Home » Language IDEs » PHP Development Tools (PDT) » Problem installing build I20080407
Problem installing build I20080407 [message #68910] Fri, 18 April 2008 04:48 Go to next message
Originally posted by: juice.hi.makni.htnet.hr
Hi!
I downloaded and installed Eclipse 3.4M5 and all prerequisites specified in:
http://download.eclipse.org/tools/pdt/downloads/release.php? release=I20080407
When I try to install I20080407 from the update site, I get the
following error message:
PDT Feature (1.0.2.v20080102-79-7GE7QYGHNGPGY) requires feature
"org.eclipse.wst (2.0.0)", or compatible.
The version of WST (actually WTP which includes WST) installed with the
prerquisites is S-3.0M5-20080218021547.
If I download the PDT zip archive and install it manually it works, but
whenever I try to install any other plugins (not related to PDT) using
their update sites, I get the above error message again.
If I disable PDT, the problem goes away. Does anybody know what to do to
fix this?
Vozdra! Ivan [Juice]
I am a marxist of the Groucho variety.
Re: Problem installing build I20080407 [message #69598 is a reply to message #68910] Tue, 29 April 2008 14:01 Go to previous message
Originally posted by: codeslave.ca.ibm.com
o.e.wst 2.0.0 is not considered "compatible" with the 3.0.0 version.
You need to either move up to a newer version of PDT (1.1) which
properly requires WTP 3.0, not 2.0, or go back to an older combination
(Eclipse 3.3 + WTP 2.0 + PDT 1.0).
Checking the source for o.e.php-feature/feature.xml in CVS, it looks
like this was fixed on 2008.04.08.08.40.16, but not yet tagged &
released in a build.
Nick
(Oh, I'm not a PDT developer, nor do I play one on TV.) :D
Juice wrote:
> Hi!
> in:
> fix this?
Previous Topic:Exclude files/directories from build
Next Topic:PDT dependecies
Current Time: Tue Jul 15 12:05:48 EDT 2025
Powered by FUDForum. Page generated in 0.07843 seconds
