvbkgB7RXEZl2C3lGq5ZU05l4QXoiG7ohAbeK31o WWZlN/5njC7lGCbD
nPRaikVkyNzXNv7l2fxbSN7eZP7iQI5fyiVKRY7pYL5pAm7Ck91faa7pySXS V03pQSbf1fTpKx5q
7bXXrIxpD2VYppbnYJZmXCVkbz5na+XpvaVqmG5mrO7LciZjQc7pTLboW95J ij5rYZ3kgj7hXF5h
ZwZpEN1dW35htI7l1L3alcXli7Zrunboj7bPGT7lvQ7QWmbogC7aV6RTO8Ze uw1chA3dBI5gk4TU
Lm7mxq5syTZcrwZdic1cWM3cqFZI/mj+UzwdY85u2wbdVyoW4Pw9bbQFa9FF XXEs209F4wbW3Pjt
4yxubD7WZrh0546FbJAlWLn9adzG2wsl18FuUr8+7FHmZE0m7L+23YmWa+ZG Xuod7FkOUY1uZb0u
ayMubO2G7l7Fa2PdbuM9bIpWXfzb5eGNZP4cS+W+S7x855yFUv0cTsIM6fGN 7x+lb0weyvrj3MCk
SgH/TRbVb/bmb2q8zIW+2sUu8LfG5LqGWvC+cEnm62k9b8OmbrgOZevWcOzG 8E3+b/Om4eoebyFW
8YrObhEnWvTWWvUG6b7GMIbaQA3WzT/M8SAuWR73yUnVwKMNcVctVSG/ys0+ Va8V/nKjZUcNnlWM
VE0ez8Ve1u+V1mB7TlcSllIo1dUnn1SMdEv5XFgsD0Wx9nCeZXESZ/EMb3Ha 5fAXn13wxk2PFvEK
j/G7LnGIXnM+p9LmDuyh7e4MF3SrpXFDh0Uq6dq7DM8XTu/OfNiFpE6qpEny zM77hm9IT8oybfQ6
59Iub9PdJcoEV07ElkpMp9a8/NUT7+Amv/A+//M2n+sND3BCX1IbBnFg5ui2 hvXpHvSx5u4Uf/UL
ZfMO/+5VN3Fdb+H1XnYlvF7cZPSCXF1Sz/VWH3OoTUnsrkzL9OFov28WtvZd t9mrNOj3vvTzlPFx
F/XpHlYBX3U0v/Ngh3cUf96h/l1xZj/oFKfzGnf18uZ1lt1oet9zeed3Yg/v Xy92OAf0Ql/ue88S
9x5SOY/dVpba2vRnHQ7wap91Ih7i5GZTC0fyda/4gc5KUYZoYFfh/X5uxoTN enfrgn/5Cv93lSfv
Q0fziVfPEBd2ncdzX3fxGx14oPf3medzwSZ68Tb6P1fsZ4VwifdW5T53765a GE9v3O1htkZ4Wg95
aq11XM9z+3T3oSfQnG15lH/5nRd6mQf7ekd6fNdWfV/eoIf5Xk/4QBd4oY/7 sxfie/d6hb9utsfw
kZ57Hf/4hX9zgP95fv3zYYdhkx97PY/3wtT5BZf6H5b1qnX6CY9ul897uV/u /plfe9Cv+c1HbJyn
ds5fR2Z4FNVffdZvfdd/fdiPfdmffdqvfdu/fdzPfd3ffd7vfd//feAPfuF/ /SNxb6wX9ZHP+f8u
+ryGfOd+z78+eeQX/KmP1n43+Lied8mP9cJn+bF+d7TH+/X+/O+P7r8fffEe 6LsP01dQfWbYRPiP
f/mff/qvf/u/f/zP/yXcktREdp8HCFOoTBEUSHDgwYIIDSYs2JAhxIcLIS6c SFEhxocaK2a8KLEj
x48OQ3osSfKkw5IRUW4EmZKlSY0iY84k6dEizYg5YcJUmZNmz4lBO64kytNl TaNIdy49mlTm0Kcz
p9pkKlWlTaFEZTJk6dQq/lhUr/4xG9kQIdqzaruuTcv2rdu4befCpSu3Lt67 eu3yzdt3r9/AgAf/
LSzYMOHDigGbKkHB1L+MX7VSbWoZbOWpYV+alTr5MujPV7F2/tlzM2fUqnW+ xaz6q8+orGWbVrr0
dejSonF73ir7d+qiUHNnFm78puSUPnmrZvaP7G2dFqcHH17auu/q0rVTv77d e/fs4LmTH29ePHrs
6r+nZ78+/Pvy7cOrcvE48u6st/Mrh01a824t9TbgT8wF+B+BBYqGE38JuqUb aAQGWBVwmFGG4IUY
Emfhhg0ydxVsFNrGnocajrhVayF5KJpz0AnoHozwxShffOcdxEIJLpTA/oKO PO7YI5A/CukjkUEW
OaSR/tA4o41MzrekjFFCOWWTUlZJJUaOQQahhFwat+CGxYmY4JcdmunlitHp F+Zp/qV4Jm8lGrgf
emuieWKFL16Ypphw8qkgnSDW6WWXfQa6VmvRzfmUc68QuiaktkUq4KTCReoC QaooR1AqKXXq0KcF
hcqpp6VyGpmlkqpK6aqpsvqqq7FSVumsrdYK662ydoYQC/cx9Bymft4JJ7El PcfCqA8euKewZP7p
n50cAnhZPf8g2+yHhZKIrVDHdhqitmXqeV1IwG76LJfeBoeus4fmaSi3j45Y 1ZuIssuQc2VtG6+2
9zpVgqaRCbzlwAUT/nywwQkjvLC//C76cMP9OrybfVseFBnA/RGbp1fFVoSx phBXFzGgEh+Uxwki
jDCCC3mEvO+48IZHEsgzJXLuxCbDzGfNuWHRQQdYaCxohNEu1LOyDkOENGdx zCHHxHPEoYfTcjwt
NdV6DOvgoGpia+JTDKIYcaPTxpyTDTbQkDYNL+scsSosLKww3XPbXbfFb+es N98i901yT1riR1Bk
wdZ7UQ3MXjZ11VczfjXU65rS+NSEGlT40AYRMgghCL0MrW4VZL6iKymDEIII JyBjIA8i0HAD7CeM
wIPbSb/IEMoqs7zH2TMrhHlwiWxwszIorFBQ4lv/ccEKISc/NlLP/pcskPTa /oOK4Uz9HEULQc8b
Bw4q4BCHu0QRMkPaipAb2bUgGZLI+1pL7iDwyc0RDzzxzCFyHP7E8T898kEP efgjHv8gn7gSaCff
eU1nYFuO7Q7Hp3wlUEzVowgNnpMPfxjCBp9SnN8wk7GB1cMUGThYCeWAghSg sIUkdOGWSjgwBoYQ
cHur4Q1tmJBe5W1LGctNDejxvDzJIR7xcIU/CPiPfNTDH64w4v7qJQcBMvEH Upsf4RoTsu4QAhuE
0EPtwlQU0Q2kAmHsV8poYIIb8OAEKTuB2Dyzh9TBIh03OMEdR8CMBxWtIC4Y wetiN7vPbe0jTHOI
8GKwgVQU73im/qBBP4Z4m0YSBJKStBdBTljJSNJwD7ILwQhO0IogXlJCh/SI IWQQA0RgoQUtgEL3
5GeUOLAAC1zAAgsQWL6DbA4XntCDDbaYkev9kCI2+Ec9kunBeRHnlAgpYjzo EUW+TVEHOcgBPZzR
DG0244Ajo5MuJydLEDYkBjWwXIMqt0uRxHE2/Cobubp2kBrAo5SZskE+5BEP eRyiEDYAmw4vgqmB
kWAGBT0owVSoAnosTIZ2c6jCUIEqCeawon+zKA4v2pCKDW5L2atICkIa0hVc gQ9+qAEN8EGDc4Lr
IPeLRxwCaMR65AOmRtRaO2Mqj3yuwhRW3Fb92jKIXAxigRFi/sgOKrADTVWA j/mR3QlogA4a4DGP
J0jUUU5gAhPkwR/wuMFWTXACt1FUI7AIZR3veEcT8A6gqQkqRIRXiuE5w3iP pOdKmeIHu64UHnmt
ig06aANBkCARpejrX2figtS5kQc/WGk6Ets7jLBvVKiEwSAEAQND3MGVULBA KeqFA1eSFg4jUFkP
QrXAQRTCEynYxCSCGZz6VSQRnvDEJjDxCEbAr7eGaCuc4AqROMCjuDuAHNa2 RpL+RZMeBowHTWka
OfigxGk5+AH5ihhFoxYkBv2IwbfQuSHtVjBamDwvcyjoHpJc4AIocO8FqsAH xLK0IzaIRx3Q4A5G
KMKf6wwo/q+y+A8S2CIRM6iFgeWxJRWysG6RgWhDYehOjWa0wgDG6L0E9ztT yO0jYPgwGMbQBj+I
Qwa62AUvdrELGuCsMsS1qRFjDFN4rGOaKXqpjOMxTpH0jDWmqAEuaqAKRBBZ uUipAJInEAIU7GAC
S/2mZ5CRuhvkgR71oKpaRdAKmRFEBCYQwQ/+4Y9+gFV2zEyKVk3wA3qQOaxj lZdmeryQRABieDEA
xDFQYAwTqxjFMmgnKgwhjeIpg88pXjHOVGGDRSzCEYmwwTb4rGJe/Dk4iz3B D/IAC2iY+NCIzhxN
aPuSGtTgETAQxCAyC4M73EEUdxCaS0jdPaCpgAsg4AEb/kVAOywKhBCF2EQK JvGISczAXj1OSCJO
zIsT64IXy8aGLuYhWwWCRM4jmUM34NGNHfTjuUncrpFdGs0d1HSb8tCm/lR0 ZjnkoAc5iEYcaopT
d3n3u8kSr2fuJ80zZwbQoztTi/Q1JokIYQwGP4Mf/tDpSVfaLDZYxzrcsQ51 lGMdh9DDvQkCgI0D
AIskA9jAZrAIQ2Rg5CRIKAoWCkODQRjCA9uSuil8YZljuOY6i5uvEHJshoh0 pCUtNAw0oUrgRpAk
cugGTLsBcXXAQx3rIK465FeVIvaBanHYgTwQ2E5Rn0UVNfBEURExCkQ0ayCo 2AEKzuGDJYdAFROY
AHUt/iO7rVa5HvRQY5rhCGeIhAAEIFjzc2Dh5RFwuSFeBvM/2Fxmwp8t1KYw 3ETqDIjJb2AbzEOF
KjkRAxr8AFECMUS1KLn5SQw9OQRZNC4csYgZlGIfmd9852UyxxN09TlilgEM NE+DHYPt2GiBQZ81
kOpUL4IHK+uBUmDwHBV0gPlYYKwbzUzRzd0WtpMoxCAgFNSFGCIX3sfF973/ fRv0NJ5JqaxI5CCN
bXBjB/D4Rzya0U3ycVc6c3D/DnJcDx1D70VXj8N15U887IAVNQ5VxAA/4AM/ xAAD1gADgtdoGB3W
OA233RSUURt6Fd2GwFObmEV7wRcKvIAfjF7pvYUN/qBDfm1BocmADJBLx2nc ZPVNfWRRBhRUBtyg
QZ1QZDDYwXBcDEUYyy1M/1mYzREhzR0hbmhYQVxP+xhTOIADOIwDOIQDOazD O8BAJcDAIfDRVcRB
N3SDF36hGILhF+6PBELNxMXDOqhhPKDC1Rgbh4Ga12XCOYmdIJRfsQhECPwA CMxCLPxACHBBUjVV
4XnZVv1AtSQTDYyAWIlASwmECPgdDzzHD0TiaZ0RBppC3/0dPQTe4MGLsWgR Z9RZPtjCN1Se8TjD
NGAhDCRDcFxTDtwWPDSSKsIAJMAANKCIKSzaI6jeDDhCKWADKxJdRoTSJP7D D7TRP5zDMP6bnmxf
/kHIgCZMwiTQwiAInyEUH8u0Dg/0QWdIYyYwwhx0QAvUkgicIzqKAJqkTdrg FjUWAiGkSxxKhCHg
lj1uAj7cgz5ugieQn3qwhHANBAVGA0HugEHCgzw4lyy5FUHIQf7AQ/7FH7qB WwaORBz8wHXlQDoU
l7YVV7bBQzhxRAzowz3Ygz3ogz7MAzagpD3EACYOHDQZUQA5VzwUEP1dIAj5 m8eBhnqBDkHMQDg8
