Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo newbi, problems getting started
Re: Teneo newbi, problems getting started [message #68429 is a reply to message #68416] |
Sat, 20 January 2007 05:41 |
It can't find/set a unique name for the eclass references by a many-ereference. Can you debug to
that line and check why the compare to is on null and for which ereference/eclass it goes wrong?
If you see nothing strange can you then send me the ecore model?
gr. Martin
mark wrote:
> I have the following code section in the start() method of my plugin:
> final Properties props = new Properties();
> props.setProperty(Environment.DRIVER, "com.mysql.jdbc.Driver");
> props.setProperty(Environment.USER, "geib");
> props.setProperty(Environment.URL,
> "jdbc:mysql://200.50.32.186:3306/srdV3");
> props.setProperty(Environment.PASS, "");
> props.setProperty(Environment.DIALECT,
> org.hibernate.dialect.MySQL5InnoDBDialect.class.getName());
> // Initialize and create the HbDataStore
> HbDataStore dataStore =
> HbHelper.INSTANCE.createRegisterDataStore("srdV3");
> dataStore.setEPackages(new EPackage[] {SrdPackage.eINSTANCE});
> dataStore.setHibernateProperties(props);
> dataStore.initialize();
> When the last line, dataStore.initialize() is called I get the following
> stack trace...any ideas or help would be appreciated.
> Mark.
> at java.lang.String.compareTo(Unknown Source)
> at
> org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessOneToManyReference(DefaultAnnotator.java:785)
> at
> org.eclipse.emf.teneo.hibernate.hbannotation.util.HibernateD efaultAnnotator.processOneToManyReference(HibernateDefaultAn notator.java:176)
> at
> org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessEFeature(DefaultAnnotator.java:511)
> at
> org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessClass(DefaultAnnotator.java:390)
> at
> org.eclipse.emf.teneo.hibernate.hbannotation.util.HibernateD efaultAnnotator.processClass(HibernateDefaultAnnotator.java: 140)
> at
> org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.pr ocessPackage(DefaultAnnotator.java:235)
> at
> org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator.ma p(DefaultAnnotator.java:155)
> at
> org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:158)
> at
> org.eclipse.emf.teneo.hibernate.HbDataStore.mapEPackages(HbD ataStore.java:374)
> at
> org.eclipse.emf.teneo.hibernate.HbDataStore.mapModel(HbDataS tore.java:363)
> at
> org.eclipse.emf.teneo.hibernate.HbDataStore.initialize(HbDat aStore.java:156)
> at
> srd.view.navigator.ServiceNavigatorPlugin.start(ServiceNavig atorPlugin.java:73)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:991)
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo newbi, problems getting started [message #68531 is a reply to message #68521] |
Mon, 22 January 2007 18:19 |
Mark,
The latest builds should allow you to validate your Ecore model for
problems like this one, i.e., open it in the Ecore editor and invoke
"Validate..." on the root package or programmatically using
Diagnostician.INSTANCE.validate. It sounds like you have an EReference
that either doesn't have a type or has a type that's an EDataType
instead of an EClass (for which you should use an EAttribute not an
EReference).
mark wrote:
> The call to eReference.getEReferenceType() is returning null in
> processOneToManyReference().
> This seems to be the problem.
> Is this something I can change in my model..?
> Mark.
Re: Teneo newbi, problems getting started [message #68563 is a reply to message #68429] |
Mon, 22 January 2007 21:22 |
Mark Geib Messages: 432 Registered: July 2009 |
Martin,
After some more debugging it was not the call to getEReferenceType, but
the call to getEntityName() that returned null...
if (otm.getTargetEntity() == null)
otm.setTargetEntity(getEntityName(eReference.getEReferenceTy pe()));
The call to getEReferenceType() returned an EClass, but the name, and most
other attributes, were null for the EClass object.
I have included the ecore file, the error happends on the
services/ServiceGroups relationship as displayed below in the log...
