Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo: indexed collections are not indexed in correct way with SessionController
Teneo: indexed collections are not indexed in correct way with SessionController [message #68871] Tue, 23 January 2007 03:39 Go to next message
I have such mapping:
<class entity-name="Funnel" abstract="false" lazy="false"
discriminator-value="Funnel" table="`funnel`">
<list name="event" fetch="subselect" lazy="true"
cascade="merge,persist,save-update,lock,refresh">
<key update="true">
<column name="`funnel_id`" not-null="true" unique="false"/>
</key>
<list-index column="`funnel_event_idx`"/>
<one-to-many entity-name="FunnelEvent"/>
</list>
</class>
When I do not use SessionController all is OK.
But when I use SessionController for HibernateResource funnel_event_idx
is always null when I create and add new event to funnel.
Any syuggestions?
Thanks.
Ilya
Re: Teneo: indexed collections are not indexed in correct way with SessionController [message #68892 is a reply to message #68871] Tue, 23 January 2007 04:09 Go to previous messageGo to next message
The session controller does not do much more then give access to a session so I am not sure how the
session controller can influence this.
So, I would need more information, can you debug some more? You can for example check which type the
delegate member in the PersistableEList instance has (of the event property).
gr. Martin
> <key update="true">
> </key>
> </list>
> </class>
> Any syuggestions?
> Thanks.
> Ilya
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: indexed collections are not indexed in correct way with SessionController [message #68912 is a reply to message #68892] Tue, 23 January 2007 05:13 Go to previous message
Hi Martin,
I resolved this problem. My sessionController had flushMode.MANUAL and
as far as I understand during save session was not flushed. I set
flushMode to COMMIT and now all is OK.
Ilya
> session so I am not sure how the session controller can influence this.
> example check which type the delegate member in the PersistableEList
> gr. Martin
>> <key update="true">
>> unique="false"/>
>> </key>
>> </list>
>> </class>
>> funnel_event_idx is always null when I create and add new event to
>> funnel.
>> Any syuggestions?
>> Thanks.
>> Ilya
Re: Teneo: indexed collections are not indexed in correct way with SessionController [message #601581 is a reply to message #68871] Tue, 23 January 2007 04:09 Go to previous message
gr. Martin
> <key update="true">
> </key>
> </list>
> </class>
> Any syuggestions?
> Thanks.
> Ilya
The Netherlands
Re: Teneo: indexed collections are not indexed in correct way with SessionController [message #601586 is a reply to message #68892] Tue, 23 January 2007 05:13 Go to previous message
Hi Martin,
Ilya
> gr. Martin
>> <key update="true">
>> unique="false"/>
>> </key>
>> </list>
>> </class>
>> funnel.
>> Any syuggestions?
>> Thanks.
>> Ilya
Previous Topic:Teneo: indexed collections are not indexed in correct way with SessionController
Next Topic:Teneo: <version type="dbtimestamp">
Current Time: Sat Jul 26 00:09:46 EDT 2025
Powered by FUDForum. Page generated in 0.06688 seconds