4Q2MwxOGgy3CACzMhg2UQzmogzxsgO1tgNllxAuiwguagg9q3MZp5QteZcd9 JVeGpUuA3JbsQCZ0
kCcYgga4gsDIwQWkgJIUDAAEocK4nECgSq7M/pwR7qVe9iVBcNSvPJ5L2IA4 sIM7sANiusM70EM6
VMI8HMLQcNxWfoQefGEcMAMzvAJmamYccEM3RI5EvFQrdEPV/c8OrEMfQJE7 WVtG1AAlnJMgnIIg
vMIL1GZwSOZVcgSSqQLaxcI5zAIsrB0XTBhupgYqpOMxIhM9MELqgIAwJURx XkTKgFk9VKLKiIAL
PKdERCdF+N2tUaIlqqOXcKdEoN9D1Jk99IMyPMETGA+KzQMMTEMO6AYO6AAv zGITrIB7OhsMiEMO
TKVazEAi+EAi7IAGEKgjrAIM7IFlMYQqrMwkJoMJhJIb/QAM8MBdYKVkKsUp qYIM5MIu5AK0/l2j
BiwChbrRCLTVQngoiIpoHDQfDoDAdZ4WCAAXSNiAHuiB1MzAO2bfi+zcQBgC JmjCJmQCJ2iDI6RN
KdgDJ/gjSZDnQ7CmKcgBM9ACM0RDla6C+22T/ggIjvRIxk2pN3SkN7ifPhkR aGrEl+5ImE6ONEQD
N1ADN8DpNlSDNFCDNICmSC7bLjBbn/6pLsSAU0XndMwBR34kohaXLllEkBDS ZXRMv4yFvogR5oUD
Yt6AORwmYsLADWTcQMzAONSBNcjAJWiCJBxCKrFgCzqEV2qKV2IlqxYEWA7E V3alQryqR1xLZPTA
aY1AGhyCDcyAgunACrxACErUD3bcP3Bc/mQoK6wu68bR5U4ioV9SaxFWK4f5 ysWIYmfYADkg5jsY
JjvQAz3AAyTsw2+1RFZ6RBxUQzcYw0X+T7wiAzWAYUu8mB6oQzfoq9N1gx4Y UUg2BNcZRAiEwB5g
wi0ImSCMgiCYwgsowws4lYbmZkYwlZLJwizcQDLyQAiYnqxupXYShHf+nQFR ot+dAAhs2ZOCbGck
wzn+AB+e48rQgw5UwQu0gCN1xrpyxHQionWeVnaOiw+G7EAMrCkgQiLcwiyi gPHgQ4vqAgsAaEa8
gC3MYgoYjzc8bdRWRwbMgNcaFAdogNfugA/MwJYlSt/xgDzsQd/1XeqgDLPs bEeYJ0bI/sAm5JYn
3AI27AI2YEMInEAbcayNGoTd4i0uqBg2cCwjnhYPSJ1E4GgfzIHU7MAMYF9o jczAosINUALncq49
HNM/2IA9aIM3SE5WOpXRTg5mrgJm7oA3yNi8SUQqfGk+4KVDyAH7cQM35O6W NgNMKUUquACOPAdU
zEGVXilmIi/ymmFnxIAn+JIteEL0Tu/zCuptsqxaxMH6VcM2dG+csh81bIPj PsSXysNE8Zui5Iek
ypOKAOWltoO4vsM7NNxKlMA6XIM7mJgv7C//6oIvrKpAbChXbuVW0upBgCUM dpyrsqoAd8RAmUIP
iAAb3YAI9MAOnNw/9EAKXF5cEsxc/nrwsgrMB4uwwcCctZ4wX16rCnuGhumc YHZEKthAOLyDO9Rw
uJZrP0RCOizTVlRlacgBNVBDNQQxEQdxNwTxQkLE0XVDK+hBEzdx1Y2mv84E kBJECPAACIzALjiC
KQgCIjTsC7TBC4CaD7sEKkwACvgALPyACfjADaDA27XTVV4EKmzidz4HFsvo CIRA3GqH8S3uyowA
MXDJRJRxQqjCHpwWzMqoynyxIHjxeHpJFasCNXgCPvQDPmSyLeBC9OLCGHss C+QCPsADPngDPnAy
Kn+ygIgcoyUCCTTaIhTov+3xCfwDNKAjD/DqJS6FIVMENBKEDGTCJHDCI+Ce McPA/jHvAR8F8yRo
QjEjMzQf88ywo45eHeUOwgcJiO8RhCE0giR88y7YwDQCKzuW34UoMFJUMUHM Aetqaf7In+/a2HQE
b+1qzNTsAPIapPutIUyFl0yUAPGahPFippUSdPIuJEfk3iYQKScs9CY0NCfA QHbMsU5QKZZeNPJi
6fhGBD3b7nHEHHJIyPqG9E7MADjQMAvAjgvcgA24wAzYTgmUQx1Mgwx4Qi98 wifkAk7fNADDqk9b
5aYQsKz6NKy+KkLMMReOEPShaD5siYLRQyp0sEMp64aG8AhX9Q9OFLZu9Qqn sLXy0Pk60y6GgxUq
pmJG0z5IAj/wMEhvRRwE8TVQ/kMP/F8PBLE1UAPzRkS7dsM1fGFf1ytfb8M1 5LUvv7BE/G0bgRIq
jF3DqsAafLLtZMhCONkV+0Dr3EAI7AAqkBE7zcR0zg4e9+pp6Z24aIWmeFKv 8kA6oIAqbEFtvoAK
OCpWjYTxTejiwoIGHMM3fIMGhAIN7ckvE0QL3G05vgALtIBxl2Nx68Zwb0Jx H7dxJzcLqLJGiFzq
Gdgi5IKjFZttvFE3/APKqO06TKgLaOA3OZMMUCMjpPckCHN7qzcAcwR7TwIM uDc13vd6Z8cgXIIv
2IA15wB3T1gWfdRB2EAjHHgj7EI9Pm9O6/S03U4oEnhCyMEOaCk3sCEbap13 /ni0RVymle4AN2gb
uoWTR6jC+XIFlbau5E6N5FpHKtR3e8NADMg4jftzvVwI1cyBFd3fKvT4RtMM r2WIZoTFWLjIEKIE
CdzASrOAO8iDPLRDPcgDCVgWQqRCTF9DO8BAJ3ACJ2x5J2x5RN/qUP+0D89q URsEAgP1Aa85Z8RN
KkRGOqLjMBw3+dRNPczlVTfrs+b5wZhwV3M1CgN6RgGmC2dPQ9gAONTDO8jD otsdP6j1O9iAlVAG
EE8DNcRBPDBRPLxCHDRDEC8qRuiBpVPDqJc6EQdsQog1KIVSKIXA2HnAKqyA GKiAag3hSigVClwx
7JyON+IbRUgZ4/5D66Dj/pfJAqjthxbI7wM0+gOcbaakb2cgsuyc1iNXe7WT XQymOrdyhAo4tAr8
AbiHe7i3QNJ0uyZwwreLu7iTe0uInCP44rs/Qtnexh5ksQskw3PUQzUYHwj8 OFIAuaEXBAwcuAw0
AiNEwiQ0QsJPAiNItEgM/HorvMQvfMMvBSHw93PMgD7PQOy+SYcaOILbgg08 NMk39LQpzkmwD1IQ
F4hL5DqgW5ouR/r1uJZmm9PFwxTDyGwbBDszQ+y1ikDAgCVIAgygQipIrS6O hkDMwSysQhLLPA3p
SkVKxEjf+GWQwDg4uQvIQ5Q3OgmELEGUgNgbQn1ngtmfvdnDwMuUeViq/sK6 vr0PznFWnq5GZEw9
6PF1gsAy2FIuZXUPPivgO6vgS1i2C7rh/zniP4QS3uU82leiR3ky1UM/ZAI/ WBmOZjO/uWEzTIMz
9MAwtEIrmCapN4O/Tw48nz7qN4OeDhOHUbkeBvLftsIieEBju4AKmLd+EOIZ s12zy9NHoELKjEAy
RuLgpY6KdjZSPMAMo8Cy10Ozu3Zt0vr8DBwqeAAiaACRXT8ieACowQTdNoQK aEImfHvC+UH5/4Ef
xPbQhH8mtED5vz/6q39wzIAhECjlDij8nNz8uADquJELAIQLEyNCuFBlCiFC VAkXKkzIkOE/UyUO
OkQI45AMRo04bmzE/ogRjIoNTZHEKKNjykaKZFh0OeiSr3/+/v2akWOGnlQP SUI0JdHFQ4eqbBS1
8c2GJkqZKC3NZENoSZ5RSS6USFFowzjw1nWLtw6eunhi181xeVZqWrVxmNFa tSPOjzlx5sgxWzUr
WrUk9awyqxYwXlOpYECCsdNnz7QNBe91GGeVHos9BVf2Gfhy48ybmf17pVex Y5ckwNWT50KevHqm
65FwyXhwKlQwJEWyfTuSJBiXp0YF/Dtx77wOg0rkEWLEQBE87rRwzkJidFP1 TAGw/rO6dQDRt2PX
3l06dsWUN78uLxp9Y/Xn15t3n559/Pft4c+XXx+/KhYUxCO8OpKn/hLIWa2e ePrRRBN+4vmnnhlC
08yxOJyZppk4mnGGGj1QsbCZae66TI44eogDrhF7KFHEvxr7BxWsAkNOhBFa QUWViqSC7b37Jthh
hz1U2cmyHPc6AYQRRjjhBCNBOGE83s5qSBUUyHmHShToQeGgigBE7zyGPNDg Sw3ABNNJ8l4DSjhV
VHhEBT/cfPNNFbYkSU024bxTzsmEsmGGPjUgoU8SPrBhFeGgRMWFGAdKsqBZ 9LTPMYlYQKwqDVA6
pBFMNWUkBr0UsjTTUDdtiUtUDpHpn398uWQG14RbLKH/eFNllVpNsSESjnRt xIYtecMxLTR5k6Ob
HIztxplmLmxG/h3JIDRzrzlWYWaVH3yjT7T14nC2y99gOIyqX8MV0i7QXjU3 R/qAXe+Vf5hxL8j0
SKvnH+gYvJeEPs5NCIZd/YVBDxuBfRStgUt9EiEWEKoHFR5AeJgHNDqYuAMV sJMO4+ku3lgi6jL2
GDuCoVX3PpIhxc9klEte+eSUXWZZ5RL4kyhWVCYdzqgfJtGEE1pusKEEoEvY yVcu05JD2WZ2YIaZ
V5buIek4DJ1jBz306EMOPea4Wms9qh6uJGETC0GEPBZ6cNxs2ZugFeDQFvJs ZIh8WIQTZHk2uCeV
eYBKd+h54A9TtNDhhRXyhHS9hjxYnHHGERPZUOxcxEuFINi4/hxzzFVoO/LK M/9chWHAXqgis17J
IJRrX1UFFT1GiDGEE/agNG0IgzUlqOG+3Z333YYjibDeeZcsclMwoUnVSyCZ wZSi1ZOUdrQOMor6
QntLWVbH5ugmRGK7Uqebrv5KF2yE5JjWL4Lxc9vJ+xxa6PF1xVV5fs3kp//k +Dr7zGj2zeOABAAM
4AAByAGTaQAGCFRgAm1UPMT9DmYTUUXHUOEOPbzjDiqoWMVYII+NgSxjHePY BzfWn/y9rGUwQyH+
VthCFb4whTEUjQtmdrvcYaYPoWke/BxotG39UA8/nMNc5CIHhJnCLnGgSxLr 0kSDWUWC5tnDHsYV
L9uppwJm/tKi+0rCOlXsARVQMtrb0qIKZaDgAShAQeCEEr9ulQoRjWMcIiLY ELH5RE2VU4Ee9Vg7
hOQxCHsMZB/LJJQG+nFWqoMcvGIVxSMqcmQPId5DigarqWALL3c8Yo1qtQpa CcyBz8PduOwihx8s
sYlOjGFj7GIt/52QfJgREgxZGEou4q8+7HLXAxcpFdaFcUZhFCaNjkinLDUP mRCM5StrSRz/bCwO
HWgBC1rQAamFUGPSASF2tvmxkMmwmeF0oQzHKU5alhOd59nPN21WAoX1UIeW PJin6GmyeGrGBe58
XMHyx8t5knN+iuzW/XzZCipGBZT+1GEqUrGKhjJUoNjK/uc70cI531SyJxb1 zSw3Ks8e9vKW7bxh
e86WkITmDaXqQ1csJ/qqeCIyhSxw57l02KR+9g+k6XxkvADaU58SFJPtw8v+ bkrGl6YNOEk1Z3ns
xzKF+WOE0azYtrQ5wm5mk4QZM2Edz9nVn3p1qWHVqVgZIjMTMjR6/FRfytS2 PtvlrT0NtOkq38jW