22-Jan-2007 14:05:02,072 [DEBUG]
org.eclipse.emf.teneo.annotations.mapper.DefaultAnnotator: EReference +
services/ServiceGroup does not have a onetomany annotation, adding one
-----------.ecore file-----------
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="srd"
nsURI="http://srd" nsPrefix="srd">
<eClassifiers xsi:type="ecore:EClass" name="Service">
<eStructuralFeatures xsi:type="ecore:EReference" name="links"
upperBound="-1"
eType="#//Link" containment="true" eOpposite="#//Link/service"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="contacts"
upperBound="-1"
eType="#//Contact" eOpposite="#//Contact/services"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="notes"
upperBound="-1"
eType="#//Note" containment="true" eOpposite="#//Note/service"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="locations"
upperBound="-1"
eType="#//Location" containment="true"
eOpposite="#//Location/service"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="serviceGroup"
lowerBound="1"
eType="#//ServiceGroup" eOpposite="#//ServiceGroup/services"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="organizations"
upperBound="-1"
eType="#//Organization" eOpposite="#//Organization/services"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="longName"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="EPGName"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="adult"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="externalLaunch"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//ELong"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="local"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="title"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="xmitProfile"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="epgSource"
name="requestedVideoQuality"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="nocViewable"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="audioDelay"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="blackedOut"
<eStructuralFeatures xsi:type="ecore:EReference" name="namedEquipment"
upperBound="-1"
eType="#//NamedEquipment" eOpposite="#//NamedEquipment/services"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="routerPorts"
upperBound="-1"
eType="#//RouterPort" containment="true"
eOpposite="#//RouterPort/service"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="allServices"
lowerBound="1"
eType="#//AllServices" eOpposite="#//AllServices/services"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="CheyenneUplink"
eType="#//EnumType"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="GilbertUplink"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Link">
<eStructuralFeatures xsi:type="ecore:EReference" name="service"
lowerBound="1"
eType="#//Service" eOpposite="#//Service/links"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Contact">
name="physicalAddresses" upperBound="-1"
eType="#//PhysicalAddress" containment="true"
eOpposite="#//PhysicalAddress/contact"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="phoneNumbers"
upperBound="-1"
eType="#//PhoneNumber" containment="true"
eOpposite="#//PhoneNumber/contact"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="emailAddresses"
upperBound="-1"
eType="#//EmailAddress" containment="true"
eOpposite="#//EmailAddress/contact"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="authInfo"
upperBound="-1"
eType="#//AuthInfo" containment="true"
eOpposite="#//AuthInfo/contact"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="urlAddresses"
upperBound="-1"
eType="#//UrlAddress" containment="true"
eOpposite="#//UrlAddress/contact"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="ipAddresses"
upperBound="-1"
eType="#//IpAddress" containment="true"
eOpposite="#//IpAddress/contact"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="services"
upperBound="-1"
eType="#//Service" eOpposite="#//Service/contacts"/>
upperBound="-1"
eType="#//NamedEquipment" eOpposite="#//NamedEquipment/contacts"/>
lowerBound="1"
eType="#//Organization" eOpposite="#//Organization/contacts"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Description"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="FirstName"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="LastName"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="MiddleName"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="NickName"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="CallOrder"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Note">
lowerBound="1"
eType="#//Service" eOpposite="#//Service/notes"/>
lowerBound="1"
eType="#//NamedEquipment" eOpposite="#//NamedEquipment/notes"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="routerPort"
lowerBound="1"
eType="#//RouterPort" eOpposite="#//RouterPort/notes"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="text"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="critical"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EBoolean"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="AuthInfo">
<eStructuralFeatures xsi:type="ecore:EReference" name="contact"
lowerBound="1"
eType="#//Contact" eOpposite="#//Contact/authInfo"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="authKey"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EmailAddress">
lowerBound="1"
eType="#//Contact" eOpposite="#//Contact/emailAddresses"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Address"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="IpAddress">
lowerBound="1"
eType="#//Contact" eOpposite="#//Contact/ipAddresses"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="IP"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="PhoneNumber">
lowerBound="1"
eType="#//Contact" eOpposite="#//Contact/phoneNumbers"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="AreaCode"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="CountryCode"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ShortNumber"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="UrlAddress">
lowerBound="1"
eType="#//Contact" eOpposite="#//Contact/urlAddresses"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="PhysicalAddress">
lowerBound="1"
eType="#//Contact" eOpposite="#//Contact/physicalAddresses"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="City"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Country"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="FirstLine"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="SecondLine"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ThirdLine"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="FourthLine"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="State"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="PostalCode"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Organization">
upperBound="-1"
eType="#//Contact" containment="true"
eOpposite="#//Contact/organizations"/>
upperBound="-1"
eType="#//Service" eOpposite="#//Service/organizations"/>
upperBound="-1"
eOpposite="#//NamedEquipment/organizations"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="contactList"
lowerBound="1"
eType="#//ContactList" eOpposite="#//ContactList/organizations"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Sar"
eSuperTypes="#//NamedEquipment"/>
<eClassifiers xsi:type="ecore:EClass" name="Hpa"
eSuperTypes="#//NamedEquipment">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="designation"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="encMod"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="frequencyBand"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="misc"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="polarity"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="hpaType"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="hpaUse"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="UpConverter"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="attenuation"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="frequency"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ucOption"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ptcNumber"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ucType"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DtoAConverter"
<eClassifiers xsi:type="ecore:EClass" name="AtoDConverter"
name="horizontalPhase" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="verticalPhase"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Satellite"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="orbitalSlot"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="bandID"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="SourceSatellite"
eSuperTypes="#//Satellite"/>
<eClassifiers xsi:type="ecore:EClass" name="EchostarSatellite"
