Home » Archived » XML Schema Definition (XSD) » XSD features restricting base class
XSD features restricting base class [message #68570] |
Mon, 10 July 2006 07:30  |
Originally posted by: kannan.ekanath.gmail.com
--------------090105070109080301040308
Hi Group,
I have an xsd where i want to extend an element type but also control
the parent types data. Let us take a simple library example,
We have types Book and Writer (A book has many "authors" and a writer
has "books"). Now there are subclasses for Book like FunBook, TechBook
and Author has subclasses like FreelanceWriter, SeriousWriter etc. (OO
purists please excuse the usage of inheritance paradigm here :)
Now, i want to impose some restrictions on SeriousWriter. For example,
although he can write many types of books, i want to enforce that "He
cannot write FunBooks". Similarly a Techbook not being able to authored
by a "FunWriter" etc.
Can someone tell me if this can be possible in XSD? I am not able to get
the <xsd:restriction> element to work here. The constraint here being
that i want the "authors" and "books" relation *only* in the base class?
I have also attached the sample xsd.
Kannan
Content-Type: text/xml;
name="book.xsd"
Content-Disposition: inline;
filename="book.xsd"
<xsd:schema xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:element name="Library">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="library" type="LibraryType" minOccurs="0" maxOccurs="unbounded"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:complexType name="LibraryType">
<xsd:sequence>
<xsd:element name="book" type="Book" minOccurs="0" maxOccurs="unbounded"/>
<xsd:element name="writer" type="Writer" minOccurs="0" maxOccurs="unbounded"/>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="Book">
<xsd:sequence>
<xsd:element name="bookName" type="xsd:string" minOccurs="1" maxOccurs="1"/>
<xsd:element name="authors" ecore:reference="Writer" ecore:opposite="books" minOccurs="0" maxOccurs="unbounded" type="xsd:anyURI"/>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="Writer">
<xsd:sequence>
<xsd:element name="writerName" type="xsd:string" minOccurs="0" maxOccurs="unbounded"/>
<xsd:element name="books" ecore:reference="Book" ecore:opposite="authors" minOccurs="0" maxOccurs="unbounded" type="xsd:anyURI"/>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="FinanceBook">
<xsd:complexContent>
<xsd:extension base="Book">
<xsd:sequence>
<xsd:element name="financeSubjectName" type="xsd:string"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:complexType name="FunBook">
<xsd:sequence>
<xsd:element name="funSubjectName" type="xsd:string"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
<xsd:complexType name="FunWriter">
<xsd:extension base="Writer">
<xsd:sequence>
<xsd:element name="writerStyle" type="xsd:string"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
<xsd:complexType name="SeriousWriter">
<xsd:sequence>
<xsd:element name="seriousnessLevel" type="xsd:string"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
</xsd:schema>
--------------090105070109080301040308--
Re: XSD features restricting base class [message #68580 is a reply to message #68570] |
Mon, 10 July 2006 08:50  |
--------------050907060407030706050504
Kannan,
You can't write a constraint that disallows only certain subclasses that
would otherwise be valid. In fact, you should note that XML Schema
itself doesn't even allow you to constrain which type of object may be
referenced by an IDREF or an anyURI.
Kannan Ekanath wrote:
> Hi Group,
> authored by a "FunWriter" etc.
> get the <xsd:restriction> element to work here. The constraint here
> being that i want the "authors" and "books" relation *only* in the
> base class? I have also attached the sample xsd.
> Kannan
><?xml version="1.0" encoding="UTF-8"?>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
></xsd:schema>
<html>
<head>
</head>
Kannan,<br>
<br>
that would otherwise be valid. In fact, you should note that XML
Schema itself doesn't even allow you to constrain which type of object
may be referenced by an IDREF or an anyURI.<br>
<br>
<br>
<blockquote cite="mide8tdkg$g80$1@utils.eclipse.org" type="cite">Hi
Group,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
here being that i want the "authors" and "books" relation *only* in the
<br>
<br>
<br>
Kannan
<br>
<pre wrap="">
<hr size="4" width="90%">
<xsd:schema xmlns:ecore=<a class="moz-txt-link-rfc2396E" href="http://www.eclipse.org/emf/2002/Ecore">"http://www.eclipse.org/emf/2002/Ecore"</a> xmlns:xsd=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>>
<xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
</xsd:schema>
</pre>
</blockquote>
<br>
</body>
</html>
--------------050907060407030706050504--
Re: XSD features restricting base class [message #598342 is a reply to message #68570] |
Kannan,
> Hi Group,
> Kannan
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:extension>
> </xsd:complexType>
></xsd:schema>
<html>
<head>
</head>
Kannan,<br>
<br>
<br>
<br>
Group,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Kannan
<br>
<pre wrap="">
<xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
<xsd:sequence>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
</xsd:schema>
</pre>
</blockquote>
<br>
</body>
</html>
Current Time: Wed Jul 16 15:23:38 EDT 2025
Powered by FUDForum. Page generated in 0.04498 seconds
