Home » Modeling » OCL » VariableCS.initExpr = null when parsing a Tuplizing query
VariableCS.initExpr = null when parsing a Tuplizing query [message #68945] |
Mon, 16 March 2009 13:23  |
I'm somewhat of an OCL MDT novice, so please bear with me! I'm
attempting to write my first queries which return tuplized results.
First off, I can't seem to find any documentation on the proper way to
write these queries and have taken all of my guidance from the example
in the 'MDT OCL Goes Generic' eclipsecon presentation. Is there a more
elaborate primer on this topic?
My first observation is that I get a parse exception if I initialize the
Tuple with parentheses, it appears to want brackets (so Tuple{x : T, x2
:T2,...}, not Tuple(x : T, x2 :T2, ...)). Is this accurate?
My current problem is that I'm getting a NullPointer that appears to
boil down to my specification of the Tuple fields. The following is a
simplified query that is not parsing:
String queryString = "Set(Tuple{task : Task}) = " +
"let overrun : Set(Task) = " +
"self.tasks->select(t : Task | " +
"t.blownTask<>null) in " +
"overrun->collect(t | Tuple{" +
"task = t})";
The full query I'm trying to write is tuplizing three fields, but I've
tried to cut this one down as much as I can. As I said, I get a
NullPointer when parsing this query, and when I unwind the stack trace
in debug mode, the trouble seems to start at line 2855 of
AbstractOCLAnalyzer (src.zip for build 1.2.3).
At that point in the code, the parser is building instances of
TupleLiteralPart for each of the declared tuple fields. Each has three
parts - name, type and expr. In the debug console, 'name' is assigned
correctly ("task"), and so is 'type' (EClass for 'Task'), but 'expr' is
null because the object we're building from (an instance of VariableCS)
returns 'null' for getInitExpression().
So what am I doing wrong? Is there something else I am supposed to be
doing is the query to make sure that 'task' is initialized? Since it is
being assigned in the 'collect' clause, what would be the point?
Thank you for your assistance,
Daniel
Re: VariableCS.initExpr = null when parsing a Tuplizing query [message #68990 is a reply to message #68945] |
Thu, 19 March 2009 08:52   |
Originally posted by: give.a.damus.gmail.com
--=-24Ww0e0kYvaRNrW2HhbI
Content-Type: text/plain
Hi, Daniel,
See some replies in-line, below.
HTH,
Christian
On Mon, 2009-03-16 at 13:23 -0400, Daniel Tuohy wrote:
> Hello,
Do you mean, besides the OCL Specification? You might try the
introductory materials in the Open Model CourseWare project (OMCW) here
at Eclipse.
The parentheses are used in the identification of a tuple *type* just as
for collection types, e.g., Set(Employee) . The braces are used to
construct a tuple value just as for collections, e.g., Set{self,
self.manager} .
> "task = t})";
That should be:
String queryString = "Set(Tuple(task : Task)) = " +
"overrun->collect(t | Tuple{t})";
So, use parentheses in the tuple type reference and just fill in the
tuple parts in the literal expression. The tuple parts are ordered, so
the inferred type of the tuple literal in the collect expression is the
same type as declared in the element type of the set type. At least, I
think that should work ...
I suspect that what is happening, here, is that the parser is actually
processing the misplaced tuple literal in the Set type reference? Tuple
parts can have null values, and the 't' variable should be well-formed.
I suspect that it all stems from the parser getting confused by the
misplaced tuple literal in your set type, instead of a tuple type.
> Daniel
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
Hi, Daniel,<BR>
<BR>
See some replies in-line, below.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
Do you mean, besides the OCL Specification? You might try the introductory materials in the Open Model CourseWare project (OMCW) here at Eclipse.<BR>
<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
The parentheses are used in the identification of a tuple *type* just as for collection types, e.g., Set(Employee) . The braces are used to construct a tuple value just as for collections, e.g., Set{self, self.manager} .<BR>
<BR>
<BR>
<PRE>
"task = t})";
</PRE>
</BLOCKQUOTE>
<BR>
That should be:<BR>
<BR>
String queryString = "Set(Tuple(task : Task)) = " +<BR>
"let overrun : Set(Task) = " +<BR>
"self.tasks->select(t : Task | " +<BR>
"t.blownTask<>null) in " +<BR>
"overrun->collect(t | Tuple{t})";<BR>
<BR>
So, use parentheses in the tuple type reference and just fill in the tuple parts in the literal expression. The tuple parts are ordered, so the inferred type of the tuple literal in the collect expression is the same type as declared in the element type of the set type. At least, I think that should work ...<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
I suspect that what is happening, here, is that the parser is actually processing the misplaced tuple literal in the Set type reference? Tuple parts can have null values, and the 't' variable should be well-formed.<BR>
<BR>
<PRE>
</PRE>
</BLOCKQUOTE>
<BR>
I suspect that it all stems from the parser getting confused by the misplaced tuple literal in your set type, instead of a tuple type.<BR>
<BR>
<PRE>
Daniel
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-24Ww0e0kYvaRNrW2HhbI--
Re: VariableCS.initExpr = null when parsing a Tuplizing query [message #69014 is a reply to message #68990] |
Thu, 19 March 2009 14:28   |
Christian,
Thanks for your comments. Alas, I still can't seem to get a handle on
the exact syntax. The real break may be getting a simple example of a
well-formed query which returns a set of tuples, and then working from
there.
In thorough examination of both the OCL spec and your comments, I would
think that the following is well-formed:
String queryStr = "let tuplized : Set(Tuple(task : Task)) =
self.tasks->collect(t | Tuple{t}) in tuplized->asSet()"
Parsing this query generates a similar parse exception as described
previously (a NullPointer at OCLFactoryImpl:153 - when processing the
tuple specification).