<eClassifiers xsi:type="ecore:EClass" name="Cherrypicker"
name="in1PrimarySource" eType="ecore:EDataType
name="in2PrimarySource" eType="ecore:EDataType
name="in3PrimarySource" eType="ecore:EDataType
name="in4PrimarySource" eType="ecore:EDataType
name="in5PrimarySource" eType="ecore:EDataType
name="in6PrimarySource" eType="ecore:EDataType
name="in7PrimarySource" eType="ecore:EDataType
name="in8PrimarySource" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="out1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="out2"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="out3"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="out4"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DishReceiver"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="channel"
name="downlinkFrequency" eType="ecore:EDataType
name="forwardRateCorrection"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lbandFrequency"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="smartCard"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="symbolRate"
name="dishReceiverType" eType="ecore:EDataType
name="unitAuthorizationNumber"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="CommercialInserter"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="cueSource"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="cueType"
name="dtmfStartNumber" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="dtmfStopNumber"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EDouble"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="preRoll"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="serverID"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="tcid"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="vbiDecoder"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="wegenerCardID"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="zone"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="TandB"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="AudioDeEmbedder"
name="group1Pr1GainDB" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="group1Pr1Swap"
name="group1Pr2GainDB" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="group1Pr2Swap"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="group1Swap"
name="group2Pr1GainDB" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="group2Pr1Swap"
name="group2Pr2GainDB" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="group2Pr2Swap"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="group2Swap"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Antenna"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="acu"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="azimuth"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="deIce"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="drive"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="elevation"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="gain"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="sizeM"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="track"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="antennaType"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="antennaUse"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Feed"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lnb1"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lnb2"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lnb3"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lnb4"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="orientation"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="feedType"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Hydra"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="engineNumber"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="head"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="module"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="MonitorWall"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ptc"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="rfDesignation"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="rfDisType"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="EchostarXpndrFreq"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="SourceXpndrFreq"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DividerPort"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="portNumber"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BackhaulGroundStation"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="latitude"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="longitude"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DistributionAmp"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="frameNumber"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="daType"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="RouterPort">
<eStructuralFeatures xsi:type="ecore:EReference" name="router"
lowerBound="1"
eType="#//Router" eOpposite="#//Router/routerPorts"/>
upperBound="-1"
eType="#//Note" containment="true" eOpposite="#//Note/routerPort"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="number"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="parentAlias"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="portType"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="linkedToAlias"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="linkedToId"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="parentId"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="description"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Id"
lowerBound="1"
eType="#//Service" eOpposite="#//Service/routerPorts"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="portLocations"
upperBound="-1"
eType="#//Location" eOpposite="#//Location/routerPort"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="RfPatch"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="band"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="expansion"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="port"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Encoder"
name="audioConfigStat" eType="ecore:EDataType
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Pr1Language"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="satellite"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Pr2Language"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Pr3Language"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Pr4Language"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="AudioEmbedder"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="pr1Gain"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="pr2Gain"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Fiber"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="customer"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="fiber"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="VideoServer"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="role"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Ifl"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="endLocation"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="startLocation"
<eStructuralFeatures xsi:type="ecore:EReference" name="otherIfls"
upperBound="-1"
eType="#//Ifl"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Ici"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="IpSwitch"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="ipAddress"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="IpRouter"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Patch"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="patchRow"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="StandardsConverter"
<eClassifiers xsi:type="ecore:EClass" name="Divider"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="barCode"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="FiberPop"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="circuitID"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DolbyEEncoder"
<eClassifiers xsi:type="ecore:EClass" name="DolbyEDecoder"
<eClassifiers xsi:type="ecore:EClass" name="Ac3Decoder"
<eClassifiers xsi:type="ecore:EClass" name="Ac3Encoder"
<eClassifiers xsi:type="ecore:EClass" name="IpHub"
<eClassifiers xsi:type="ecore:EClass" name="FrameSync"
<eClassifiers xsi:type="ecore:EClass" name="AtmSwitch"
<eClassifiers xsi:type="ecore:EClass" name="LocalRack"
Re: Teneo newbi, problems getting started [message #68849 is a reply to message #68563] |
Mon, 22 January 2007 22:54 |
Mark,
I used the ecore below to generate a hibernate mapping file. This also goes through the
DefaultAnnotator in exactly the same way as in your case and it went fine (btw I tested eclipse 3.2
and emf 2.2). I needed to name the file srd.ecore correct?
