Home » Archived » Test and Performance Tools Platform (TPTP) » Documentation about TPTP extensions points
Documentation about TPTP extensions points [message #68633] Wed, 26 April 2006 06:07 Go to next message
Hi all,
I was wondering if some documentation was available about TPTP plugins
extensions points because the only doc I found was in the EclipseCon 2005
tutorial (#6: Building a custom test execution environment). This tutorial
is great for beginning but a bit light in order to understanf all the TPTP
potential.
I'm really interrested in getting some more documentation about this,
even a "beta" one, as i have to go on my project using your marvellous but
not enough documented tool =)
Regards.
BQ.
Re: Documentation about TPTP extensions points [message #68653 is a reply to message #68633] Wed, 26 April 2006 09:19 Go to previous messageGo to next message
Hi Bertrand,
The first point of entry would be the extension point schemas. Each
schema should be documented with sufficient comments and example snippets
for implementation. Next, consult the TPTP product documentation (Help >>
Help Contents >> Testing automatically and manually). Finally, we are in
the process of converting our conference slides into tutorials (see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=111202). If you find these
sources unsatisfactory, please open a TPTP bugzilla for additional
documentation.
Paul
"Bertrand Quenin" <bquenin@axway.com> wrote in message
news:8eadb0eee04914fc6a519af31db9ac79$1@www.eclipse.org...
> Hi all,
> potential.
> Regards.
> BQ.
Re: Documentation about TPTP extensions points [message #70159 is a reply to message #68633] Tue, 09 May 2006 10:52 Go to previous messageGo to next message
Which parts of TPTP are you interested in (Platform, test, trace, monitor,
or all of the above)?
I have a user guide on how to extend the launch configuration in TPTP. It's
available under the documentation link from TPTP's homepage. The document
is titled: "Registering a Custom Data Collection Mechanism with TPTP's
Launch Configuration Framework". Here's an absolute path:
http://www.eclipse.org/tptp/home/documents/tutorials/datacol lection/launch-extensions/extending-launch-configuration.htm l
> Hi all,
> potential.
> Regards.
> BQ.
Re: Documentation about TPTP extensions points [message #73208 is a reply to message #70159] Mon, 05 June 2006 08:43 Go to previous messageGo to next message
I'm interesseted in org.eclipse.tptp.test.* extension points
documentation ...
BQ.
Re: Documentation about TPTP extensions points [message #73371 is a reply to message #73208] Tue, 06 June 2006 11:14 Go to previous message
Hi Bertrand,
TPTP extension points are documented in the SDK product docs:
Extending the monitoring, profiling, and testing functions >> Reference >>
Extension points
Alternativly, you may view the extension point documentation in each
extension point schema.
Paul
news:ab7d197030db9a0341da851b5dff1c51$1@www.eclipse.org...
> documentation ...
> Regards
> BQ.
Previous Topic:Snapshot/memory dump functionality in TPTP??
Next Topic:HTTP Proxy set and Secure Proxy not set error
Current Time: Sun Aug 31 17:16:44 EDT 2025
Powered by FUDForum. Page generated in 0.22035 seconds
