Home » Archived » Visual Editor (VE) » JScrollBar not in 1.3?
JScrollBar not in 1.3? [message #68926] Sun, 24 October 2004 12:41 Go to next message
Originally posted by: cdouglas.nospam.oz.net
I just tried to set values in a scrollbar in a JScrollPane for the first
time in VE. It attempts to set them via JScrollPane.ScrollBar (with lots
of errors generated). My docs talk about JScrollBar as a separate class.
I take it this is something new since 1.3 (which VE supports)?
This sure made a mess. I can't even get rid of the errored code through
the visual editor.
Got an estimate on 1.4 support, yet?
Chas Douglass
Re: JScrollBar not in 1.3? [message #70397 is a reply to message #68926] Mon, 08 November 2004 14:22 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
It's not 1.3 versus 1.4. The problem is that the default scroll bar that
JScrollPane uses is a protected non-static inner class. The VE's problem
is that it doesn't work on what we call implicit values. An implicit
value happens when you try to set a property of a property and the
original property was not set but was queried. Currently what we do is
we try to instantiate a new copy of the implicit property and then set
the inner property on it. But since the class of the property setting is
a protected non-static inner class we can't generate any good code for
it. What we generate fails.
This is something we must address in the next release of VE, implicit
properties.
Rich Kulp
Re: JScrollBar not in 1.3? [message #70793 is a reply to message #70397] Tue, 09 November 2004 12:18 Go to previous messageGo to next message
> properties.
Are we talking about Bug 48552 here or something different?
Thanks in advance,
Dave
Dave Orme
Eclipse Visual Editor Project Lead
Advanced Systems Concepts' Chief Architect
http://www.swtworkbench.com http://essentialdata.sf.net
Re: JScrollBar not in 1.3? [message #70901 is a reply to message #70793] Tue, 09 November 2004 13:23 Go to previous message
Yeah, this is 48552.
Rich Kulp
Re: JScrollBar not in 1.3? [message #602735 is a reply to message #68926] Mon, 08 November 2004 14:22 Go to previous message
properties.
Rich Kulp
Re: JScrollBar not in 1.3? [message #602853 is a reply to message #70397] Tue, 09 November 2004 12:18 Go to previous message
> properties.
Thanks in advance,
Dave
Dave Orme
Re: JScrollBar not in 1.3? [message #602883 is a reply to message #70793] Tue, 09 November 2004 13:23 Go to previous message
Rich Kulp
Previous Topic:layout property not shown for Shell
Next Topic:Cannot use VE ...
Current Time: Thu Jul 17 04:25:19 EDT 2025
Powered by FUDForum. Page generated in 3.27410 seconds