However, my interpretation of the OCL Spec is that the correct syntax
would use the 'TupleType' keyword instead of the first occurrence of
'Tuple' in the above query. The parser seems to have other ideas,
returning org.eclipse.ocl.SyntaxException: 1:20:1:28 "Tuple" expected
instead of "TupleType".
What is the simplest query in EMF OCL that will return me a set of tuples?
Daniel
Christian W. Damus wrote:
> Hi, Daniel,
> HTH,
> Christian
>> Hello,
> at Eclipse.
> self.manager} .
>> "task = t})";
> That should be:
>> Daniel
Re: VariableCS.initExpr = null when parsing a Tuplizing query [message #69056 is a reply to message #69014] |
Thu, 19 March 2009 15:37   |
Christian,
I may have stumbled across the error. I'm posting the solution in case
it is useful to other readers, and because I am curious for you to
verify the rationale.
The query works if I add another field to the tuple, as in:
String queryString = "let tuplized : Set(Tuple(task : Task, cost :
Integer)) = self.tasks->collect(t | Tuple{cost = t.cost, task =
t})->asSet() in tuplized->asSet()";
I'm inclined to think that tuples are not well-formed unless they
specify at least 2 component parts, and that the parser just isn't
equipped to express that in an exception. Is that correct?
Daniel
Daniel Tuohy wrote:
> Christian,
> there.
> Daniel
>> Hi, Daniel,
>> HTH,
>> Christian
>>> Hello,
>>> to write these queries and have taken all of my guidance from the
>>> example in the 'MDT OCL Goes Generic' eclipsecon presentation. Is
>>> there a more elaborate primer on this topic?
>> here at Eclipse.
>>> the Tuple with parentheses, it appears to want brackets (so Tuple{x :
>>> T, x2 :T2,...}, not Tuple(x : T, x2 :T2, ...)). Is this accurate?
>> self.manager} .
>>> a simplified query that is not parsing:
>>> "task = t})";
>> That should be:
>>> I've tried to cut this one down as much as I can. As I said, I get a
>>> trace in debug mode, the trouble seems to start at line 2855 of
>>> three parts - name, type and expr. In the debug console, 'name' is
>>> assigned correctly ("task"), and so is 'type' (EClass for 'Task'),
>>> but 'expr' is null because the object we're building from (an
>>> instance of VariableCS) returns 'null' for getInitExpression().
>> well-formed.
>>> be doing is the query to make sure that 'task' is initialized? Since
>>> it is being assigned in the 'collect' clause, what would be the point?
>>> Daniel
Re: VariableCS.initExpr = null when parsing a Tuplizing query [message #69078 is a reply to message #69056] |
Thu, 19 March 2009 16:00   |
Hi again!
The problem is not that a tuple requires multiple components. My
current guess is that a Tuple must have at least one component that is a
primitive. My reason for suggesting this is:
- Tuple(x : Foo, y : Bar, z : Baz, p : Integer)
- Tuple(x : Foo, y : Bar, z : Baz, p : String)
- Tuple(p : String)
- Tuple(p : Integer)
....all parse correctly, however:
- Tuple(x : Foo, y : Bar, z : Baz)
- Tuple(x : Foo)
....cause a NullPointerException in the parser when processing the
variable specs.
It seems awfully silly, but is it possible that Tuples require a
primitive component?
Daniel
Daniel Tuohy wrote:
> Christian,
> Daniel
> Daniel Tuohy wrote:
>> Christian,
>> there.
>> would think that the following is well-formed:
>> tuples?
>> Thanks,
>> Daniel
>>> Hi, Daniel,
>>> HTH,
>>> Christian
>>>> Hello,
>>> here at Eclipse.
>>>> : T, x2 :T2,...}, not Tuple(x : T, x2 :T2, ...)). Is this accurate?
>>> self.manager} .
>>>> "task = t})";
>>> That should be:
>>>> a NullPointer when parsing this query, and when I unwind the stack
>>>> Since it is being assigned in the 'collect' clause, what would be
>>>> the point?
>>>> Daniel
Re: VariableCS.initExpr = null when parsing a Tuplizing query [message #69099 is a reply to message #69078] |
Thu, 19 March 2009 20:44  |
Hi, Daniel,
As far as I know, a TupleType needs not have any parts at all (though
such wouldn't be useful). Certainly, there is no restriction on the
types of the parts.
This definitely looks like a bug.
cW
Daniel Tuohy wrote:
> Hi again!
> - Tuple(p : String)
> - Tuple(x : Foo)
> variable specs.
> Daniel
> Daniel Tuohy wrote:
>> Christian,
>> case it is useful to other readers, and because I am curious for you
>> to verify the rationale.
>> Thanks,
>> Daniel
>> Daniel Tuohy wrote:
>>> Christian,
>>> on the exact syntax. The real break may be getting a simple example
>>> of a well-formed query which returns a set of tuples, and then
>>> working from there.
>>> tuples?
>>> Thanks,
>>> Daniel
>>>> Hi, Daniel,
>>>> HTH,
>>>> Christian
>>>>> Hello,
>>>> here at Eclipse.
>>>>> initialize the Tuple with parentheses, it appears to want brackets
>>>>> (so Tuple{x : T, x2 :T2,...}, not Tuple(x : T, x2 :T2, ...)). Is
>>>>> this accurate?
>>>>> to boil down to my specification of the Tuple fields. The
>>>>> following is a simplified query that is not parsing:
>>>>> "task = t})";
>>>> That should be:
>>>>> the point?
>>>>> Daniel
Current Time: Sun Aug 31 00:36:46 EDT 2025
Powered by FUDForum. Page generated in 0.26317 seconds
