Eclipse Startup Problem [message #68708] |
Tue, 24 May 2005 10:55  |
Originally posted by: bora.abi.com.tr
I've downloaded the eclipse and unzipped when I try to lunch it stops after
the splash screen and the folloving log is created.
What to do?
Bora
SESSION May 24, 2005
17:40:31.32 ----------------------------------------------
eclipse.buildId=M200503110845
java.version=1.3.1_01
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=tr_TR
!ENTRY org.eclipse.osgi May 24, 2005 17:40:31.32
!MESSAGE Error registering XML parser services.
!STACK 0
java.lang.ClassNotFoundException: javax.xml.parsers.SAXParserFactory
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Unknown Source)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.registerEndo rsedXMLParser(EclipseAdaptor.java:272)
org.eclipse.core.runtime.adaptor.EclipseAdaptor.frameworkSta rt(EclipseAdaptor.java:253)
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.start(SystemBundleActivator.java:61)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:553)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:477)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:273)
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:243)
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:166)
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:425)
at org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:216)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!ENTRY org.eclipse.osgi May 24, 2005 17:40:31.452
!MESSAGE Startup error
!STACK 1
java.lang.NoClassDefFoundError: org/xml/sax/helpers/DefaultHandler
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginConverterImpl.java:557)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginConverterImpl.java:111)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginConverterImpl.java:660)
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseBundleData.java:233)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundleData.java:191)
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundleData.java:159)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseBundleData.java:280)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initializeNewBundle(DefaultBundleData.java:77)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(DefaultAdaptor.java:451)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:746)
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:664)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:715)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:659)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:219)
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:800)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:429)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:222)
!ENTRY org.eclipse.osgi May 24, 2005 17:40:31.462
!MESSAGE Bundle
initial@reference:file:f:/eclipse/plugins/org.eclipse.core.runtime_3.0.2/
[1] was not resolved.
FUDForum. Page generated in 0.08507 seconds