Can you debug further to see where getEReferenceType points to?
Here is the (quick and dirty) program I used to test the reading of the ecore file and generating
the mapping. Can you also try:
* @param args
try {
final ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "*", new
EcoreResourceFactoryImpl());
final ArrayList epackages = new ArrayList();
final Resource res = resourceSet.getResource(URI.createFileURI("/home/mtaal/mytmp/srd.ecore "), true);
res.load(new HashMap());
Iterator it = res.getAllContents();
while (it.hasNext()) {
final Object obj = it.next();
if (obj instanceof EPackage) {
EPackage epack = (EPackage) obj;
if (EPackage.Registry.INSTANCE.getEPackage(epack.getNsURI()) == null) {
EPackage.Registry.INSTANCE.put(epack.getNsURI(), epack);
epackages.add(epack);
final EPackage[] epacks = (EPackage[])epackages.toArray(new EPackage[epackages.size()]);
System.err.println(HbHelper.INSTANCE.generateMapping(epacks, new Properties()));
} catch (Exception e) {
throw new RuntimeException(e.getMessage(), e);
Here is the mapping file:
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD 3.0//EN"
"http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<!-- Generated by Teneo on Mon Jan 22 23:50:22 CET 2007 -->
<hibernate-mapping>
<class entity-name="Service" abstract="false" lazy="false" discriminator-value="Service"
table="`service`">
<meta attribute="eclassName">Service</meta>
<meta attribute="epackage">http://srd</meta>
<id type="long" name="e_id" column="e_id"
access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<discriminator column="`dtype`" type="string"/>
<version name="e_version" column="e_version"
access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
<list name="links" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`link_service_id`" not-null="false" unique="false"/>
</key>
<list-index column="`service_links_idx`"/>
<one-to-many entity-name="Link"/>
</list>
<list name="contacts" lazy="true" cascade="merge,persist,save-update,lock,refresh"
table="service_contact">
<key update="true">
<column name="`service_id`" not-null="true" unique="false"/>
</key>
<list-index column="`service_contacts_idx`"/>
<many-to-many entity-name="Contact" unique="false">
<column name="`contact_id`" not-null="true" unique="false"/>
</many-to-many>
</list>
<list name="notes" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`note_service_id`" not-null="false" unique="false"/>
</key>
<list-index column="`service_notes_idx`"/>
<one-to-many entity-name="Note"/>
</list>
<list name="locations" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`location_service_id`" not-null="false" unique="false"/>
</key>
<list-index column="`service_locations_idx`"/>
<one-to-many entity-name="Location"/>
</list>
<many-to-one name="serviceGroup" entity-name="ServiceGroup"
cascade="merge,persist,save-update,lock,refresh" lazy="false" insert="false" update="false"
not-null="false">
<column not-null="false" unique="false" name="`service_servicegroup_id`"/>
</many-to-one>
<list name="organizations" lazy="true" cascade="merge,persist,save-update,lock,refresh"
table="service_organization">
<key update="true">
</key>
<list-index column="`service_organizations_idx`"/>
<many-to-many entity-name="Organization" unique="false">
<column name="`organization_id`" not-null="true" unique="false"/>
</many-to-many>
</list>
<property name="longName" lazy="false" insert="true" update="true" not-null="false" unique="false"
type="java.lang.String">
<column not-null="false" unique="false" name="`longname`"/>
</property>
<property name="EPGName" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`epgname`"/>
</property>
<property name="adult" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`adult`"/>
</property>
<property name="externalLaunch" lazy="false" insert="true" update="true" not-null="false"
unique="false" type="long">
<column not-null="false" unique="false" name="`externallaunch`"/>
</property>
<property name="local" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`local`"/>
</property>
<property name="title" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`title`"/>
</property>
<property name="xmitProfile" lazy="false" insert="true" update="true" not-null="false"
unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`xmitprofile`"/>
</property>
<property name="epgSource" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`epgsource`"/>
</property>
<property name="requestedVideoQuality" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`requestedvideoquality`"/>
</property>
<property name="nocViewable" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`nocviewable`"/>
</property>
<property name="audioDelay" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`audiodelay`"/>
</property>
<property name="blackedOut" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`blackedout`"/>
</property>
<list name="namedEquipment" lazy="true" cascade="merge,persist,save-update,lock,refresh"
table="service_namedequipment">
<key update="true">
</key>
<list-index column="`service_namedequipment_idx`"/>
<many-to-many entity-name="NamedEquipment" unique="false">
<column name="`namedequipment_id`" not-null="true" unique="false"/>
</many-to-many>
</list>
