Newbie Question about "Projects" [message #68704] |
Tue, 06 May 2003 07:46  |
Originally posted by: thomas.leglise.tradeware.be
Hi all,
I just started using Eclipse, migrating from Microsoft Visual Studio. I've
some troubles
understanding how the workspace concept is handled. In VS you can define a
project as a
collection of files and a workspace as a collection of projects, whatever
the relative location
of the projects and the files are. I don't see how to do that in eclipse.
I have the following setup: a first "collection" of projects
workspace/dev/Libs/Lib1 ->a first project
workspace/dev/Libs/Lib2 ->a second project
workspace/dev/Srv/Srv1 ->a third project
workspace/dev/Gtw/Gtw1 ->a fourth project
and a second collection of projects (which corresponds to a global branch
into my cvs)
workspace/v1.0/Libs/Lib1 ->a first project
workspace/v1.0/Libs/Lib2 ->a second project
workspace/v1.0/Srv/Srv1 ->a third project
workspace/v1.0/Gtw/Gtw1 ->a fourth project
How should I set up my file system (and perhaps my repository or module
definition) so it can
handle this?
Thanks a lot
Thomas
Re: Newbie Question about "Projects" [message #68958 is a reply to message #68894] |
Wed, 07 May 2003 04:04  |
I did some tests yesterday and came to the conclusion that eitheir each
"project" has to be checked-out in /workspace, without any directory
structure betweeen those, so they can be "seen" in eclipse as C/C++
projects. Of course this is easy to do with the CVS explorator embedded in
eclipse (which by the way does seem to beahve strangely with modules): just
"CheckOut as Project"
Eitheir you chekout the projects with the "structure", into a dummy project
that you convert to a C/C++ project afterwards: just "CheckOut Into". The
subfolders are not considered as indepedent projects but you can build them
separately if you have the makefiles and create for the binaries run
environements as well.
So with this setup I can more or less mimic VS. Now I wonder what's the
difference between the two, as in the first solution each project is a
C++project and in the second each project is a subfolder of a C++project.
So I suppose in the second case I "miss" something???
Thomas
bill wrote:
> I also want to KNOW:)
> It is a bit different with VS studio
> bill
> e-mail: billhao@hotmail.com
> MSN Messenger: billhao@hotmail.com
> Web: http://www.minivoice.com
> "Thomas L'Eglise" <thomas.leglise@tradeware.be> ????
> news:b987ab$1kr$1@rogue.oti.com...
>> Hi all,
>> I've some troubles
>> a project as a
>> into my cvs)
>> handle this?
>> Thanks a lot
>> Thomas
FUDForum. Page generated in 0.26480 seconds
