Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Live Validation after saving the model
Live Validation after saving the model [message #68476] Sun, 21 January 2007 08:47 Go to next message
Originally posted by: S.Kemmann.herr-der-mails.de
If I'm opening an existing (saved) .extlibrary-file with a library without
the "Name"-property set, the Live-Validation isn't working!? If I add
another Library to the resource and edit the name (but leaf it blank -
invalid) the live-validation message pops-up ... as said before ... doing
the same thind on a saved library-object, nothing happens!?
Is that a bug, or is the problem located between my PC and my chair!?
Thanx!
Soeren
Re: Live Validation after saving the model [message #68733 is a reply to message #68476] Mon, 22 January 2007 17:12 Go to previous message
Hi, Soeren,
Live validation isn't performed on loading the contents of a resource,
because this isn't considered to be "changing" the data. You could,
however, implement a project builder that performs batch validation on a
resource when it is saved (batch validation also includes live constraints,
by default). This builder could produce problem markers (using the
Validation API's MarkerUtil) that persist in the workspace, so that they
will be there whenever the resource is opened.
Of course, such a builder would need to know how to find the in-memory copy
of your resource if it is already open, to avoid loading a duplicate ...
Christian
Soeren Kemmann wrote:
> Thanx!
> Soeren
Re: Live Validation after saving the model [message #601537 is a reply to message #68476] Mon, 22 January 2007 17:12 Go to previous message
Hi, Soeren,
Christian
> Thanx!
> Soeren
Previous Topic:Live Validation not working!?
Next Topic:Problem with Interactive OCL Console used with Sample Ecore Editor
Current Time: Tue Jul 22 02:27:45 EDT 2025
Powered by FUDForum. Page generated in 0.07441 seconds
