Home » Archived » XML Schema Definition (XSD) » DocumentRoot
DocumentRoot [message #68552] Thu, 06 July 2006 15:13 Go to next message
Originally posted by: gui.le.conquerant.com
Hiya group,
I am using XSD along with EMF to generate a java-based model, latekly
used in a GEF-based tool.
Is there a way to tell, in the XML Schema, which element is the document
root? What I need, is to make an 'existing' element the document root.
"ecore:documentRoot" seems to be the solution except that it creates an
extra class in the model. I have tried to make ecore:documentRoot point
to an exising xsd element, but a new class gets generated as well.
Thanks in advance,
Gui
Re: DocumentRoot [message #68562 is a reply to message #68552] Thu, 06 July 2006 16:08 Go to previous message
Gui,
All global elements are mapped to features of the special document root
EClass and any such global element can be the root of an XML instance.
The ecore:documentRoot annotation only lets you specify a name other
than "DocumentRoot" for this special EClass. For a serialization to
conform to a schema, the DocumentRoot instance with an appropriate
element-derived feature set must be at the root of the resource. So if
your model allows only a single thing to be a root, you should have a
single element of that type...
Gui wrote:
> Hiya group,
> document root? What I need, is to make an 'existing' element the
> document root.
> an extra class in the model. I have tried to make ecore:documentRoot
> point to an exising xsd element, but a new class gets generated as well.
> Thanks in advance,
> Gui
Re: DocumentRoot [message #598327 is a reply to message #68552] Thu, 06 July 2006 16:08 Go to previous message
Gui,
Gui wrote:
> Hiya group,
> document root.
> Thanks in advance,
> Gui
Previous Topic:DocumentRoot
Next Topic:XSD features restricting base class
Current Time: Fri Nov 21 04:52:56 EST 2025
Powered by FUDForum. Page generated in 0.04905 seconds
