Home » Archived » BIRT » [Use case] Web Log Reports
[Use case] Web Log Reports [message #6104] Wed, 26 January 2005 13:05 Go to next message
Originally posted by: smesh.openrules.com
I did not found any convenient products for the *subj*. I has already
tried awstats <http://awstats.sourceforge.net/> and WebLog Expert
<http://www.weblogexpert.com/>.
They both lack sofisticated capabilities for querying/subquerying log
data. For example, I can view predefined page "Organizations
statistics". But from it I can not click on the Organization to go to
its Web page or to view detailed statistic for its logs. I'll not say
that there is no way to select subquery criteria (for example, clicking
on some Organizations) and view sub-report for it.
10x,
Sam Mesh
Re: [Use case] Web Log Reports [message #6148 is a reply to message #6104] Wed, 26 January 2005 14:21 Go to previous messageGo to next message
Sam,
Web logs seem like a great use case for BIRT. BIRT's data engine provides
powerful tools for filtering, sorting & grouping data. Someone will need to
create a data adapter to parse a web log into a format that BIRT can
understand, but this should be a straightforward use of BIRT's comprehensive
extension framework. Perhaps there is an open source JDBC driver that
already exists?
You mentioned subqueries; which appear to be "drill-down" links in BIRT
terminology. You should be able to create reports that present summary data,
then provide drill-down links to reports that present specific data in
greater detail.
Once BIRT is available for use, this would be wonderful use case to try for
someone in the BIRT community who is familiar with web logs and their
reporting needs.
- Paul
Paul Rogers
BIRT PMC
"Sam Mesh" <smesh@openrules.com> wrote in message
news:ct8m55$ejl$1@www.eclipse.org...
>I did not found any convenient products for the *subj*. I has already tried
> data. For example, I can view predefined page "Organizations statistics".
> But from it I can not click on the Organization to go to its Web page or
> to view detailed statistic for its logs. I'll not say that there is no way
> to select subquery criteria (for example, clicking on some Organizations)
> 10x,
> Sam Mesh
Re: [Use case] Web Log Reports [message #6163 is a reply to message #6148] Wed, 26 January 2005 16:34 Go to previous messageGo to next message
Paul,
Thanks for giving me hope with Web Log Reports.
What kind of the model/meta model has to be provided?
Here is my 'knowledge' about Web logging:
- logs can be accumulated from Apache Web Server
- log format is publicly available
- logs contain IPs or DNS names
- other IP-based information can be obtained via databases/web services
- all this stuff is public and free (except Organization database:)
10x,
Sam Mesh
> already exists?
> greater detail.
> reporting needs.
Re: [Use case] Web Log Reports [message #6177 is a reply to message #6148] Fri, 28 January 2005 13:01 Go to previous messageGo to next message
You might want to look at Hyades. I think they've already done a lot
of work with the Common Base Event and viewing (mining) web logs.
Bryan
On 2005-01-26 13:21:49 -0600, "Paul Rogers" <progers@actuate.com> said:
> Sam,
> provides powerful tools for filtering, sorting & grouping data. Someone
> will need to create a data adapter to parse a web log into a format
> that BIRT can understand, but this should be a straightforward use of
> BIRT's comprehensive extension framework. Perhaps there is an open
> source JDBC driver that already exists?
> data, then provide drill-down links to reports that present specific
> data in greater detail.
> for someone in the BIRT community who is familiar with web logs and
> their reporting needs.
> - Paul
> Paul Rogers
> BIRT PMC
>> 10x,
>> Sam Mesh
Re: [Use case] Web Log Reports [message #6287 is a reply to message #6163] Wed, 02 February 2005 16:44 Go to previous message
Hi Sam,
For the BIRT extension to data access, the Data Engine component has implemented
an Open Data Access (ODA) extension framework. It provides the capability to plug
in any external data source, such as the Web logs and other application data
sources, to the BIRT reporting engine.
BIRT ODA extension defines a set of public interfaces. It adopts the Eclipse
plug-in framework for one to provide a designer tool, and a runtime driver for
data retrieval during report generation. The BIRT community is encouraged to
adopt the ODA extension framework for its specific types of data sources.
We will be publishing detail spec on the ROM Data model and the ODA interfaces
shortly.
In brief, the Eclipse plug-in for BIRT data extension allows one to provide a
designer GUI tool specific to an external data source. The plug-in designer tool
would then use BIRT public API to specify the data set and data source
definitions, which will be saved in the report design file. BIRT Data Engine
would then use such data definition in the report design, and access a data
extension's ODA runtime driver for query execution and data retrieval.
The ODA runtime interfaces are JDBC-like, but has been extended to support
additional capabilities of non-RDBMS data sources. An ODA driver would basically
implement the public runtime interfaces, which would in turn wrap data source
specific APIs, such as web services, etc. to retrieve data rows.
For a preview, the ODA runtime interfaces source are available in the Eclipse CVS
source code repository, in the org.eclipse.birt.data.oda package under the
org.eclipse.birt.data sub project.
Linda
BIRT Data Engine lead
Sam Mesh wrote:
> Paul,
> 10x,
> Sam Mesh
> > already exists?
> > greater detail.
> > reporting needs.
Previous Topic:Any concerns with XSL:FO performance/scalability?
Next Topic:Eclipse Report Engine (ERE) deployment options ?
Current Time: Mon Sep 01 01:16:41 EDT 2025
Powered by FUDForum. Page generated in 0.04925 seconds