<list name="routerPorts" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`routerport_service_id`" not-null="false" unique="false"/>
</key>
<list-index column="`service_routerports_idx`"/>
<one-to-many entity-name="RouterPort"/>
</list>
<many-to-one name="allServices" entity-name="AllServices"
not-null="false">
<column not-null="false" unique="false" name="`service_allservices_id`"/>
</many-to-one>
<property name="CheyenneUplink" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`cheyenneuplink`"/>
</property>
<property name="GilbertUplink" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`gilbertuplink`"/>
</property>
</class>
<class entity-name="Link" abstract="false" lazy="false" discriminator-value="Link" table="`link`">
<meta attribute="eclassName">Link</meta>
</id>
</version>
<many-to-one name="service" entity-name="Service" cascade="merge,persist,save-update,lock,refresh"
lazy="false" insert="false" update="false" not-null="false">
<column not-null="false" unique="false" name="`link_service_id`"/>
</many-to-one>
</class>
<class entity-name="Contact" abstract="false" lazy="false" discriminator-value="Contact"
table="`contact`">
<meta attribute="eclassName">Contact</meta>
</id>
</version>
<list name="physicalAddresses" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`physicaladdress_contact_id`" not-null="false" unique="false"/>
</key>
<list-index column="`contact_physicaladdresses_idx`"/>
<one-to-many entity-name="PhysicalAddress"/>
</list>
<list name="phoneNumbers" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`phonenumber_contact_id`" not-null="false" unique="false"/>
</key>
<list-index column="`contact_phonenumbers_idx`"/>
<one-to-many entity-name="PhoneNumber"/>
</list>
<list name="emailAddresses" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`emailaddress_contact_id`" not-null="false" unique="false"/>
</key>
<list-index column="`contact_emailaddresses_idx`"/>
<one-to-many entity-name="EmailAddress"/>
</list>
<list name="authInfo" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`authinfo_contact_id`" not-null="false" unique="false"/>
</key>
<list-index column="`contact_authinfo_idx`"/>
<one-to-many entity-name="AuthInfo"/>
</list>
<list name="urlAddresses" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`urladdress_contact_id`" not-null="false" unique="false"/>
</key>
<list-index column="`contact_urladdresses_idx`"/>
<one-to-many entity-name="UrlAddress"/>
</list>
<list name="ipAddresses" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`ipaddress_contact_id`" not-null="false" unique="false"/>
</key>
<list-index column="`contact_ipaddresses_idx`"/>
<one-to-many entity-name="IpAddress"/>
</list>
<list name="services" lazy="true" cascade="merge,persist,save-update,lock,refresh"
table="contact_service">
<key update="true">
</key>
<list-index column="`contact_services_idx`"/>
<many-to-many entity-name="Service" unique="false">
</many-to-many>
</list>
table="contact_namedequipment">
<key update="true">
</key>
<list-index column="`contact_namedequipment_idx`"/>
</many-to-many>
</list>
<many-to-one name="organizations" entity-name="Organization"
not-null="false">
<column not-null="false" unique="false" name="`contact_organizations_id`"/>
</many-to-one>
<property name="Description" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`description`"/>
</property>
<property name="FirstName" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`firstname`"/>
</property>
<property name="LastName" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`lastname`"/>
</property>
<property name="MiddleName" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`middlename`"/>
</property>
<property name="NickName" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`nickname`"/>
</property>
<property name="CallOrder" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`callorder`"/>
</property>
</class>
<class entity-name="Note" abstract="false" lazy="false" discriminator-value="Note" table="`note`">
<meta attribute="eclassName">Note</meta>
</id>
</version>
<column not-null="false" unique="false" name="`note_service_id`"/>
</many-to-one>
<many-to-one name="namedEquipment" entity-name="NamedEquipment"
not-null="false">
<column not-null="false" unique="false" name="`note_namedequipment_id`"/>
</many-to-one>
<many-to-one name="routerPort" entity-name="RouterPort"
not-null="false">
<column not-null="false" unique="false" name="`note_routerport_id`"/>
</many-to-one>
<property name="text" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`text`"/>
</property>
<property name="critical" lazy="false" insert="true" update="true" not-null="false" unique="false"
type="boolean">
<column not-null="false" unique="false" name="`critical`"/>
</property>
</class>
<class entity-name="AuthInfo" abstract="false" lazy="false" discriminator-value="AuthInfo"
table="`authinfo`">
<meta attribute="eclassName">AuthInfo</meta>
</id>
</version>
<many-to-one name="contact" entity-name="Contact" cascade="merge,persist,save-update,lock,refresh"
<column not-null="false" unique="false" name="`authinfo_contact_id`"/>
</many-to-one>
</property>
<property name="authKey" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`authkey`"/>
</property>
</class>