sFoSWv98K0HXB7fBJNOjduXoH5naPsL+xoo7faRQUUrSvwo0oDz1qGLbKkul WhavkbVlbNy40l46
tpjuG2skrwdWtq6QlpVFRbt2Sb/E1i+WW9QsLEe3WbW4KDCs6+hla1pbmsnz tKYV7leJS9bijjY+
6/zt/kbJiNjaLhOcQZrrFRtrW/mg1rguhWdhaavaQrq1S3zl62ZB61zohhak Ny3tWutavKaWD6nY
suxc5/tRyr4Xl8e1LWrxi9zu2jO1oelMa0nLzO6Ctb60Dep7JpgqBz8YwhGW 8IQpTOHsZte/GB6u
hvXbUxqaEEevRS8upxve5w50X/2t7krtqlP86hWmKj5xgWXc0eAm2LDyXbBg RSzdN+JUvDAFLnsv
M6fZBhTGmDXqfld81wwnmcNQpq5P09KZd8WXu0OOLYJpzOUf7xbMYRZzh3Gc YTNv+MxkHqtZf1vi
GTNZoaI9sV+bXODrpvau0JUxf+t85D2r9c2UXW9f/v075THembksHnSLkexm HC/2xZD+b3vJHGUp
o9nPfW4Za1N15cDad8lqNjGmBR3iR5k6s6lGdZepnOYouxrWpMaffmqYV+8u E7tL1fF3SaxpOB+6
pws+bzhfKWxh0/meo55sfsea5V3P8s+i3i6vayzpEYvxmDVqXo243W1ue/IV qnDFKsY97leUu2lN
c0W6X8FupqWbGc6I97zl7Yx62xvf+I6Gvfe9b2o4Ixr/pkbACU4Ngx/c4Ns4 uMIZTg1uOHwb3aBG
NyIecW50oxsXx/jGOd7xbsDDKyGPh8hHHg+TnxzlKT+5POIhj3y4vED/kIc/ 5CHzVNU8VfSisKcP
/vzaWPdc1sDmNaCJzswn//zVskb60idSQ2fHONNxBmc/8RZdqF+Y2EC/NleJ fWNl19jWWia0Vw39
7FtjVtrmTbDX6cvqy455t2+Fu5iPOvfhAAmwdr/oYfWe6ITgve9xD/RiFZ32 Y7ta6EWnr9pzuuGk
G17pkYe8ez4skcWf3dghhSGjAX1j+WIdhV5/vJNZlvlSDxrP5Xw61Rm75ckr m+uMd/uqDZtqRsKG
9qpeb+4N9nZT876epxa+2OE6/NyL/cX3Y7rWLf1e58N2xF/38uuXP/rqr1C5 1d3BRLnvzu6z4Pvh
9/74wU9+8Zcf/edXv/nZn/72r9/98Yf//N9f/n/525/+99d//vmPf//v///6 DwDBbweEQ6YEEAED
UAEHMAEZcAEbEAIfUALvzwUOUAErsATgLwMtEP0y0P8isPy6T/zObwM9sANH cAFNkP4wEARbcAJd
0AFjEAZn8AVrUAZtkAZvUAdzkAdx0AcPqUVqLTO2jwVoAnmOMFWQcCaSkAmX 0AmVEAqbMAqfUAqr
kAqvcAqzsAonygfaaMwQY598IwyjIgzH0AvFbAzN8O/ATA3XcLfaECHSEA2/ cKPkMMwQQ6akBiJc
4HLe4HLa4A8DkQ0AcRABkRAPURARcRAT0RAT0REXERIVURIfcRIjkRIv0RIz sRI3kRE1ERMl/rER
PVEUORFzCPENQrESBdEPNbENQnEVWxEQX/ER+/ATMZEWMecVCZENZLEQXfEP W3EXBfEWSREWg3EU
M8cUa/EYl5EYlbEZmdEZoxEap/EZq1EarZEar1Ebs5EbsdEbt/EbuxEcH/GG 0qLyDCUOSuAf8uEf
6EHmaGLmai4f6GVBZu4d5ZEe3/Ee1zEf7TEe+fEf6hEeaQ4gBXIf5zEg9fEf EdIgF7IfBxIfE9If
2dEfDnAH4LDukAqy6IkjO1LwPtLGwKzuMhK+QhIkxyyeGKoE9LAhSkAWwxEm x1EcZzImaVImazIm
OfEbUTEQeXIRcdITJ1Eng/Inx9EnEREo/m1SKZOSKW/SKZfyKZsSKqdSKqsy Kq9yGSmKJLJvPLYv
H+KB5r4yLOkhH+hh5uJhHssSLetBLQOyLOcRLc3SH8ByQejyLOeSLcHyLPVy LsmyLufyLuMhL2lu
LvkyHvwyIAFzLvFSLPeSMA/zKxOz5d7yMGkiH/JwKDCD9nrrIJorMzlTMyGi M9+HfUbzIVwgH3yp
NJOKdFgTmXAPsErqMy8JImzq92izjCZCD5uHBVqRBVjgBXDABXBAB3KgOHdA B3ZgROCCLqxGJ87Q
DaMTOuNwOh9LOq2TOh+iDKtzO7WTO7/TO98QPK/zOruzPOcODs0z8LJzPNnT Pcmzo+AQ/swOST35
rjrbEzvzsz73Ez/5MzzP8z/f0z8BlEAFtD8PNED1E0ELVEETdEAN1EEXFEIZ 9EEblEIl1ELfExCH
JivYLDHS8StVTkRHlERNLkRLFEVTVEVXlEVRjh5G1B/oYSX9rvZSatE8pfeK DkeVqiWXCzeryO9Q
IQZqoCQvT0d7ayN74iBmFCFKwDcrMDhfwDiNk0e4gDmrJi5MYZJkC/h0z0u7 FEyNT0y/dEzDlEzP
lPZG0zTTtK1QzfaOD02JTPkWKcjOdPdms0zzNE731Ez7VE/9lE//VFADlVAB 1VAH9VALFVEXVVH5
dBBH6o/OES+8MuVKgOVaFFMzVVM3/pVTTw4eTi4f8klqBsY278u+lu2JlAkh gAhITaoIbfTT1ioG
+iEGAI+mEIICclVXd7VgdtVX+SMxfpVXfckFCrB5+JANgBP8hNNYijM5lZM5 42JrJskj19NarxVb
s1Vbt5VbN/IkS1IjA++oMvKl5C7MZBMlu1Vd15Vd29Vd3xVe41Ve55VerxUQ KcohPNQnWAAfvAIe
PjUeWCAd4gEeZKAGNKAGZCAfPvUbPvVfCdZhIxZiJ/ZhK1ZiLZZiL1ZjM5Zj MdZjN/ZjO9Zhv+Eb
4oFJ3WvOmoQuGIllTWFbWpYh5oAJWbJ41BE90GAL0AANuKAHtoBnc/ZWTaEG 8KEf/oh0xXqCAnRO
54A1OCjgXnIuVYAVL5zWwXTuH/ijJ25mIk7xN4OTBmrga8EWOa2URJRoW6zm r3ysUROVbRm1bdfW
beN2srr0TYevUW1vTOt2UJXJTeHWb98WcOU2cP9WcAuXcA93cBPXcBU3LQZx cv6IKwOEYD+Ockug
Kwo2F2BgF2Rg5EDOcyn3c0MXdEdXdEuXdE/XdFMXdVdXdXUV40DOdUFXHT51 RsdL7aBFDuKBWouN
KuYgHnbTf1BhDqKBaaxHiIyoN1QBNQ0FDcQBHMIBHJwXesUBDRYrBu7hHuxh SLe3Bmq19ag2alUK
fCGMaS1CWHU1KlwEWcHvBVig/gZSIzUMoQaScznj4myTFL4WT3/zl3+DdugY D4D3138Vr3//V4Bh
z8CqboAB+Hb919EOmMhaL4ALmIAXGIIn2IIpGIMNWIMv2IM7GIQzWIQ5eIQr mIRP2IRTeIMV4lF9
Q1/LyAUiruNkSqYSSExgAHw8Tod3uBsAgId/GIiDuIeFmIgxjmopwIijVuM4 DuROdvXYw3d1V8sc
Kw7IEnl5Kg7SoRu8AeO44eK8uBvmYGBs1jy2IBwIJwdeQAdwQI2l9AUMJQZ8 IRfmOBdwoY7vGFxQ
74jR5XxzVZ6SVsKw1pmalGuBEwdogOXkgR4UwRBogEeUCC7kAm2Jb4Ur+YNL /tiSQxiFMxmTLxmB
x6vqFFitFNjWSBmFIw2oNFmFPXmVVZmTN5mVX7mVO9mVY9mWaxmXaVmXT/he E0NSIaIEviHjhpkb
SqAcME4GcoEEcEEGupiYv4OYo/mLh3iaq1mar/nivsOHrdmatxmbv5mbhxl8 cxV5KCCcP652oY3a
5gBgd0AuhOiVkiiIvKYfTE6MGSsOvNiLf7cH8kGfVQQiXtVMmvcFnFd6w0F6 cwBhUiEGOGETOAEG
YiCiJzp63saPzy5cUWF8H6x8mzRLerMNgLMC37cO0EAeFIGRaYBszVYyqHXH oE+Wnm/rmoz46lSm
YxqmZQunZ7rxhE6yfNq6/uoUqD9r8Go6y+Rsnm5ap5f6RmnapnO6qXtaqaPa qJMaqp3a9XZaq5ka
q62ap6t6qrs6rB3Ccccw+/bVi7fh4iKOBarh4WBABjZABmRgGyourQGAG9Qa r9U6r9e6r7lhr/2a
r9Wa4v6asNWarwO7ry0OsQU7sAt7sAU7rSW7rwt7o6/W4SDbrzPOiVv2Wbbn X/8VdEFuS10id0HV
QEzuRQH6UfQgGrYhGuJhB/pAD3rgG2CbWyxieXkDDcAhB8BhHdjhHYLbHYL7 jV0KBixhEmCgpKbM
SEHLMi47fGFDa500pA2ZBtrhK+RhHdahHt6ibOPCORHiOwZvrMrbJwDg/teu T/KsL4L6J5WnretQ
rPAa2OrQhb2pr73z273127/7G8D5O2UAEVJLwkMpowQyjhq2oRoYvAQavK6v YcEXvMErfBsAgMEv
nMG1I8M5HK+pAcOrgcMb/Ds23Doy3OFCvMMfDrAvfMRD/MU1XMRPXMQvnMUd jsIZbnwpIMctvMEh
rphHVZ3dI5+JuZovjrV5gp1Fm8k9Fx6ANzTiIBqiAR5mO+C8Zh2iYXxuq80g ord1ABzewR3eQbjH
3B10ANBg4BI6JSGGVKdbz9DGRbqv1iduCFnb1wVeQAbcoaS3oA5qANC5ILzP lnjUm7xPr7gM3UkM
ffb229H/G7t+2uwa/h3XqG3qVE/SHz3ANV3AOd3TIf3TN93wLgdfpeKsYfgZ Di7gqIEFoqEaqMFg
EVYQoMHgpOHgAMDgogHXEQ7Xd33gej3Xbx3Ecx3Yf13Vv0PYd33XdX3Yl73X lT3Zl33CB87guCEa
dnzVXzvYqcHWcbyzMS8h5ECtbT2vx33ckTc44kAaMlytF7zdt4F4tGgOmAEe ckAPkuFCkqEPciAd
7lkt9AOqBhocwHwdxNzg3eHMb1Si8a57a6D3SJW8ig9XJ0yQE8JFXDJZlZUG zEEdykEeYsDBYgCS
g+gHJonRFV07EiLls8PQUb46Xp7lyfs6GILRVX7mV77MQr3TQf1I/i896sCL zn6tuIJX54ue50Ud
6Xc+6Y1+6c3DcX3ll/NV4aYctqOhBAZuG2RAF2DgFmSA2weO4L4j4KRB7AHg tQPOOsYexLVD18/e
7LX57EGc4M6+7X/d7dve7GH77cO+7NV+yrH+7y+bAuYe8MEe66khneHbSeRg yhvf8af8Q35DDpiB
eCuf8i8/3jdj3r1BB4pTFVphStMBePN1uXqCoMXhAVJf9fnmuHk0KmKAH7p3 nx7e0gtYoynekLR2
fYdTz8ehDoahBhBkEhgZ0AF9WgtdKlpe5WH+0A9dvRdCvW+e5pc/LVbe5RU9 r5Re+5lepZjt503P
vCI9wOp7+4++/vybHv3PX/2ZXjBaOH2dziJafcoBLuBouARsmAQ2YODof9/M vt8AwhmAaM6iDRxY
