Home » Archived » XML Schema Definition (XSD) » XSDParser Question :(
XSDParser Question :( [message #68718] Fri, 21 July 2006 22:40 Go to next message
Hi every one:
I got a question concerning parsing an xsd file with the XSDParser class of
org.eclipse.xsd.
I used the parse method to parse a file and got a XSDSchema, and from the
XSDSchema I got XSDElementDeclarations and XSDTypeDefinitions.
The question is : how can I get the exact content of an
XSDElementDeclarations ? Coz I need to display the tree structor of the
element in a GEF application, so I must get this information.
I know an Element could be got by calling getElement(), but that way I have
to deal with a XML Element, which could be difficult to use since what I
need is the structor of the XSD file.
Any suggestion would be thankful :)
Re: XSDParser Question :( [message #68750 is a reply to message #68718] Sat, 22 July 2006 08:12 Go to previous messageGo to next message
I would suggest looking at how the "XSD Editor" displays the tree
structure of a .xsd file in the outline view. WTP's XML Schema editor
displays the XSD model instances using GEF, so that's another thing that
might be useful. And finally, the GMF project lets you generate a
graphical editor from an Ecore model, so perhaps trying that with the
XSD model will generate something that's close to your needs.
ÕÅÏàì¶ wrote:
> Hi every one:
> org.eclipse.xsd.
Re: XSDParser Question :( [message #68771 is a reply to message #68750] Sat, 22 July 2006 11:55 Go to previous messageGo to next message
Thanks so much for your suggestion :)
But how can I get the source code of the "XSD Editor" and "WTP's XML Schema
Editor" you mentioned ?
Is it included in the CVS Repositoy of Eclipse ?
Thanks again in advance :)
"Ed Merks" <merks@ca.ibm.com> ???? news:e9t4m6$mn5$1@utils.eclipse.org...
Re: XSDParser Question :( [message #68791 is a reply to message #68771] Sun, 23 July 2006 08:35 Go to previous message
--------------030307020703020706090108
The source is packaged in the standard Eclipse way in the source plugin
that comes with our SDK zip download and can be accessed via CVS:
http://dev.eclipse.org/viewcvs/indextools.cgi/org.eclipse.xs d/plugins/
Re: XSDParser Question :( [message #598396 is a reply to message #68718] Sat, 22 July 2006 08:12 Go to previous message
ÕÅÏàì¶ wrote:
> Hi every one:
> org.eclipse.xsd.
Re: XSDParser Question :( [message #598403 is a reply to message #68750] Sat, 22 July 2006 11:55 Go to previous message
Re: XSDParser Question :( [message #598411 is a reply to message #68771] Sun, 23 July 2006 08:35 Go to previous message
Previous Topic:XSDParser Question :(
Next Topic:About org.eclipse.xsd.provider
Current Time: Sun Jul 27 02:51:32 EDT 2025
Powered by FUDForum. Page generated in 0.04146 seconds
