Home » Modeling » OCL » Pre-compiled OCL expressions?
Pre-compiled OCL expressions? [message #68484] |
Fri, 06 March 2009 01:40  |
Originally posted by: zzhangh.cn.ibm.com
Hi all,
I got a set of OCL expressions, and had to evaluate them with thousands of objects. I'm wondering if the OCL expressions
can be pre-compiled (or any other related mechanism) to improve the performance, thanks!
Hao
Re: Pre-compiled OCL expressions? [message #68518 is a reply to message #68484] |
Fri, 06 March 2009 09:09   |
Originally posted by: cdamus.zeligsoft.com
Hi, Hao,
Yes, that's precisely what you get when you parse the expression: a
compiled form of it. Are you parsing every time you need to evaluate
the OCL expression? You can parse the expression, encapsulate it in a
Query (OCL::createQuery(...) method), and feed all of your objects into
that query one by one. Or, even, send them all in as a list and let the
query return the corresponding list of results. This has the benefit of
caching, for example, the class extents for allInstances() operation
between evaluations.
Otherwise, you'd be looking at some kind of OCL-to-Java compiler such as
was prototyped in the defunct OCLTools component. You may still find
links to some of that code from the Eclipse Wiki. Note, though, that
Miguel's initial trials showed only a 2-fold performance increase in the
compiled-to-Java OCL over the interpreted OCL. For many applications,
that wouldn't be a determining factor.
HTH,
Christian
Hao Zhang wrote:
> Hi all,
> Hao
Re: Pre-compiled OCL expressions? [message #68571 is a reply to message #68518] |
Sun, 08 March 2009 23:38   |
Hi Christian,
Sounds interesting, I'll give it a try. One more question:
Can these query objects be persisted, so that potentially I can have them back more quickly the next time I run my program.
Hao
Christian W. Damus Wrote:
> Hi, Hao,
> HTH,
> Christian
> Hao Zhang wrote:
>> Hi all,
>> Regards,
>> Hao
Re: Pre-compiled OCL expressions? [message #68608 is a reply to message #68571] |
Wed, 11 March 2009 09:25  |
Hi, Hao,
No, the Query cannot be persisted, but the expression that it evaluates
can. Persistence of the EvaluationEnvironment encapsulated by the Query
doesn't make sense, as it includes caches of the current model state,
which quickly become stale.
The cost of creating new Query instances is quite small compared to parsing.
Christian
Hao Zhang wrote:
> Hi Christian,
> Hao
>> Hi, Hao,
>> into that query one by one. Or, even, send them all in as a list and
>> let the query return the corresponding list of results. This has the
>> benefit of caching, for example, the class extents for allInstances()
>> operation between evaluations.
>> as was prototyped in the defunct OCLTools component. You may still
>> find links to some of that code from the Eclipse Wiki. Note, though,
>> that Miguel's initial trials showed only a 2-fold performance increase
>> in the compiled-to-Java OCL over the interpreted OCL. For many
>> applications, that wouldn't be a determining factor.
>> HTH,
>> Christian
>> Hao Zhang wrote:
>>> Hi all,
>>> Regards,
>>> Hao
Current Time: Sat May 10 16:11:43 EDT 2025
Powered by FUDForum. Page generated in 0.03686 seconds