0KBCgdEIHiSoECFEiBILFhzokGJEjRgZWlw4caIzCv9KUiBpMiFElROplYhj KqZMVDNj0rRZM2ac
aMyi7ZgTR0+cOXJkmrp5VKbQOT/mzNmxitYqPTirJjUlZ9WqVNl07NGjI1uq qVVvusiXM+kWcTrA
vQsHN244HUbLyoxRA6/eX9h4xUh1NfBNpITrFhZs2NTJxYwpXKVZQlXMEm/a sHjBwsUMcdfc1djF
a5cuXrp2ma6hJ3VMAKwBmJLcmrUp2TRdH3Vte7Zu2EZj566L/ju2bqSBix9G bPW48rTLkzN/7jw6
8unNqUO3Dr36cenYu3vXfl06+Ojju5c/fx29+PTs17s33x7+e/Xy69O/Hx// /Pz89/vv3gYbLOSk
CguO/WNcCdR85AwzJUzjzDQy6AKDLTI4YxGGBjEIgEUddkiQQBge5KGIDpmI 4oYrbQgiiCJ+WGKH
F8XIoIYaokQBMyOllOFKNjYUzUuPpcXeHMyQVVdx09k0h1ZUJWYVVnMI5UJq LuwQxw9QmsKCP8bF
hAY4bdEjTz1mlikPXUMahUoMn3CyCSedbNKJJ3R68ld470XJXZJsGqWKCzK5 wIaAl+GwWR3q1HBL
Lrng8qij/rigpppull7aG24yabrapa7d9NtgOHG66Z9EEqefff2p+l+qroZH XKtboroqrdylKmuf
rO76aq681gqsr73+KmywxB47bLLGKmsTG22UAFhNJRxIoAuvNIitMywwo6MM MGgggwzN6EiuiOUy
E1uDrZn74rrouusutr6x+yG86rKmLrbvdoiuvv7quFi5Af9LsI5BwjSrrlgh Kapd0mX1ZMN9EjUU
wnyiUgKCRKLRAw7hmAmymfTo8CRyksGAcsowWDKJJjBEa+ua3sl8WMOx3hRZ TCysYZkLL2hmjTjm
1LBJ0XbaWbQMplSa26e2ofK0bp9KnRSnUM/09G9XWU3q/nYxI7ts2MWODXaU EtN3q7HfqV02s2W/
7XbcYsM9t9xk20333XWz5ywLMMcUKLWFlaAvtw6Oy8y1zjRzLbcNGk6u45BH PnnlknMLAOWaW/44
upA/3nnkoV8++uiGm1766aoLqWSsyN0kxxxKzq4cUXx+aVUccsgRlMVDuiDP dS+E4089Jf1j/D8v
+FkYYDQBtrLLZptKfXUz31xVgTJRZtllLMxAwgx9yKBJJpmUbz4nmdQwpR6A TW1pa6/Jv5ps9cv2
G/30g0r/bPb7Xz3q4S5vBMSbAfe2pyXhynq4OhYCC/jAA+ptghCkoAQriMEL 6sdZgkrStEyhsaqw
gBav/kgctxpXQhOWcIUmVKELXZhCFr5wha1poQxvaEMTZi6GOWQhD3/YwxMG EYZCBGIJnVGCKwGO
PEQK4Ov0lBOvVaV3TcFdl14jQB28IAdb7CIXc+Cw2x1lZS9ToKnQZr0BmiJn qSAUGzDjMxd8sQaU
kAQl7ljHOiqtUgJk3pag9LVTJWyAX4uZBiOISAsmcklm9NXaHEmsQypykhlc pCQrSclLatKSaQlQ
zq5SIMGxqQQnXIUJTbkKFpryFahM3CpbycpTHqmEq6Rl4mwZy1ceyZW7fAUu bZnKXu4ymLCE5SyH
yctcnhKXxRQmMXu5wldcSTKMfGIfaZcdJ2JTm2sM/qEaqylFpKAsWrCa2yNr 0sE1vsFQL8ABC3SQ
gxzIoBH0rGc9ZZCaiDHxmxJLGyEH+U9BcjKTA8UkBv25q3OiLaEEbahBN+lQ iD60oBKt6Ez6Rs6k
fDCENymQVlyxClW8QqQkXQVIT2rSkI40pSAtKUpR6lKVknSkK4UpTVWR0pi+ VKY3vSlLeTpTnLaU
GTrNqU9tKlKgpjSVq2AB6/bZOqierYnY01VVk3KW6QF0qhczRUavaki1jecm A4qJGzODGR24AAfw
DJdb3zqlpXETO1VFI1XLqdW8WjSiFO1rn6ToSAayTT17nShfD2vYxBZ2sX6F j7M+eRUXiBInggop
/k4vG9LMYnazmu0sZz/r2dCCdrSiLS1pT2va1F72s5hdRRKfus2AXlOw8tlO VLXqOm3alqt4dWAa
10hN7rHgMmvdIjx1sIPkYikOO9DDD/LpVYBaVbfxYSRt1RhWxDJWuwVFqF29 u6r/NHa7ih2vebmL
3vKmtzkcTIuBQGiqEoxUFfR9DX3vW1/86ne/+LUvf+/r3/z+d8CS0a9/Ayxg AxN4vwhecIMTXGCt
uDYzO6AmzQR6YQJCkVX9LM/1MLxA6ARKJixog2Uwg4O1HjcHO9BBD7C03KDw kbdgBa94d9vbQlJ3
vedVr4YbmdDrLnSsPSavkYuMZB4r2cf0CVBZ/kc5WcD5bYnUrDIWr2xlLFN5 iVrGopWzDGYuF1jM
XiZzmMPc5TGn2cxsLnOB62sKF5QgM3OWM53vbOc813nPeOaznvsM6D8L2s+E DnShX2voRMt50Iou
NKMf7ehI2zkmqRCuzy6TAznmALks5kIcehCHLMlOn1v9o43rY90cCzC7TE5y q8l2ag8LObwze7Wt
j7xkXN/a1Zp87N9eI1n4lgWyfmpisZOU22OLUdnLnh2znw3taDtb2knKqFGs /Wxs10Xb16Z0tbut
bHKmQs3H5jaXZYJtc0fXT+peN7iZnc6zEhcHxt10i1/M3FDLuGRhTCONd6zQ UvdWtrouOK+l/hvi
WFeXrgfPdcN37fCIQ7y8GP3TRhGTzjXV1WEd5ni/PS4zjUcR5DYjuclFPvJp d9WPyr5qsZNt7Jcz
G+bHpjnLo51sm9sc2XX5JPdSge2biJvnvq1uwm8LZB0/3OAS93DSwztr8YJz 6VRvetUnznSst6e9
2XuvN8kak+OJXexnGbvZzz52FMgD7Wxvu9vfDve4y33udK+73e+O97zrfe9x F3msHFOgaLnRzq9d
9JwLf3jDOxXSjW484x8facdHHvKSrzzlLz/5zFte85jfvOc7D3rOi/7zow89 6U9v+tSXfvWoZ73q
Ww/718ve9bSPfe0fXyhiTybKk5GM2/Ox/ncUAJ/vxC++8Y+P/OQrf/l7B+Hb gw1cna2BDWs3e/XL
Xn22+6Mk2/9H97/P/fB7/x9lH7/5wW/+jJ1f/OhvP/vfv/74u1/+8J+//euP f/rr//77zz///+9/
Adh/AwiABCiABYiAB6iABsiACdiAC+iAEQiBE/iAFSiBFkiBF6iBGciBGOiB /3dl5aYYhZJxNBE4
wgZKHeR2XQJ3huCChpA8x3MBMch8NWiDN4iDOaiDzedNxfZBcbY96/R7Nzh8 O2iER4iESaiES8iE
TeiETwiFUSiFU1iDzud20+JkaXFxg+N7bdd9bmcI7wAyMCh2KPCFVIiGaaiG UQhfJZcU/u8VfYFS
KCt4hsqnfnNXfmuoh3vIh33oh38IiIEoiIN4dyhYbKHka3URSoZIVoBxdogG iWaXGSygCZowCYyg
CIZwFilQEsKHhACQg6xxg6BYg6RIiE0oPxwFJR8UeJMhhF5IhUUodyhxirVo i7eIi7moi7vIi8vX
hh6HhZbxaxjDexjThWPHgmOXhyXBAjkAKZDiKLlwC//giZ54hKBoisuXjaW4 d9todt6Id7ExduB4
PK2Rd+BIjtpYEr9IJCcYfXE2h223jHYYd4Rnj7KIdnFAAXFQh8yHjuMod+lY EgLpdgQJkN2ojr2o
kAvJkA3pkMyHglUlWYmITtSSPSpo/nZ3KHYayX0sYDQf6Qn+UAcocAFoQIMD OYo4aJDFt5J615Jw
Z4oxmY4xeXwvSXykyIi5gTOAl06UwQZD+IQcyYz9aHYUMC0waY50J47biI0H iZJsR5DZKIpPCZVt
5xv/YJNVaY5ZeZVi15QyOZVW+ZBjSZZlaZaAyI58Mi1cFxhehxg5c3bz+A/J KHYqkAnqswl3mQl5
iTx9eXZhOZBT2ZRYmZReGZZbiZWEeZiCCZjluJWiyJjemJQ0qZiBiY2kKI6J WZmWOY6QiZmKCZaX
eZmOiZmF6ZRSWZVUaZijyZmJmZmTGZlgaZmyuZnluI4Iwj+/sYjvWGI/KY/4 mHxC/ol2dMl9wjl2
POACyMkDBRmOTumVzimQUWmYtimWzKmazamZXJmamsmd0nmW3wme4SmeO5iT NRFKWWgYF5cTU/aI
oAmKGXMWXaJ+izAIjvAPKtABKoCf+pmfKhAPaCeYthmg10mTqDmYrvmcBCqg T3mgCZqd3LmgD1qg
3QmhCfqZB4qhD1qhGfqN1HmdDvqPGrqgE0qVHBqhCOqhqIkgIeQbOMGKUwaP vsl2wKmEwimXx6OP
yfkDyLmPRImOsemcs4mSpQmYTAmkrWmgDLqYkfmXpHmhrVmbr4mkTDqgq/mV kEmdk+majTmeXeql
XwqmbceO/bN7nvRri4ibo3SM/mQHnGexdmc4CPowCP/gB3WKARmAAXeap8xJ ohRqpQ36lQIamkwZ
oU/6jZkJoUvJoBQqmp7ZpBLKqIWqpFj6oaAZpCD6qJ9pqRk6qH6qqEP6pwna hr5hP+7oc6/Idjd6
fMZpdmdxlfCZD/J5PCdRAjzwA1nCA9NCiw6aon76oRNqohV6opz6nIaKoscq mb1apYRKmZoaqRKq
paBKmRtKmJUapteKrdlqlijYolhFAWzpohaZgmGXke1pdooQCRjQCIrwD2/w BneaAb+QAXgKlc5q
ooTKq4Faog16mhrKr5U6rYNprPramQf5pH0qsKCqsMIqotbqqxa6sAQbrM+K /qyJCqC32XJr5BhA
aFbxOKNQKJxdAnz9mKO2yqNxcLGVeZXTKqzA+rBGSqlbiphZWrEFiqi9GrGv ObP+6qQJe6wliqyF
+akMq61Fa7RHe4ujSqok9q1sAFlmEWWQsabHQ5xDaXaDkK6NMAj14AZsIAHy ygvxKgF/qaIVu6gU
i6Asy6H2yrMq2qwi6rPEqrZne7DD2rZ226GqOZMeCrE1S7EI+7cWq7cY64av AYeftDMyinaqanys
ioz96LgloZzJSZSDi6+Ci6kSm692e7mQCrjRqax8G7hwa7ALC7QTC7hIq7qr y7p+aIg8h4VskE5I
4Zbr6YgZaY+vZXaHUAiN/lADkVAIh1AGZSABGcAL86ALGTC2l7qZUhmtUYql jQqlQuukd5uiyyqk
miq92cmkdCutWTqz2vuYXDq4tXmo5Ki92eupRAq0mwq+7CuqqhhfgAejPgmU TmijNDp2RrmrKeu3
Cpq5Zlu+//uzMhm4LNu+Akys3nu6i3q5mhvADtu6E0zBFUyeaSozgVMoTzYT W6imVmh3WHsIGHAI
kTAIF4ACEZC8YcsLEnCS2Fl3WfmoOyjDOljDD4mTGGw20MdGbuR2jFt8kXs8 uetUVXt2ckABc1C5