<class entity-name="EmailAddress" abstract="false" lazy="false" discriminator-value="EmailAddress"
table="`emailaddress`">
<meta attribute="eclassName">EmailAddress</meta>
</id>
</version>
<column not-null="false" unique="false" name="`emailaddress_contact_id`"/>
</many-to-one>
<property name="Address" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`address`"/>
</property>
</class>
<class entity-name="IpAddress" abstract="false" lazy="false" discriminator-value="IpAddress"
table="`ipaddress`">
<meta attribute="eclassName">IpAddress</meta>
</id>
</version>
<column not-null="false" unique="false" name="`ipaddress_contact_id`"/>
</many-to-one>
<property name="IP" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`ip`"/>
</property>
</class>
<class entity-name="PhoneNumber" abstract="false" lazy="false" discriminator-value="PhoneNumber"
table="`phonenumber`">
<meta attribute="eclassName">PhoneNumber</meta>
</id>
</version>
<column not-null="false" unique="false" name="`phonenumber_contact_id`"/>
</many-to-one>
<property name="AreaCode" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`areacode`"/>
</property>
<property name="CountryCode" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`countrycode`"/>
</property>
</property>
<property name="ShortNumber" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`shortnumber`"/>
</property>
</class>
<class entity-name="UrlAddress" abstract="false" lazy="false" discriminator-value="UrlAddress"
table="`urladdress`">
<meta attribute="eclassName">UrlAddress</meta>
</id>
</version>
<column not-null="false" unique="false" name="`urladdress_contact_id`"/>
</many-to-one>
</property>
</class>
<class entity-name="PhysicalAddress" abstract="false" lazy="false"
discriminator-value="PhysicalAddress" table="`physicaladdress`">
<meta attribute="eclassName">PhysicalAddress</meta>
</id>
</version>
<column not-null="false" unique="false" name="`physicaladdress_contact_id`"/>
</many-to-one>
<property name="City" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`city`"/>
</property>
<property name="Country" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`country`"/>
</property>
<property name="FirstLine" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`firstline`"/>
</property>
<property name="SecondLine" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`secondline`"/>
</property>
<property name="ThirdLine" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`thirdline`"/>
</property>
<property name="FourthLine" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`fourthline`"/>
</property>
<property name="State" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`state`"/>
</property>
<property name="PostalCode" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`postalcode`"/>
</property>
</class>
<class entity-name="Organization" abstract="false" lazy="false" discriminator-value="Organization"
table="`organization`">
<meta attribute="eclassName">Organization</meta>
</id>
</version>
<list name="contacts" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`contact_organizations_id`" not-null="false" unique="false"/>
</key>
<list-index column="`organization_contacts_idx`"/>
<one-to-many entity-name="Contact"/>
</list>
table="organization_service">
<key update="true">
</key>
<list-index column="`organization_services_idx`"/>
</many-to-many>
</list>
table="organization_namedequipment">
<key update="true">
</key>
<list-index column="`organization_namedequipment_idx`"/>
</many-to-many>
</list>
<many-to-one name="contactList" entity-name="ContactList"
not-null="false">
<column not-null="false" unique="false" name="`organization_contactlist_id`"/>
</many-to-one>
<property name="name" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`name`"/>
</property>
</class>
<class entity-name="NamedEquipment" abstract="false" lazy="false"
discriminator-value="NamedEquipment" table="`namedequipment`">
<meta attribute="eclassName">NamedEquipment</meta>
</id>
</version>
<key update="true">
<column name="`note_namedequipment_id`" not-null="false" unique="false"/>
</key>
<list-index column="`namedequipment_notes_idx`"/>
</list>
table="namedequipment_contact">
<key update="true">
</key>
<list-index column="`namedequipment_contacts_idx`"/>
</many-to-many>
</list>
<many-to-one name="namedEquipmentList" entity-name="NamedEquipmentList"
not-null="false">
<column not-null="false" unique="false" name="`namedequipment_namedequipmentlist_id`"/>
</many-to-one>
table="namedequipment_organization">
<key update="true">
</key>
<list-index column="`namedequipment_organizations_idx`"/>
</many-to-many>
</list>
<property name="building" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`building`"/>
</property>
<property name="description" lazy="false" insert="true" update="true" not-null="false"
</property>
<property name="manufacturer" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`manufacturer`"/>
</property>
<property name="model" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`model`"/>
</property>
<property name="rack" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`rack`"/>
</property>
<property name="room" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`room`"/>
</property>
<property name="serialNumber" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`serialnumber`"/>
