Home » Archived » M2M (model-to-model transformation) » [QVT ] example problem
[QVT ] example problem [message #68895] Tue, 11 December 2007 12:38 Go to next message
I downloaded the QVT project m2m-qvto-SDK-incubation-1.0M1.zip and tried
to load the example and I get the Error
java.lang.NoClassDefFoundError: org/eclipse/ocl/cst/CSTNode
org.eclipse.m2m.qvt.oml.editor.ui.QvtConfiguration.getHyperl inkDetectors(QvtConfiguration.java:153)
org.eclipse.jface.text.source.SourceViewer.configure(SourceV iewer.java:391)
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:3201)
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:378)
org.eclipse.m2m.qvt.oml.editor.ui.QvtEditor.createPartContro l(QvtEditor.java:157)
Am I missing some required plugins and where do I get them.
Re: [QVT ] example problem [message #68956 is a reply to message #68895] Tue, 11 December 2007 13:41 Go to previous messageGo to next message
Hi, Gary,
It looks like you are missing the MDT OCL feature(s).
http://www.eclipse.org/modeling/mdt/downloads/?project=ocl
Christian
> at
> at
> at
> at
> at
> at
Re: [QVT ] example problem [message #68977 is a reply to message #68956] Tue, 11 December 2007 15:01 Go to previous messageGo to next message
Christian,
It looks the CSTNode class in this latest version of the ocl has been
repackaged in an internal package org\eclipse\ocl\internal\cst
The project still won't load.
Gary
Re: [QVT ] example problem [message #68997 is a reply to message #68977] Tue, 11 December 2007 15:44 Go to previous messageGo to next message
Hi, Gary,
The QVTo component is developing on the 1.2 release of MDT OCL, not the 1.1
release.
The 1.2 M3 build or a later integration build of OCL should work for you.
Christian
Gary Leask wrote:
> Christian,
> Gary
Re: [QVT ] example problem [message #69098 is a reply to message #68997] Wed, 12 December 2007 10:36 Go to previous messageGo to next message
Christian,
This is probably a stupid question but I'm using
Eclipse 3.3
EMF 2.3
UML 2.1
Do I need to move to the latest (i.e. Eclipse 3.4, EMF 2.4) to use OCL 1.2
or will it work with what I have?
Gary
Re: [QVT ] example problem [message #69140 is a reply to message #69098] Wed, 12 December 2007 11:19 Go to previous messageGo to next message
Hi, Gary,
OCL 1.2 requires EMF 2.4. It has a narrow (minor-version) dependency on EMF
because the OCL metamodel binding for Ecore extends the Ecore metamodel.
cW
Gary Leask wrote:
> Christian,
> Eclipse 3.3
> EMF 2.3
> UML 2.1
> Thanks
> Gary
Re: [QVT ] example problem [message #69180 is a reply to message #69098] Wed, 12 December 2007 13:04 Go to previous message
Hi Gary,
Download page of Operational QVT provides links to Eclipse, EMF and OCL
versions to be used against.
Eclipse build S-3.4M3
http://download.eclipse.org/eclipse/downloads/drops/S-3.4M3- 200711012000/index.php
EMF build 2.4.0M3
http://www.eclipse.org/downloads/download.php?file=/modeling /emf/emf/downloads/drops/2.4.0/S200711062140/emf-sdo-SDK-2.4 .0M3.zip
OCL build 2.2.0M3
http://www.eclipse.org/downloads/download.php?file=/modeling /mdt/uml2/downloads/drops/2.2.0/S200711121155/mdt-uml2-SDK-2 .2.0M3.zip
Sergey
Gary Leask wrote:
> Christian,
> This is probably a stupid question but I'm using Eclipse 3.3
> EMF 2.3
> UML 2.1
> Thanks
> Gary
Previous Topic:[ATL] Running an ANT file: File with following path:"..." does not exist in the workspace
Next Topic:[ATL] Refines
Current Time: Tue Jul 15 04:10:56 EDT 2025
Powered by FUDForum. Page generated in 0.08410 seconds