Voqkouu+32up1bupQlul3Qm/UWyaOFvAS0qkohmYTQytsEmpMVu9zmvB/meM xmmsfBG5it/6LGca
bPI7YiBsrmhXA5kwCTYwCZRQA/IgDxAwr2GbARDQjeQbdzdsvjachojcs5LZ lXsoP4w3Z47RRkGo
uGenv1C4xPurxp3syZ8Myl6alsWBiG2QcRoVtdGXd4tQA61cAzKwCCUBAQQw y7N8AJscyrl8d43B
y43Re4YbID+cyUFcd0Ksy8eMzMmszIQYZ5KWRE37tDojrlfBnnm3dtkndi+8 zNssd/C1oqbgJd+M
IF7CsWtkYvfLzemszuvMzmHay+/ctLO7PcUIl79Jd8bczuzszfsszm9IaT7c dkaMfPiczwVt0AeN
0DzIz+AMX8GzwUly/oJyjJEfm9AVPXf7XA8Yvc/vaL9tR9B5B8R1LHchbdEl bdInna0L3c8raqZW
4cEuOrWSiMvlencZgNJnvNAZ3c80kU692YTYvHzDfNNDTdRFPZbwpdNIvc8B cso0UbsidLto5w8z
fXeu3McagNVZrQFGjbQa3c9JzSU2wT1XeIMkPXYfXRJmzdVrzdZtzYc5ndMP bRVxnCAxrYxCXRKQ
SHhoJwPX/A+loAGfwAgz4AmMsNVundIrbQpJrTHG6FU+zYR4zXeSPXYggNiX jdmZnYNK/dXw1dLE
oZ7jSsdmR9lGLJc10DKMwAiHQAsawAiGkAGLYAgaoM2afZacrdKL/g1sQdgG ZG2Dan08aE1+lF0S
cQACPxCFIcqNCGnbze3ce5jbjA1C4PqGqVzPbCfQY+cP5WeKwikDorELuUAL JKABJDCvGTADGmDT
zPvcCunVuP3LcnjJSEjceVff/wACLgACm7yYM8zc0HmzMTy056iy7W3gB66E uN3Z6PkYoU3NUX12
Ux13d2iKcikDnoAJRbMJ2aABuPAIGpALhg2gMIuiWYzgaxjdC609rjjfd22D 2c12wg3cI+ACJuAC
I7DE/Z23fKfcTnx3CPzjZ3viQ07kyQfXK02RMhHRdT3aLv52XfKqwy2r/+AI 9fkPb4XlfT3ieuus
RQ7dCCLd35zR/r8co+i8fFS9d5Rt3DX+AzR+3Berr2I8pawJvd2brKdLxcot pVec5+ILv4/p5YEu
6Gen4LjN1Foorh010WhH2RROtf4wsmIXp3M6CZWup3hKr2J5mD4+6GzY2YqN Cj2Jqot733Yn4/ct
q/HpD7BaEiCQ3ybwA7Hu5vvdoYHap8XqwJx7olq8wC2rrGyL6wz8rF3e6cWO 4CkuznJdE27JhU0u
djDOplQpnOiqruwqCZMAr4KMAbVdpBNr7J6u259OYlIWzG1X6jhY6l8Y6SUh iz+Q3yPQ5vr9Az7q
wAP+qQPLqANuuXhu4gFrxWK8tvsavhL87QV/2YUu5qbw2R08/s2N6Ozch+b5 e7VZu7X0JAEsbLzL
W7C1zukGn+CKHeZH4XPnHNBonnenfs9y5w80bgInYAISnqmm66txe8CXmqRo u+OpG7rCjq/E7vE/
79ZHzs/UDWz0bNfR/uR6PWd1yLu+C7yHcAiNULzHm7wa78TPm8hAj4QIr9Rm BTgArX2xWIP+kN+0
vp0RO/PWS8D/+sB4i6loj/Zvm/bpq/V139Zcn9QMjhShrejkStFvR5T9KMIk bMIoc/HGm/G1bfdf
/t79zNGjHpfnnvJ0B9x5TXfujtzV+b6Oqb7+ysVgzKv/Tpv9arp9nr2MCcY+ v/irX9LI7s1JXt1p
KbUPb7Vz/ue4d5zHe1wDyAPIiD/IrC+I4d74byh4HsvoYm+DZk+IZQv8ze/8 3QzmKX7ow9bwOgPh
ZgfzxcfKrgzLJUHLBHAA3//8fTj80Y+biDt9wmyDKG/738n84w//8Q/yKq3s Sk7XqHLdpI58fiz/
tSj0APHPlEBTqlyYQljiDZt/DR0+/JcP4kSKFS1exCgR40aOHT1+BBlS5EiS JU2eRJlS5UqWLV2+
hBlT5kyaNW1yHGiqXk6BAncKbMOmRCpTqBAaLUEh51GEBhFiLBHShcabVa1e xZpVZs6fPHV6NVVC
VUEXbBhenDozKsi0H9dqhRtX7ly6de3exZtX796qXnt+/v37j02bgwgNq2Kh VKBRpmIHsqTKV/Jk
ynK9dv27syALwwrPWnwbs63H0B1HV0adWvVq1q1dv4bd16dfrqaCcmaaULHh oghZEIUqNbLHUoEw
xUaePC7t2YGLOjZV9rNWeTSrK8eeXft27t29d6eNmefgobyNutjN+KjjlsM9 BiIUyN93+vU91nbe
lWznhRhPvyyNo/82CtA+Aw9EMEEFF/wOv8tyCqqw3nzbLTenHgPNtBJYKMGF DTt0zyJAAjEuNgBW
AiDF5FI8kb7wXgxrLMSCyiivEFsS4UYGd+SxRx9/BHIj5gAbT6ixzEsqJ/WQ GiulAlmYDyIUphSi
yiNQ/ngHE/jko4jFf1hs8UswIRoTozBBOvPEM08K08syVWwIToe8FFPFMr+c c6I147xzTjnxrM/B
zJZCrLM22sAISrWEA6nAi+Yg4Qd6ggxpT5j+zMrSkjS9CFPVOI2TUlFHzUrQ B9t44zcL0VsqN1WD
40hRQP8JsJ4HHrjgAQtufaAhQOKLsstZW9QUVD1H2tNYNB8iNk85PcVzzTZD ndVPYSualtoGnWsO
LMdSkQ6jYO3SUSURShChn07HVLajadvNS82Z4LUoW5LoJdNTY6XN0yV78a32 2E5JJbjgrfJjjrwj
G0sPySZReivMAf8ZQYQRLrY4hBFGLBHbYbUlM2Rq/t2Ek06SRQ71TUBNjrZf kJtNuWVL5WW2ZpoF
Rhlne7clEuH9EuoPrXKdZNStj24oAekbJvXYX5dZA/hek6KuV6SdA96I6mW1 BRjUfQ0GO2yVTO02
QsMYQ6zCCS+EdaOpwDwxqqmgXCuEE+7G+4QQMOE4Ho+z7ZNPmFt2+d2Ra3bW 2WTF5BrxkVmWd2bB
X2a86Xz1LTxQhLlNSEYWaLxo6KxEJymOc2/44YYTIr0u55XdTJxYTA2v8/Bo 7WyzZDqZLfl1fZ+1
83bgZZ+ZZDWJD/nm43WPHHc/iw8e+ZVB9p3fmHmnmd3YJ+c+85ilVxl7wXMf XGzzz+9oSPEEYwM3
/t7Carixh0+K2CEoJQq2HhBCCGF//vd/x68AwbRj3UlZzZJd4bQ3vacpr1oL vF4DGwczydnMZpz6
muOuBp5uDYogiCFKWA6VqHEBqGik+cfc/CG3fMhKBCRI2g9kaAIXgIAEBHxe 9BKXssHxC4E7/CED
d/hAxTVOg0R0YJqe9jEKYq1ytCMc4YIYsHctron9uhoUJzjE423xb1K04hCT x0Unos+MZ2wI2WoT
lPIw5jxqm9CrLuKoicgqTAWSwQzyKAMb7FGPIwLEcYTVw6xFkHFZtB3loKjF m1GOiYl0nCEjZzlK
fox63FEfbVDxrXBdpIR0IR1F8OeQUf7DH/34/sHpUre6H6gLZxFMYg59yEPY TfKKEFQiLJcINyQy
kXyzA6IhvRfFWE6Pl0dMUy2JOUwvZm6Rw2JXsWT2MtgJE5d1Ch4atYnGF3Fr MBLiTZIW4zAMmaRA
A5KBIdS5znXKoBYxCMQAB4nFQl7SgdcrnxKfac1XEtJ6rrtn+SRoSUJeEpMd fNDPwhI0i0yMJXRs
aCgdAtGH+MMfNzCB0tJRNQvqcoPBnOUkjUlGZzKTihb8VyNRlj1hGnGZtJui ziw5TZaaVIuP9OgS
+VRAKZZUkmT85zaFaj41duU2Z2tKYlqFtsK0zT8f8hCHZPUQDwxiEIKw6lWt uoF/ABKHLFPc/u6w
qUHgce+K4xNePqupU/KN9aTPQ6tbZ9q9tnLtT1pTTTdpE6PNgM4iEq0KYEPi D3qcSwT8GFhHX2pS
nArxlo3N5TJtx0jJ6tKxDGxkQReLT8v603uAW2kia/rMfRLRtDMlLTKBOlTW hi2TgSFPCBmmJKSy
Byaf/McGdLtb3nIVEDGQp9P0UkHs4DWvCO3WZgyFqItMFSYUpYhDM/SRH0QK t7uMKwRrJ9PtEnSy
xktW73Jo17Y2j3lwJe9oTZvMbL6up75TYHvdCrg3gXWsZyVefh94XkfONZrM 068BxdtaApNKjbMx
26rgyBg5TtdoJanHdVNi3Hl1CVpQu3B2/l7rlU2OBVxmEZeNaJKuqcVrU8hi 0zYpXOICt9jFDtEr
bNv3Pt3Q9my2fXGOj9uzhF5oodOJrmBFAt2JSLciRK6ohLOW4bhQTaxbsxqT C/Zkq6xYx1f2UVEh
JBSiuNEUSiXI2po6RyyXGS4x9pbn/FoRIdekzWaGc5zlPGebbLgn36TxJuPX GxxXxMgUQTKdBe3B
B33QfSUYYXOVTDS2CDbQg4Z0pCUN5wN/5agKblUcgXOR1k3a0yGxs5I4CWIy z+TPE3l0Q079aVa3
2tVE3ZxfYmse+Nl4PfM78gk/UhxBvlqbldaMjz0jl07DpNi+RnaylR0kLQOF DRJCG5iR/vqz9oxk
S4teNqXQ/Be+zgjIqKbJqh+S6hS+OdvnRne6URNq9kEnnHtmUjkBrSEORRVE HuFYrxM7GSureyLN
Tupy5WLujwhZEPXwd8IVvnCtANs2qQqhG1kVZk3LmyRP+uSUUFAlIVwpS9fW k33dtS4poxjKDIcx
59b3HA93MqIzcS5HyC3uhsRBEHIw8StRvnOet3jbA1EYjaWtHpZbHCKrtuNE J2IrXOmKV74Clkz7
7VKVTH3hDlfosENHE2yjRLCCYMHBSV7ydVlr35E85kes3nO2t33HKzfqs6et 56U2Zcx/7Uj9VB2i
il2s7xrLt9QJ+uTlBRV8uzMZ4hOv/t/JSa+75/45QRzjbf8QPO+6jlXXG0IK F3B+FPXcVO7MdC2D
emTtbkd96vHCbrO4jylDry2uKRJzP+eDlyykW0Pslre77a1voS3mSXemz9Xm 1PhR3GzCAa7chCQa
73gRsuZtzoJRxGEUYcc5R305vDFmb3jgiyRd+Utl1Zff/KxxOBu7fOMF+2bT FbHo5bV1P1M6RH//
41//QhBAQgR3vMlfnspComviJdIiwAs6GX9jt6L7sG+DCNpriZlztHLLPRVq CEFAhBIgBTmIgx/g
PEEQO9JLLUWapuPLrMDJLDE6vxVkQcqIPDx7H4PYs6KrvMzTFjzSIz3qoxyU AUDS/jfhI6kg7CXV
IkLkaywj3Cl1wzphYyj4EzGRKKWIqL+GqAebc4HqI4USEIQ6OLuaSqtcmqIk 0q7wkq8CbMEzRMO9
ALhLm5BaCzOmeoqtk7kgm4h0Yid2cid48j8gtCwhBC0ThKxAJL7+grxYc45u +xwHHLdwEywILDWO
