IDE is slower? [message #68419] |
Mon, 09 June 2003 17:32  |
Originally posted by: song.chen.cloakware.com
I am a beginner for eclipse. Does anyone have a idea why eclipse is so
slower than other IDE, for example, Jbuilder?
Appreciate any comments.
CS
Re: IDE is slower? [message #72986 is a reply to message #72293] |
Thu, 12 June 2003 21:43  |
Originally posted by: substring0NOSPAM.hotmail.com
5000 Java files are too much. You should break them down into packages or
projects with smaller numbers of files. Do not load them if you are not
using them. Quite frankly, I can't see how you can use 5000 files all at
one time.
You see, I never turn off my computers and I rarely close the Eclipse IDE.
Meanwhile, I have JBoss, Tomcat, Oracle9i, SQL Server, Outlook, and several
other applications running concurrently at all time. And I never have any
problem with performance. Maybe the 1G memory helps. Nevertheless, try
reorganize your files, load only those you need, and it should resolve your
problem.
Hope this helps.
simon.
FUDForum. Page generated in 0.32570 seconds
