Home » Archived » M2M (model-to-model transformation) » [ATL] How can generate the xmi model editor from a metamodel?
[ATL] How can generate the xmi model editor from a metamodel? [message #68567] Mon, 10 December 2007 13:05 Go to next message
I have finished a metamodel. I wanna edit the model of this metamodel. I
like to use the xmi editor generated from the metamodel. But I don't know
how to generate the edito. Does anybody has an idea? Thanks
Micahel.
Re: [ATL] How can generate the xmi model editor from a metamodel? [message #68610 is a reply to message #68567] Tue, 11 December 2007 03:38 Go to previous messageGo to next message
--------------050708090909050103090500
Michael a
Re: [ATL] How can generate the xmi model editor from a metamodel? [message #68856 is a reply to message #68610] Tue, 11 December 2007 11:23 Go to previous message
Note that EMF provides a reflective editor that does not require
generating code. Unless you want to generate code, there may not be any
reason to do so.
Frédéric Jouault
William Piers wrote:
> Hello,
> Michael a écrit :
>> metamodel. I like to use the xmi editor generated from the metamodel.
>> But I don't know how to generate the edito. Does anybody has an idea?
>> Thanks
>> Micahel.
> The problems you encounter are EMF related more than ATL. You would have
> better answers on the EMF newsgroup.
> To generate an editor from a metamodel, here is a link to an EMF tutorial :
> http://www.eclipse.org/articles/Article-Using%20EMF/using-em f.html
> Best regards,
> William
Previous Topic:[ATL] Problem occurs when I launch an execution.
Next Topic:[ATL]A strange problem
Current Time: Mon Jul 21 22:05:43 EDT 2025
Powered by FUDForum. Page generated in 0.08100 seconds
