Difference between Bundles and Management Bundles [message #68699] |
Wed, 21 June 2006 05:46  |
Originally posted by: Hubert.Farnsworth.gmx.de
this question might have already appeared, but I found no matching thread.
What is the difference between a simple Bundle and a Management Bundle
and how can I create a Management Bundle?
Management Bundles occured several times in the OSGi-Specs (I need one
to access the PermissionAdmin-Service), but I never figured out how to
create one.
Thanks for answering,
Holger
PS: anyone knows a good OSGi-Tutorial or Wiki?
Re: Difference between Bundles and Management Bundles [message #70096 is a reply to message #69863] |
Mon, 17 July 2006 03:19  |
Thank you Tom,
the reason I was asking is that in several parts of the documentation
there are references to Management Bundles in the form of "only a
Management Bundle can do that...". Therefor I assumend that there should
be a little more about it.
Happy Day,
Holger
Tom Watson schrieb:
> Hi Holger,
> There is no fundamental difference between a management bundle and a
> simple bundle. Each can use the features provided by the framework
> (Import-Package, Export-Package, publish and use OSGi Services etc.).
> The reason the OSGi specification makes a distinction on a management
> bundle is because these types of bundles generally need a very high
> level of permissions (in most cases AllPermissions is needed) than
> normal bundles in order to perform operations that are considered to be
> management operations. Such as
> installing/starting/stopping/uninstalling bundles, using PermissonAdmin
> Service, using PackageAdmin service, etc.
> HTH
> Tom
FUDForum. Page generated in 0.06074 seconds