</property>
<property name="slot" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`slot`"/>
</property>
<property name="spare" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`spare`"/>
</property>
<property name="status" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`status`"/>
</property>
<property name="subslot" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`subslot`"/>
</property>
<property name="Id" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`id`"/>
</property>
<property name="owner" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`owner`"/>
</property>
table="namedequipment_service">
<key update="true">
</key>
<list-index column="`namedequipment_services_idx`"/>
</many-to-many>
</list>
<property name="assetTag" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`assettag`"/>
</property>
<property name="alias" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`alias`"/>
</property>
<list name="equipmentLocations" lazy="true" cascade="merge,persist,save-update,lock,refresh">
<key update="true">
<column name="`location_namedequipment_id`" not-null="false" unique="false"/>
</key>
<list-index column="`namedequipment_equipmentlocations_idx`"/>
</list>
</class>
<subclass entity-name="Sar" abstract="false" lazy="false" extends="NamedEquipment"
discriminator-value="Sar">
<meta attribute="eclassName">Sar</meta>
</subclass>
<subclass entity-name="Hpa" abstract="false" lazy="false" extends="NamedEquipment"
discriminator-value="Hpa">
<meta attribute="eclassName">Hpa</meta>
<property name="designation" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`designation`"/>
</property>
<property name="encMod" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`encmod`"/>
</property>
<property name="frequencyBand" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`frequencyband`"/>
</property>
<property name="misc" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`misc`"/>
</property>
<property name="polarity" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`polarity`"/>
</property>
<property name="hpaType" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`hpatype`"/>
</property>
<property name="hpaUse" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`hpause`"/>
</property>
</subclass>
<subclass entity-name="UpConverter" abstract="false" lazy="false" extends="NamedEquipment"
discriminator-value="UpConverter">
<meta attribute="eclassName">UpConverter</meta>
<property name="attenuation" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`attenuation`"/>
</property>
<property name="frequency" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`frequency`"/>
</property>
<property name="ucOption" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`ucoption`"/>
</property>
<property name="ptcNumber" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`ptcnumber`"/>
</property>
<property name="ucType" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`uctype`"/>
</property>
</subclass>
<subclass entity-name="DtoAConverter" abstract="false" lazy="false" extends="NamedEquipment"
discriminator-value="DtoAConverter">
<meta attribute="eclassName">DtoAConverter</meta>
</subclass>
<subclass entity-name="AtoDConverter" abstract="false" lazy="false" extends="NamedEquipment"
discriminator-value="AtoDConverter">
<meta attribute="eclassName">AtoDConverter</meta>
</property>
<property name="horizontalPhase" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`horizontalphase`"/>
</property>
<property name="verticalPhase" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`verticalphase`"/>
</property>
</subclass>
<subclass entity-name="Satellite" abstract="false" lazy="false" extends="NamedEquipment"
discriminator-value="Satellite">
<meta attribute="eclassName">Satellite</meta>
<property name="orbitalSlot" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`orbitalslot`"/>
</property>
<property name="bandID" lazy="false" insert="true" update="true" not-null="false" unique="false"
<column not-null="false" unique="false" name="`bandid`"/>
</property>
</property>
</property>
</subclass>
<subclass entity-name="SourceSatellite" abstract="false" lazy="false" extends="Satellite"
discriminator-value="SourceSatellite">
<meta attribute="eclassName">SourceSatellite</meta>
</subclass>
<subclass entity-name="EchostarSatellite" abstract="false" lazy="false" extends="Satellite"
discriminator-value="EchostarSatellite">
<meta attribute="eclassName">EchostarSatellite</meta>
</subclass>
<subclass entity-name="Cherrypicker" abstract="false" lazy="false" extends="NamedEquipment"
discriminator-value="Cherrypicker">
<meta attribute="eclassName">Cherrypicker</meta>
<property name="in1PrimarySource" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`in1primarysource`"/>
</property>
<property name="in2PrimarySource" lazy="false" insert="true" update="true" not-null="false"
<column not-null="false" unique="false" name="`in2primarysource`"/>
</property>
<property name="in3PrimarySource" lazy="false" insert="true" update="true" not-null="false"
Re: Teneo newbi, problems getting started [message #68996 is a reply to message #68849] |
Tue, 23 January 2007 19:15 |
Martin,
Yes, the same code worked for me as well.