qAdSYIFSYAFSAL33QsLJEsSc+acUDL80BMVQvArWa4PyQCrYkx+jewhHPDqo +hDaqyqtsiqsGgTf
iqevEpn6AqbhE6vFqyv6Gj8syqbFUz7kIhLmEyHmgovomwlBcIEQPDvU8q8x AsTIaqYjFMVs1MaZ
SD+5yw26ozgGez+KiD+SwK3e/kLHrgIuHKoUlji9M1zADjOFBqxBmWDFXGu0 j7C57Bs9suK+8HM8
XSTE7OKvytnGg0TIlHjBGYvBiWtDGhSaRjGJCLsXsju5hPyIJZQQrXs+mdA8 kzA4hDu5d8TIkjRJ
vVhDLpsQpFAbOFRFUjpJ9Im8zukrRXQImrs4zNuIe6QIkRzJmATKoEwOUgSn pII3viIhoXQtY9SP
Qmk+ZWSzJ/yIj1TKqrTKBelG91EPcaK1LxvHiVghnbzK7YjHUbPJhuBJiBHL RxzLtnRLBXnBUpSt
3nBIopPHantL79BI/jhLWmFEiczHvBTMweQgHisbb2xDaVuVOHQwj8BJwnRB /kNMs5okNuuAzMvE
zNdgPSN5H3Bsw3jDS4yogdGsgWPLzLpYPqdMRqeCiceUwNOEzdjki/SDOEwL R/d7yYZAMnvjzRCR
geqoDhmwPNlkibJsOVJbRpoQshwhzuZ0zrGRzDsrxYXhsxm8S7Wso0+qgUnQ BEZghEMwhBqQAfGs
AbUTvQIUMAvrIlqyyITcS6Dpy8cUibSEiNf0CEiRFMrIIJNznef0T0pjyi2D NqOsO2pjS0W7QYqQ
gV3QhV3IBVrQBWzYhQmVAe0zu0MivSQUmGcpI6WcSURcM1HiOuUECcNyJWwJ nEq6yP7kRNGLRmoi
v378zxk1MJWTNYZ8H65c/hKkxM5ZQSdPwIRNENIg3QRM8AQYKLvtUSlHqiCW IskVTM1Dc76KoE9z
WkuLqNJ/UJqkYcdPlFGredEWvVAVPS0wpdEzFZVubCOmcMhpazB8dBvbGxPc C0sZ0IRHuFMZ0NM9
5VPTfCKa6kXEaVJjStGgNM55dDknhL7B6gjTiSHVYZ0MFT/kMRzHox5fRC/i 875fMqtPVLzDe1I0
FdV1i06gIwwac8OHvE76cRn6CxYZmIRYhdVYxYAMqNVbHb0mIi7MEq8fClXz e88fq8eYsE8UUiE6
bYgXiqEZqqEbCrm1mqUJ0qwyCr4UtKXiQ760+6mWGtVuRZCU1EoCfUO7/mNM OE3KWSkQGJCERpAB
RoiESZCEWs0AXsgAW/XJfNFE4oKbxRmpX1W9D528RKyRRYXCKZTCKDmlVEoa HrgBF4iUEwVIXbwn
YuoTaYFWbPLEMNy+MnzWE1wrbwVZAyFFU5ytcUpFRjs694ABdmWERmiEQ2gE CfiFeZ1XCbAwgHSi
4dtQa/HXfw1QQxM4BJWJYmUJi1IdjbquoArEPuREbGXSamzaInyrkKVazTHM NUJMpmo/r8xNvxQQ
V5SqT9IAGXjZso3ZeZ0HXcgAm+1PHzKggYKr88zLQ6VHT5JKlyAsEKghiNW5 EVzaMvVbT8TW4Jta
wV3SqkVc7FhI1+sM/uvss5a4LhiQ3MmFAQiYWXrlBQm418QliWDlyNpblMCE CfxUMjL8PwDbL4tF
XQHLp1z8vk5lK2Lsrvbk3NqdjJRc095QTDEr13kDTI9AOAioV3rNAAiw3ZIA WDXry+F8CeYVFxI7
3ui1SqLMMx2Nva61CQggAO3V3gOgSulNuattSimFytn73iG70pQoR/BlX6DM ymmTwUwTx64lNwhr
35Gg20Qlx7u93/6d0bgk2eq0NYh8uQfz35rw3Cakw6FN3wN2YMxMyQHdjJYk 16710wc+s1KVPOVl
zZdwTQwG4djcTHdrXFsDzQMVEOcNYYqI0qCFiwte4Rh+TtpUlZVs/lNX+Uqv 4wjSLE0ZFhIbdQ55
rNsCJtYG9uEjNkkApk4KGeBVBV0C4c0PqYjf/IfgVOEv1SnZTODl5V+OiAIk BuNQjOC548rF7NpQ
or0B2c7u/M7wHM/xjIldJc7kpcyIZOCvrTeoEp04iII4ON+9wKueJdMwJuSV 2EzGNQpU5DPZy86N
8IcBwSMGdVAIlVAKtVD+9FIR/tmAe8qBnQuM24goKIEvXjLa1dZLbMcL3U/1 JDsy3EVoKjlBLmTE
VdP1W4+tfVOw1DxQhggZAFIhLdIhPdIkbby6mq8Ba878RU4q/ePfPVeHCEuM 4AMWGAYW4AMsXlFU
HsmPyuRu5ggM/hqmVZ7lcQZiWTvVhnRcRk7ZzLs9CqzTO81TPpVnP+1VqOVW Tb7a2cg6BQbLujgn
HeHjEhiGOKjmPsYt6ImrFmW8XRow8Aum2ZVdhc6uxutY4Rk8X6VdcsZgcJ22 VDVjT+7gcquOV43V
SZjVSbhVW7XVXD0cA/zYOdZgmqQ8FHaJVXubOXXnt4gCUV6GOPDpYRhlUm5b IXSpiT2tah1CpN6g
f3kk9vIspr6g0tNoJB7ZuUzko3zcRo5TcJsIdWXZd43X4a1XDNhcs9NVp+3Q 02zhTo6LUMK4KHQI
OYgCao6DaY6CH2ga8DLqop5GWcKnMfweoEpRpq5UnA3shL6m/qkm526UYM90 0xxOMvl7wE9a2XZ1
WZiVWZrN3JulJwDERi0u578QYv0tsitmZhusT3Gp5mkeBgkbRMYibLjFGi98 WqXet9SyxqbGLqZV
7DBeXBqLX5O9ta5Fug5xxQEZ27KF2bPlhbRdW53DrEl16Bk2Rn1mQi6eia57 ZPc4NVGOgkULXO4S
wMiC6mzl2cEV71jK7cK+VKLubTDGXVtmyQJlGzl05I+g3Mm1XM3WXKqOaRCN T9P2XQLJ4zzmCD7W
A2wTyLmC0YQmSGsUORf9VEttINSFr2NaIPlCq2R6b98ObVMtygk2YR7F0u9N teAV6+L1bbjjMK5d
TfuGje/O/hTlkOUOf+/3zQ2PxuHcXF+Z4N7tJQDv9W+Ak0eDWGbzDV0D1k8a t/EmjwkAturoSGfi
FnCLKOshJzRuu+4Qc/Iup9ExzvHddcmQHlbJnuVCQ3O+io4jL+0k9/I3T8MR XmLP3NGsPokq/wca
sIEasAEa4PMauPLjDTVk/NwBF40JFF04V3RI60pURQUKGIwa1lr5xU0yt2MU 2ojSlId8kAd5iAdD
oIH7RXOfCdgQxQoYVgk8X/RVX0oCoYAEq60pD02WsAF4iAdPlwd6UARQF/VS PQ8XNtfWRPSPkE9W
N/ZtyjRUTRs2WhgGo2ADbUzTGPaLcIR14IB2iAd3iAdF/th1GkB1FtsOf81t FtXMLHeQL0OIIdYK
VX8IIQOBY4d3M7IxL6tOWGe/EbdzkHSJFmiBD+gAfseBdlCHdVgHG2hmqUb4 uQBnC72rCa+dGB13
cneNQVfzQm9zezRxI36IOAABvK4LOY73kB/Fce1K9Gg9+L3hirN0IjbzivgA YMCCl8eBDxB4d1CH
GTjoCeOLC2MyDrcn8e4nbC53h/MxgYXx2yLRj9BbEChdF5X4VFbojL6cVhZ5 Y2/iHIV0uaQ1670x
ddb3lmgBHICCDsABsf8GgV+HGagX9vpT1g3AfyzUT+1UCpf4hddEL+Xmkaqs GqeJn6PJNQ9wN5d2
kMjS/hFwARoaAdd2em/OZn5NsaqHfBa+TQtJDFiPtmev72hPYYk8VnfmgA7w d9DvgA649nIohxkI
9CQ86xEUqL2mLB6iurpnePIyqLx3Ur4eSnPvFhCCT5CuC2Y8cL01gR8w/I7/ ok01q/P6x2MWKGlk
3QzFVPiKfCcf4M9MCjZ8N3z3+pJ4sygcJXnoAGCY+Szwgg5IaQyo1dKNbtvm 1fZSXY6FpUKVarsX
IhWM/QQ0SPNWjkGXR8Avc4D4J3AgwYIGDxIsgXDhPxf5GB5U6JCFP4n5KAoE AcKFiR8eR7jQ6M8g
gH8lT5ociJJkypYrU5YU+PKlypoyW8K0STAmzpk5/iECDSp0KNGiRo8iTap0 KdOmTp9CjSp1KtWq
Vq8uNPXPFFdUXbma8uqCAhs2JVJ9DTtWK9iwXFmghaiwqMOicxl28ALlAxYc HzIA1gUYw0IAMQ/f
9MlzJeLFPQvyvKnTJ9DIkAurNKz5smXJOFk2rhm5M1arbLfWO606tSoXYEu8 YQPxYWmjtG3/Gynw
oW6BPzaO+AESxI/eOyWf1ExTucvEokUz7zy6eWLmlz0r/lx7O/fu3r+DDy9+ PPny5rNu9ZrWrSkW
ZNu4bvuWAlv1XUuo0hr1NlQcHT50EGALEuySAS8Z/CLBQYYd11x2zjn4HHLY feaYY56xpJN2DVZ4
/p10GnpInXaknXeUaqid+Fp+qrDQhmwM1XXVXUPFONSMEPkDkgknmOCPcQ2G xqGFEw4JIYgdImbk
gpM9RlOJT0IZpZRTUlmllVcSxRZY9tlXAgUu4rclV15qyV5rXMllVI1C3XiQ PF1cw8Exx7QjgYG8
HKjgdUA6d2F0E5q0mXU9MShToZtVWOiCii6maIbTDRoog4I6KqSfHGIJ1Gop prYVi6+10cZsUvI3
lT8bgfDjnkZS9lOQP8Hq5IhMXiikhDmRmKmuu/Laq6+/AhteffLZ1xpZbMRn 5lrpiRmmVKU+RcI4
y4xzzTISHJitBPWQl6uU3oIHbq8porjVVmGF/pmKC2VBhJGMakKbJlG//QCR ZYcxiu+kgCIqqb4Y
AtxovqSNdiii/wabsMILM9yww5mWqR6XpnhZFgvyjUnfuWnBpd9CbQK1ZlAg G0RCCSabDAFgB2YA
QXniQgnzdjLruqm5m545Zmw4klpaqgpP1xTNDxNdtNFHI500RMOup557YKJl pntM35ffs6X5AwEB
Wmt9gKpKgx0spymOuWKLL35cmshAuWtj2BkCnNTQb9Ndt913423axuzxPRYb 8BFLscZimpKzvESt
fbhR3ObdOJY2Q/7pmKGWFy/PjmOeueabc945eFSvJ7jFhBtLtVfOwmh52nSp PhANNtRgAw2x/tfA
uOe3f37zzZ1qiUq666KNUOJRtc0mvLgjn7zyyzOvcMRNt/feWRiTubfTcTEk T2naA1WDPPLk8308
htDQvPlRQa67KawlC1vwEZVGcup2nV+//ffjn79TphPuN+BpsWhw9kGX1Rgi v4UMb3UQsQE84iEP
MIDBBYcgn/4qGJSxqa9shTubr7hnwQ+CMIQitGCZ+NalY4WpWYMDYHyuNhUa yCMe8aBHBBWhCPJ5
cIQVTB9beCc5ilHOgGprHfxYp8MjIjGJSnQes9pSrKchy4lcWZYJKVZABdKI iAY54EBsoI51uCMe
YCjBH9axjhlcZW7hUeMasRI0hLAxS+or/lfvfscu8mixKXksyAfiscQ/AjKQ gkTfxiSmQhddbD1T
