Home » Eclipse Projects » Mylyn » Bridge Tutorial
Bridge Tutorial [message #68914] Wed, 13 May 2009 04:37 Go to next message
Hi all,
Is there a tutorial available on how to create custom bridges? I want to
create a bridge for a UML modeling tool and do not really know how to
start.
Thank you so much for your help!
Re: Bridge Tutorial [message #68959 is a reply to message #68914] Wed, 13 May 2009 17:50 Go to previous messageGo to next message
Iris Groher wrote:
> Hi all,
> start.
I had the same issue when creating bridges for Mylyn WikiText. I found
that the best way to get started was by copying an example. Take a look
at the integrators reference
( http://wiki.eclipse.org/index.php/Mylyn/Integrator_Reference) which has
a small piece on bridges, and read over the javadoc for
AbstractContextStructureBridge and AbstractContextUiBridge. What I did
after that is copy an existing bridge and alter it to suit my needs.
David
Re: Bridge Tutorial [message #487947 is a reply to message #68959] Thu, 24 September 2009 20:25 Go to previous messageGo to next message
I too would like to create a bridge to my domain model but find the
documentation and javadocs a little slim so any help would be greatly
appreciated. I've read the integrator reference page and have some
questions.
Is it possible to use the JIRA connector, create a task and attach a
context built based on selection in my navigator view (or other selection
providers)?
I'd then like to retrieve that context, a simple set of object ids,
retrieve them with my org.eclipse.search extension to display a resultset
of those contextual items.
I do not want to use the Task-Focused UI aspects of Mylyn. If the
selected object is of my domain type I'd like it added to the context. Am
I correct in thinking the 'context' page of the JIRA task editor will
allow me to prune the list before attaching the context to the task? Am I
correct in thinking I therefore do not need to extend the
org.eclipse.mylyn.context.ui.bridges extension point?
I have extended org.eclipse.mylyn.context.core.bridges extension point,
providing a StructureBridge. Should the getContentType() return the
classname? The Java bridge just returns "Java".
To modify the context model, I see under "Processing Interaction" that I
need to extend AbstractUserInteractionMonitor. I've done so but my
constructor is not called so it doesn't get registered as a
SelectionListener and I never get to fire the InteractionEvents. From
where should the constructor get called? What am I doing wrong or missing
here?
Again, any help appreciated and I can provide more details if needed.
Craig
On Wed, 13 May 2009 14:50:11 -0700, David Green wrote:
> Iris Groher wrote:
>> Hi all,
>> to create a bridge for a UML modeling tool and do not really know how
>> to start.
> David
Re: Bridge Tutorial [message #488245 is a reply to message #487947] Sat, 26 September 2009 12:18 Go to previous message
Update: I found that the Java InteractionMonitor is constructed in its
Activator and registered with the MonitorUIPlugin. My InteractionMonitor
now receives selection events and calls super.handle() in which I call
MonitorUI.handleElementSelection(interactionEvent).
This results in "Invisible Elements" created in the "context" tab of the
JIRA task editor. I also see that the tree I'd like to populate in the
"Elements" section above is the "commonViewer" in ContextEditorFormPage.
Debugging I see commonViewer.setInput() received my workspace root,
presumably to share the same model as my selection providing navigator.
So far so good. What I'm missing now is the call to
ContextEditorFormPage.refresh() from its AbstractContextListener.
I see that the MonitorUI.notifyInteractionObserved() notifies each
registered IInteractionListeners's interactionObserved() method. Now I'm
lost again.
I can implement IInteractionListener and register it with MonitorUI as I
did the InteractionMonitor so it receives the InteractionEvent. But how
do I implement its interactionObserved() method such that it affects the
AbstractContextListener in ContextEditorFormPage which hopefully somehow
updates the commonViewer?
Someone must have worked with this API before. Am I on the right track?
Help! Help!
Craig
> questions.
> selection providers)?
> resultset of those contextual items.
> Am I correct in thinking the 'context' page of the JIRA task editor will
> I correct in thinking I therefore do not need to extend the
> missing here?
> Craig
>> Iris Groher wrote:
>>> Hi all,
>>> to start.
>> look at the integrators reference
>> has
>> Regards,
>> David
Re: Bridge Tutorial [message #597638 is a reply to message #68914] Wed, 13 May 2009 17:50 Go to previous message
Iris Groher wrote:
> Hi all,
> start.
David
Re: Bridge Tutorial [message #599224 is a reply to message #68959] Thu, 24 September 2009 20:25 Go to previous message
questions.
providers)?
here?
Craig
> Iris Groher wrote:
>> Hi all,
>> to start.
> David
Re: Bridge Tutorial [message #599229 is a reply to message #487947] Sat, 26 September 2009 12:18 Go to previous message
lost again.
Help! Help!
Craig
> questions.
> missing here?
> Craig
>> Iris Groher wrote:
>>> Hi all,
>>> to start.
>> has
>> Regards,
>> David
Previous Topic:Mylyn 3.0 connector tutorial
Next Topic:Prefilled texts for bugzilla
Current Time: Sun Aug 31 13:37:19 EDT 2025
Powered by FUDForum. Page generated in 0.07843 seconds
