Home » Archived » M2M (model-to-model transformation) » [ATL] AtlLauncher launch method parameter
[ATL] AtlLauncher launch method parameter [message #68470] Mon, 10 December 2007 05:30 Go to next message
Originally posted by: valerio.summo.gmail.com
Hi all,
I'm trying to develop a Java Launcher for an ATL transformation from UML2 to
OWL, but I have some problems in the runATLTransformation, in the following
codeline:
AtlLauncher.getDefault().launch(transformation, libs, models, params);
The method launch(...) seems to have one more argument:
- launch (URL asmurl, Map libraries, Map models, Map asmParams, List
superimpose)
instead of:
- launch (URL asmurl, Map libraries, Map models, Map asmParams)
And so I have tried to put null as last argument.
Furthermore, when I run the code, I get the following WARNING and Exception:
Dec 10, 2007 10:32:01 AM org.eclipse.m2m.atl.engine.vm.ASMExecEnv
parseTypeInternal
WARNING: could not find model UML.
parseTypeInternal
parseTypeInternal
Dec 10, 2007 10:32:01 AM org.eclipse.m2m.atl.engine.AtlLauncher launch
SEVERE: null
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:144)
Is the last argument that causes these problems or something else?
Thank you in advance,
Valerio
Re: [ATL] AtlLauncher launch method parameter [message #68486 is a reply to message #68470] Mon, 10 December 2007 05:54 Go to previous message
Solved :)
the problem was in the first argument in loading the UML metamodel.
My erroneous code was:
emfamh.loadModel("uml"
The correct one, case sensitive, is:
emfamh.loadModel("UML"
"Valerio Summo" <valerio.summo@gmail.com> wrote in message
news:fjj4eg$vla$1@build.eclipse.org...
> Hi all,
> to
> following codeline:
> superimpose)
> instead of:
> Exception:
> parseTypeInternal
> parseTypeInternal
> parseTypeInternal
> SEVERE: null
> java.lang.NullPointerException
> Valerio
Previous Topic:ATL transformation from UML2 to OWL
Next Topic:[ATL] How can I generate a KM3 metamodel from Ecore metamodel?
Current Time: Wed Jul 02 14:01:01 EDT 2025
Powered by FUDForum. Page generated in 0.03896 seconds