s95bsAeVPRqFBu1Qxx+SEcFksGMdNvjaUMAVR+/Iqiq58lbBdtKv6EyqUhry ZFV4uLvCtW9n87tK
8UYmFBeUgAUlwKUuEziQOHwgDpyszSeBZq9BIjOZSeRfWvxmlqhtqXp8I6DH hAdJgdQSKFwUyAzW
8YcSgCENLlBGOdQxg68VE1NUSmdRVGkohpQybh+K2yqP2Ur18e5mGmSRi0aF lWEyBWTZNMgHStBH
eLpTboJCSpHc2C+lsFI5MJPOn5Rp0YuGrYQTm8/fkqWe0hWSK4ZjyDUFAlCl zOCbY/jB/hj/UI4z
2g4yBUtOdQaWHJoaSl8EG1hOIfRQme5LUpnZF8IoBU/MwJFPs4LbKH36GHo2 xZXrY8sPSxDEhQw0
Kts0iC8H4i6ebDMHJRBrDgDKTnXGsValUStD7bkhopwVo3Kdq5VAZ0IvgSk/ KuQf6rB60i3CiyIW
EexAUuoCMLDUBckoRzlmEFOSJCk0DWVMwJ5KK1sd6khN4gx0QAOoJSU1tJ89 GGjf6tQkWVYq5Jqq
Pn2XH3XdcSF/Bc8e78KTBAKzBDuIww4MKszQWmdQpH2jTU5psDcyJrMOSuVQ c3qvySgXJsY97lDV
ejDSCvW5/toswujq3e+O53lVdGay/tizSCm2x5EH8VFpeDMQ9xIkpeBkKQYy UF8M1Nes1EHJZPfr
3NT6azm3kmhpkxtUWG03skgtLdxEdCtbmRKngToOcaEiVRTljGKyRGBJj7LV gnRVIA4h8GArMpAP
FDQHP4gDbw160EcNuEnaRWuHlvQqyrqqstYtboz7218KsQrBBH6QdIEM3iMj uTTMNC8KV7EeaQ7Q
tdU8SIgL8mGChNiwiAVDfTPgi8EURsG46jGRYkzjy0L1sj5GM2obvKo9SfS5 BNPsaR8c14NgUDX7
5CBJe2ZLz1AEvgOJR25VLNYP9MByqFVMRdXpEqO+07PSXSh//ZvgVZ6SzEEe MpMo/jSkChN5JpFK
MqlLvT9GPvlLUZQPSEnXwj5jJY8kEEcyDusCDGQLQXqSqVIrvekyB1lEAg72 Wz+t6c06eFUVhnBl
N8RWPi36zU+Rqg8TCURRMSSrULnyQKr81YEckB7y6K1Yd+BHpK7Z0R+qVb44 i+Ax4zjUSkV2rOht
ZHZzl8bpNq2p++3voti1WM60Nnug3KwrIkTbCOG2iLUoLWsoIxl/sBOefpGB XR9JwZSpaGQpxajm
9lSoiRrlQrd76epaGrLsTqiDbzrTm4qcqZei86nzfC4pw/Z9Bpntd2pLZS0W 9MXoPnYo5VzPjJt5
5jdO7czrve9W4dvYIJI3vv9t/vWrLy2kVaxYG6YntRVyTL075/lSZH2yk5FA AvMwkIFc1i0r3Vlu
MbtnD1fLvtds2JpYYXhD8sjLXeYyl38FZhzogVB5i5xEHPd4yOHceKUjx+Mz frTANn7dymNap5F3
kuZP3nisgz70N9sokzuKMcGBTsoQqXJCjicU3aiM7S17mUNHfXjzxJ0puTeI zcsUJn7qvCAdrs0e
cziQ2frjA+u43e5FqXvRQz/6DNEo4UzhzBS6pdUsRBOsrzL8rRHgAOCXvtGo TVVrWxXbft27691W
lHN7rvlU+eRPyW9/0Qe8LVzvGN8M/pW+JhzZCQTfsd791Y3d6RnOAc/lQMnw /hngA0JgBBIS4UwM
FGGfSJ0X4XQMQ5iYEREF30lg+dHRHE1VhrnP6jngB7ZfCLJgC7ogUyyZeviP R92HADkRADqF8T3F
68TO7MDOY72gr/AQ7+xZPwkRVhTgAK5gEDJhE5If9aXa6EgRFW3flAGWB7of RHgP+IgPBTnhuJBg
Pp0fqKifeOjgVKTgF6rhGipT/mGgqk3PAJ3XxOCgHlEFA10AClyAP8jDDZUP G0LMCG6KBuUcCrIf
FgqFwgHiIjIiMokXHapaebmFNGmg2F0h4pTUVsHQBfzDBdRDPNgQDlmF/EXF nEkFKR6daElJ741e
LAUfQaShVXSYAAqEIABh/iPiYi7WTwxOEQrp1UdRUZTVIVPE4kLYQDzk4QXE gzuYETtsEkS51Tox
mLTRXKJEGOYxHoOxEpXUHT6VibUt4CxZBQFmYlHEgSDIwbdMoy6yYzt2BxTy jXv8Df/pH9gBI/dh
0S2VI1DMAD2sAyf+ox7GwzmtY1vBXUFO2KIcVWYgneOp4jauYhimiJRp2Cu+ l59ZhSCwgC0eHssF
RbstpLLZXmW4Y0maJHpM011FohQFEF8hnFMUI0J0U0DmITBcgCYZnkI2V2YJ F+PxlMkBVVFdXkLG
XHBFl5s52tG1WbHRXJBAHTcK4ivBEljwGYcdIibSz1CQggts5SiQ5FKA/uSC YUoxoeJJmqX9PaKY
WODpUWLYWaGVLaE29R1hTYRuzAA6mIMyqsMF5GE3EGSY8YvTSchStoqnadrS 7RtSNuW8YZdD2phT
GRmUsKKWpFA4LkRMomFVnCMLjEIcjMJGpuOCWch0cZaBoVziqdtPDuVZsiY7 8qL1HQsNqoUNRtNL
2uFRCJqgzYA4lAMKdEM53Nd9ZYB+aRy9xdt/sdVollyOCWZNHZhiplnQrFuB ARVROsqwRSRrQc4G
4Z1FNtxVZhH91GWJ1SIilAApyEEc/MBWCgJHUuevYUilUZ2djRp2hlJr4icb wuMJSaF8ZKCy4OPC
xaXiLAQJsEM5XEA5/phDl1mcfQGmf81nhBCbYWIWsDXnYqoinBEYhb3nY14o v5EHAqoPRVomQmCm
C+FGbwhaPZyjC3QmKZSAINRBSDLnpF2nhTLacjqbjnJafvroIrrhBsEhWhiS /02ibRIjVeymOCQj
BqydtuhkYEYoYvKYcSIblcKnNiZlZGrXPPGbU04dVGqnN06lznhn34GnPmZl UNQDKbBAKbAAKXwl
ZL5blUZoKlJos/3onn5hWv7fl/xPW2ifWxJoUCThP2yVtFxDOSwqxfGCxWGc PJWZn5Rcx6XSx/0X
akJmdxnlUoIcoTQVkjwUKsFcgTUdiIaoN5KgFW2QEV4mRlaFILiA/nvSqGUV ptFlKXbmqb3xaa+6
4Gte3y++Bm1WzVuWHVU8nDVMC7ZkwJO63XhMFLCU5VFM61J043ZW1VUFYJoa 6j4OxTmGZjSCqsC8
Gaeu5rJ16uNVq6+yaxuiWjy+Bz26xX/eo7GC24AeoVygzMnEHss8q3iQkkdi yboKBcEihYiqhgLG
FkLQ4nacKEPQaidtabtSbMWaSBNVn+/AoV4VHLGeDpIeq6kc3z9wDfhBwC1a rLVGZd2VaUUa4rsg
4p8RBcpGo8Gm7M26ptZNzAxizKCalyXCZczKJVLQLM4qxWSey+9VpYnCqtE6 7dPuymvKo1k4Wf8R
KzW9bBaG57Sd/l7Xeu3Xgm3Yiu3Ykm3Zmu3Zom3ajq13jOm1Mgv/pV+7NKxR kOOaQu3d4m1t7Oew
ziM0zas9itSrLcQZSgXhFgQPyg7t3GJaGBJ7NO7jMm7kOq7kQu7kWm7lYi7l au7lbm7mcu7nem7o
di7jvuMrqSo1tcbCFtFVHGrd5u3rwq5qYex6GMvfpJB9BOPB2asSCm2hHsQW hk8MeWFBoFf1hU5K
DhDyBk7xHm/yOu/yGq/yMq/0Ru/zTq/1Vi/0Nq/2Ki/bnq4+mWDehYfhQgX5 xu75ou8F6awKmR71
gN3P7i5SPCxBMJADORA9+CHvTRP2bu/1ci//Um//Zq//EvAA/huwACNwACsw /5Zu2woiq1qf6nLV
/K7u1mpt+mJwBk8fxm7U1FrbR83hDYJst5WUIl4iQ8DQMsbDOvShH+YQ9Dbu /kIPABhvDEcZ9FDg
lhhGDeOw5MpwFeVw6NiwE9FwEP8w6VluWBSxEqOXehTxxHiv27JsVYmvQVAw TJaG0GnwFuPs3vai
7frt6QBumfoTUcxtUHjROsRDO1iAPKzDSz3jQCQweywxENMwEpNeHmesDu9x HwMxE1eRZlSfIA9y
8XoFDevVDoOFcnQFIwsyIUvRE5uCJIdOHavHO4rhykoZ8GVtVbiuXPzd3wUF 4Z1xKcpdrV6JzXLx
Kk/b7E4T/tfJZqvR4QhjEy1+8kLMpDvMgQXMARiZk3EsshAL8x9bMg/3sB5/ BSX/8R9ziSKLyRLX
8SQHM98o8g1LcyM/cTFH8zVfcwzXMQBwbCCHThRnsna2bNx235PsUTaFWNDB X5gJLK+l2TyTUs2O
JFJiKrXWZ6zUH3Sy8j9ThZ/+bV65LxRuoGyVMlHkUTepQzlYAAtYwCSdEfE6 8RKjwiMXMQ0zMlc4
8g47MyFv9DNjtEZntCJvNEhD8kYp8zMLczQfMvRadEZzdFpYdCPbdMbKdE5P Mze7RQOb7iD+Xoke
hAkHFL4GLU6E1ViNlX7pczWCaD2jMlk+m8SKVtWJJUBj/nVAc3D/xCZLhnBt xm/rBpaJjWdh4WUQ
lABaB0FDOxZBYIxJz7Q0a3QwQ/M1y3RbzHVcOzFdx3Vec7NfAzZMc6wh7fBg B7OwcjRi2/Re/zVc
T0xdP29eS/ZNX/R6sG05iyF3mikDqrOa4gRuFdRu9VYwodOidN5gqit1odVx kauzRVim/ku8UZdq
qhx/HVhRTVpW67bsGjLfssEHD6t4jdSrxlpuXOSPpOdDB8Ec4Jd92RdhCITk TrZcd3NeV/Zdg/Mk
P/JNT/N197U0vzQTS1R1N29Nv3Uh4zQOfzMg24df0zF3H7JHI7J2F85MzzdP h4VPO7B2kqgEg9gV
H7UF/gsRic1lB/4Dio3VirUYir2zpE4oZT3dlt5ppwkmpOgYjpqc1AEYTqny bqdvkAYQ1BBL7v4f
Lf8DUbde7xaEBTy0CsQBcwNGg0L37MK1XVO3ffO1jdc1NAvrjn93XeM4Xi+y YbuFMhP2etz3Y8P0
Io83H5s3eOO3kOu0eOM1YkfxT4+e9XVnGXd2UHxbLQuaQBBaiv3AoSUaaEne rfZJj0XKvSyny8lK
1D2HdFLecfaomp2m53W4h5+vQItxqMhm9Bg00B5fQg9FHs3BLrNAEMSBBFgc lEY3kyfzTHv3HVP3
S9/xlHt3eMs0pgNyYHs6lYd3Sq73X383S3c3sVh6/qkzdnbzMaVH7pQDeZFb Nnfs9wMnEieLoycb
dYojNUOIG7npVoOP5VLVmK99aLFnqYNb6bAhu52X65yH6YTyebUf7FY3ky9K kZFi7a7LrIAjBAmY
gzWotaPmiRwDspBXNnUDuSNTeknL90czuUe/O5Rrt0nXeDeLdDbPe33De41f tDM37l1juiAn8kjf
+/JCc7u/N7Fc+X6nhgZdG5eXyB6tTTsbFLE73o9hx50SV4R76Zoh14NgKZ7r aWFae8rLUW9zVBvw
