Home » Modeling » GMF (Graphical Modeling Framework) » Helpers Generation
Helpers Generation [message #68505] Tue, 24 October 2006 09:04 Go to next message
Originally posted by: greenl.mot.com
I noticed the diagram project generator will generate two kinds of classes
in helpers package:
1. XXXEditHelper
2. XXXEditHelperAdvice
My two concern to the generation (My version is M-02):
First, For XXXEditHelper, all concrete Helper classes will extends from a
YYYBaseEditHelper (where YYY is the root element name). But
XXXEditHelperAdvice classes does not have a project level base class to
extend, instead they extends directly from AbstractEditHelperAdvice defined
in the gmf runtime, I wonder why it makes this kind of differences? Why not
give a project level base for the EditHelperAdvice classes?
Second, I am expecting the generator be more intelligent to notice my class
hierarchies defined in the ecore model, say I have class A, A1, A2 defined
in my ecore model, with A1 extends A and A2 extends A as well. I hope there
following help classes generated in the helpers package:
1. MyModelBaseEditHelper extends AbstractEditHelper
2. MyModelBaseEditHelperAdvice extends AbstractEditHelperAdvice
3. AEditHelper extends MyModelBaseEditHelper
4. A1EditHelper extends AEditHelper
5. A2EditHelper extends AEditHelper
6. AEditHelperAdvice extends MyModelBaseEditHelperAdvice
7. A1EditHelperAdvice extends AEditHelperAdvice
8. A2EditHelperAdvice extends AEditHelperAdvice
As a comparison, the current GMF generator generates the following classes
2. <-- missed MyModelBaseEditHelperAdvice -->
4. A1EditHelper extends MyModelBaseEditHelper
5. A2EditHelper extends MyModelBaseEditHelper
6. AEditHelperAdvice extends AbstractEditHelperAdvice
7. A1EditHelperAdvice extends AbstractEditHelperAdvice
8. A2EditHelperAdvice extends AbstractEditHelperAdvice
I don't know if I missed some important concepts or should I submit a bug
for future enhancement. I am all my ear to you gurus's opinion on this
point.
Green
Re: Helpers Generation [message #68751 is a reply to message #68505] Tue, 24 October 2006 18:04 Go to previous messageGo to next message
Hi Green,
Yes, from a manual customization point of view it's most convenient if
the edit helper hierarchy mirrors the hierarchy in your ecore model so
that you can inherit common behaviours. I suppose that for generated
code it isn't as important (the same behaviour can be generated into
each edit helper).
Having a XXXBaseEditHelperAdvice might be nice, too, in case your
application has common behaviour for its advice.
I'd say an enhancement request would be in order, but maybe there are
considerations in the generator that I'm not aware of?
Linda
> in helpers package:
> 1. XXXEditHelper
> point.
> Green
Re: Helpers Generation [message #70747 is a reply to message #68751] Fri, 27 October 2006 08:14 Go to previous message
>> class hierarchies defined in the ecore model, say I have class A, A1, A2
>> defined in my ecore model, with A1 extends A and A2 extends A as well. I
>> hope there
Generally, one can't assume such reuse will happen, and introducing any
heuristics here just complicates matter. However, GMF is *tool for
toolsmith* and you are supposed to modify it to fit your needs - add your
templates/logic to detect duplications/abstract superclasses and generate
the code you like most ;). And file bugs to let us know we can improve
pieces to ease customization step for you
Artem
"Linda Damus" <ldamus@ca.ibm.com> wrote in message
news:ehm2la$ipf$1@utils.eclipse.org...
> Hi Green,
> Yes, from a manual customization point of view it's most convenient if the
> edit helper hierarchy mirrors the hierarchy in your ecore model so that
> you can inherit common behaviours. I suppose that for generated code it
> isn't as important (the same behaviour can be generated into each edit
> helper).
> Linda
>> classes in helpers package:
>> 1. XXXEditHelper
>> defined in the gmf runtime, I wonder why it makes this kind of
>> differences? Why not give a project level base for the EditHelperAdvice
>> classes?
>> hope there following help classes generated in the helpers package:
>> classes
>> point.
>> Thanks,
>> Green
Previous Topic:updating diagram when automatically removing transient children
Next Topic:Code for Outline
Current Time: Sat Jul 26 17:54:43 EDT 2025
Powered by FUDForum. Page generated in 0.03159 seconds