HzCO8XAzbXEDxcMtw0NDgGA8+rZEuhGDbfL+vHwUM6mLbXtrL9BjL9BH7/H6 8ZN7rdJjTAz/cEra
/vsl2/rKiiEqxEfqnimKK8Utf0wvBR4ujXIw5WRHhtyORdp0dRdsSx7IeWni Ydeba56YXR5rP9qO
Pmc8q3zfR7crcwlemUU4Z4xLxq/X8y5W6uvJ7HK/AsazJvHobpQheYXUMzbS G7xbUH4yF/bURz7U
V+7n+7CSN/Hoby4zs/y61/rVS9VbbDkHNi0aKh/n7Lnf234Umz7PAtB/wi8H GrpQ5FFvNL4BlOzJ
9jwe/y/3ov7yQr0xd601H7MP9/Aws3wSJ73yI7PnW38DlzMd9feZHqqH9bpT aHzj1P7to7+SYXvp
Ue22X63qefvQKj7REu/yMz30G/DkR7304/AQ/uc/QJgSKBDVwIIDTR1MiFAh QYcPGRqUGBHiQ4UX
Jy7MqHHhP48fQYYUOZKkSFP/TpqqlxJly4UuBpZ4w6akx3w1cebUWfPmTp8/ gQYVOpRoUaNHkSZV
upRpU6dPoUaVOpVqVatXSabMqLAEBTZtWKR6qMoFBa0ayQrEWSKoi54+2WKV OxdoPbl26WJNudIl
Sr5aWQhUxaINzZpup8b9iThvY8ePIUeWPJlyZcuXMWf2mbIhR7Je25RQhVBg V84SRZ9kKq8qAM2v
YcfWyXIvbZQJU5sq0abNWqqM4coWPpx4cePHkSdXLvvsQYxdv8Icy8Ls7Ydh VZdU7BP4zu0l/hGE
Dz8gwADxy9GnX0r7r8u/pqSTZWPYMWv19/Hn17+ff3//U0+D6CDq5gssItNQ agiV1Jp6iykEgkAh
wghMGEBCBPz5T8P8VLKtQ5cKMlC3mXDq7qnvdDJxwxVZbNHFF2GMMSvrOFKo rK9KEAutspoTTDrf
gFIRSJwQkFDCACqMEAGpXLMKgCaJgvIpKacEicqQrqTMw/Zo0200+ObDycHJ xtQpChnRTFPNNdls
E6oAN4KuDelIQ7BGL7NTqsykILzQBBFMCCCIJYvK0konkTIUy5IU/UfKJ618 EkpJXZPUUUhHehSn
RiHz0D2tUMFuRPpIEpIpFEstgYUSXFCV/tU9Q4ojijgyTI/Tmm6lLFc3ee3V 11+F6vFO6grLbaHB
qqMIuyG5g1U7nYoM4oIBTKg2ABQIFWnXnLY9qltGuTUUU5IenVTbcz1SVFNc M2PP0w5TSW2wwsSc
DFUWaq0pihLODHdcnSjt9ttFPxqX00YpxSrgRSst2NJNgY1Y4oljhBMj+Lxi g06uklWQQaacNeqA
kSM44M9qzWO03EqbZNlgS2GeFNOEtY2Z5XRnhtlRnFt+mGZywQW64HSJPhTd nYVueGdzi75sSw9N
Sas03nDCN7GdrEb6H1RD4oOFYVjgA+IogxrYaJyHZjdoralSN22tD6ZY7rnp xu+sO0vL/lhEg3i0
7iCpmd3J1GfdwpetwjMswIPFPYCg2j8JCGDTlotu2NzLK2f47aaVppzppa9U eunNCc50baRlpvxo
tz3nnPTJ3O3rw9JGk4/UkfKFTDEoB5e1hGHiAHvW3F+/tOd/N/f5YdJ9Trv5 oVVfnublXefZ4eNd
7zxn1SOF1GW4rR+d+rrJL998pxMkTSFki9VRIeosxrPBoW7Kt/5/FGd8cQIw 6B+DDPoHseiNjmiY
Qx3PREclA7Yue91LIPiEZroIHlBzq8OS92R2qHWh72kuiZqIZHI7kQxOKVwb YT4Wdrh8GO4jUdjX
MuIQw2Hwq1+le9sDS2dAtm3wgTok/mAPoZc85wXxhuCb2dlcxj3LFVGD3Dvf E6EYxbkI6zkU4A2d
HGKniSyrJiYsCQlH4kX86W9xEPhfBn6RAQCqLHPiI+IPC/hGBRKRgUYsog7d NsEcLkyDEmRbBYFY
vMjE7ml4ApMIQxIyuezuI/i6X0jkEIWvxcFrUfhB0jCos6YxkYA7dCADF7au JcaxgD8zXuoweEc5
fvKPmEPl9XAoRVnOkpbrSZ+ABHIjNhjrIH3jCG5GMz+m5E9/B8DAPNCYAV5I IFOijCMeKRjIaNKR
lHZsYDXzuMlsbrCNSAxa55jXLtlxKX10CmGJFIkUMTayVlASoz/A5rVhEO9s naye/jexWc/QUVCI
bsynuO4ZKWt2kputDOLnrvnHWi6UoQ0tyd0uZgoCgcV9A4Gf33ykli62JZ0h ESMxGXcACSiTF2lk
pg3bOErUaTJ6Nvtcwga4MtGdkqYQrNlLkWc0TZkSppmMoMG0Kc7ajBMwgiEM IkHSUaugCoz/2FcU
6JnDge4zodx8qSpvKM1YQhChWrXpQBuI0Kk6lKxlJSucBNSVYn3JIHZ6TjBB 5hQDFFOkvFCmMiEA
mVx9K26I0pVm3sUl2k2tNzXJWlTW6ZFWrWqxqopqrKKgh8c6MHxi3eH2FKg8 qx4xq+Gr6fhEub3r
wfKy2Dvl8bSnUJgK1Kytde0T/qkokRvNaSKfgahAuPisICn1I4k1wMgM4BEI qNGuGcjrYxCWU5Xd
ymyFmkxzrUJIokrNdjiZrGSuCxKo5gW6r/Xud8GbpvhdJ2MlWMWBOsaQjy2F t0YhAAQIcID3EiC8
Eetglwx5zsO0dyiJ9ehwultfAQ+YwOq5LUTkJKq/XbS2P9roboHi3wLTbajS /aCOXBAmnkyYwx32
8IcHecuMfAZHbI1JerMI1y/yV8IfaSqIJ2Zhv8TkS/pd8dVgnGMd79i7sc0i aDZGEF9uUSw4sY9U
jsxjCstuxrJDBZ2OGrinvBgkLVbylbGcZf+MVyMEYsPeLIpigqyXJFb+B5V7 /qvluVX4U9Yx0ILe
UNj6qJnOdbbzmg7MkdnmyCJa3JFG2TulgPHxzvu576fwlIooP1gqaPaImQsd aUlPWi5o/aWcsLgQ
Br81T2HkaIQBZqUIRSjA3LqKculSalMLcpPCYXOFo2bOOEOGv0MBQ3YpnWtd 73o2GB2WFXfJ1l4m
i8idRkqtd6LAUQe4r21zSjb9eCnKItB41Y52s5nD5Nl5UF4ZRmqap/JiVrmq sTqRAxguyd1Uz0XV
vHb3u5PC5WHPJ8h5Q+uCVFwq/h7WO6EumIQuEASAJsqvS0E1qrVpWaoqtJ+n y/a23XXh0pDoMUrl
t2LTCQYX3NpfAqtn8Qit/rYLKneOyZ4caAk6vmjDm+Ut30meOVYg0nyQ2H82 diKDguuhdG7UKFDX
yqQNupf5dOjUvun3RBuz0dZUjx/XZzdbHVCCgfOqriaqtvGdSw3fWCoXxx1j 3JmTP5QgGS5QBl6a
bvKxrRwo2Gb4ztdWdYe7nO51B4ml10esXVYUN2IuCJlH4nUp5wRxKmQhzgRO qcRPLqUEtaYTHe/N
mA7RoJZlNbSVyFmpAg2UnHw4OWcX65hQvCTIznm/m9Y7jStDDsrY+A/2lCXN lryUnF24tadnPdon
sbKYrVzSjy50rh7xe3Y3ft19vBC10jYiQ75OkUviD50f5ZH/qH66jCTw/v/1 D4AYEGDmvDpAmop1
gfmMpibfnn7MR32mnq/2y/rIag5evUvyWjTXESs4FCbM8P5QDBg0LhniQA7i IBlKAADpaeG2aqcO
yo+gqf2ex/GuypX0KQJVivyCrt2ObwN5TN5yqbyEDbfEDJhuDiQcbWs+bVN6 DgDOKI3WiFzE7wIf
75/CiZTqaPLMj+0uD5aQp/2kLv6kKf0w49UQbTBigmo2TDIYySMc6R+Ixx9+ AAxK4A9+wPXQDZOS
aAHjD3R+apV8kAZzEIjKpQb9ielWK+o4MA1zDebC7CsU7MSEBXCSUCo6CgAA bkkkII3sapmaSaee
yQvBb5X4CZwi7wa//sqGCgqfWg3yDtEPlQilXuPQaCPrUsHbqmb6isK/sibs cGLsPHGyGFARPYkC
LYgGAeoBsaoMHcag/nARBVENYXENRSytgM1YfMTv5MewMPHRUhBXVnCkeIEX kOmknG7ymOYMWyqT
cMp7ArHxxk/llg5uEM6JeI+0bOanjtHpYIMIQ09qRsW67GUkmkrjOE7kvEqI ym/zJPDtwi8VVWoL
w4oMtyoW6fHOkq8gZqvedKPmugz6SEL6qKIOA0YC9hCv9MrfCA4qNFApFrIq Zm4jTMEs8GRevo0X
w62jGquxBC8k9OAKO66ykkdnoKkCUev3qvEZ4Q/3nucaT4vaeka1/tAv6Opx JtXMAyWqvM5LIjZN
vfJNHFmsF31iuO7KuA5yuQyOSZ6rOEowJHgEPo5QzhpDqZLsI3TOH8pROBpy 7WhyK7my1yiCIxKM
7zAmDh2s9AJSKOZLvuCrKx/jbh5yHwfrkNBpKjZSt35iFyUjK0WOLfmyL0FE fQaCxELDxOxNxP6u
J0WiLssMKP1yOALEORwCfiRKR1hgDSrS+qgCLxtzMzkziu5xH6Ojthis2GrC /xgzJyCtMx1DWCai
K8RC1i7zBIUiNVWzNm0TWGzSy8Ds70Yw65piKhUS4W7TKe4NIWzLkCyR0aLi BGlzOJ3zOdODDT8Q
R/jOtnxNDu2y/llArWwGYRD0EjrvjkYiyjScErcsEzKAEzzVcz3FaxYvDcge 0q1QAzGpz0m68zvV
E+8CUzJzQyag0tMucjvZc0AJdDk+U+94ieYOLLcWE8J+osUMZhAIAT+FsCmE UwfzcioSURul4jNN
YzAwbOuikiquskBN9ESnyDAnQpf0UT7bij6NwvR8AgC801G6s0bJZi+REg3T jkdVq4mk55WORibN
8Bqh0ZN0FEBU9CGasj9JT9/oUufGjbFcxdw8ct2EIiuZDUW5tL6kEzS/bOae rOb+piwbdDF+ckbv
U0IlVPaSgkLVcdVqBgaH9AuBiv1Y60fjFBG1kiq+FH6ebCCS/tMsp2L6vG4c Nw7XTElOGU72jrRR
5U+PHBXlEuhRI7VLMZVX9NOoalEsdzLFlpIoZDTZ2LQ7a+DnuicDi5ToUsfo Rg7psEezlg7aIDEU
/RBJg4qf0NDymjGW4DQkNrXv4rIyY3NUUQ8132adxq7szi5J1c5ZedVNc7RP FZFXLzVTsVVNPNSK
mA81+HFA/PFMtfNBz2yFTBNxrKRUCQFHcSUG19EGXRED4TXyxopWizGUpAfq rIpzNE8UAWkQr1Up
DlQiYbNeJAPsXMxZ4mD1Wu/1Yq+ZSvLpcg9XW3WlYrX3ii73JpaykM55iM/a sjVk3cQmdS
Previous Topic:How to have multi line labels
Next Topic:Re: set return type of Operation
Current Time: Mon Jul 14 22:39:17 EDT 2025
Powered by FUDForum. Page generated in 0.05063 seconds