I did a little looking at the ecore file and found that the problematic
references and attributes all contained something like...
eType="ecore:EDataType src/srd/impl/srd.ecore#//EnumType"
I made these all look like
eType="#//EnumType"
Now the code is all working.
I get the database tables created, etc.
After the datastore.initialize() I create a ResourceSet and a Resource with
the hibernate URI. That all seems to work.
However, when I call getContents() on the resource I get an error loading
the class javax/transaction/Synchronization...
Where is this class referenced, or better yet, where do I add the
reference to my class path..?
Making great progress I think,
Mark.
Re: Teneo newbi, problems getting started [message #69019 is a reply to message #68996] |
Tue, 23 January 2007 20:45 |
Mark,
This one is in jta.jar. Do you have this jar in your hibernate libraries plugin (and exported the
related packages)?
gr. Martin
mark wrote:
> Martin,
> eType="#//EnumType"
> loading the class javax/transaction/Synchronization...
> Mark.
The Netherlands
Re: Teneo newbi, problems getting started [message #601426 is a reply to message #68416] |
gr. Martin
> Mark.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
Re: Teneo newbi, problems getting started [message #601502 is a reply to message #68521] |
Ed Merks Messages: 33142 Registered: July 2009 |
Mark,
EReference).
> Mark.
Ed Merks
Re: Teneo newbi, problems getting started [message #601517 is a reply to message #68429] |
Martin,
upperBound="-1"
upperBound="-1"
upperBound="-1"
upperBound="-1"
lowerBound="1"
upperBound="-1"
upperBound="-1"
upperBound="-1"
lowerBound="1"
</eClassifiers>
lowerBound="1"
</eClassifiers>
upperBound="-1"
upperBound="-1"
upperBound="-1"
upperBound="-1"
upperBound="-1"
upperBound="-1"
upperBound="-1"
lowerBound="1"
</eClassifiers>
lowerBound="1"
lowerBound="1"
lowerBound="1"
</eClassifiers>
lowerBound="1"
</eClassifiers>
lowerBound="1"
</eClassifiers>
lowerBound="1"
</eClassifiers>
lowerBound="1"
</eClassifiers>
lowerBound="1"
</eClassifiers>
lowerBound="1"
</eClassifiers>
upperBound="-1"
upperBound="-1"
upperBound="-1"
lowerBound="1"
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
lowerBound="1"
upperBound="-1"
lowerBound="1"
upperBound="-1"
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
upperBound="-1"
eType="#//Ifl"/>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
Re: Teneo newbi, problems getting started [message #601564 is a reply to message #68563] |
Mark,
* @param args
try {
<hibernate-mapping>
table="`service`">
</id>
</version>
<key update="true">
</key>
</list>
<key update="true">
</key>
</many-to-many>
</list>
<key update="true">
</key>
</list>
<key update="true">
</key>
</list>
not-null="false">
</many-to-one>
<key update="true">
</key>
</many-to-many>
</list>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
<key update="true">
</key>
</many-to-many>
</list>
<key update="true">
</key>
</list>
not-null="false">
</many-to-one>
</property>
</property>
</class>
</id>
</version>
</many-to-one>
</class>
table="`contact`">
</id>
</version>
<key update="true">
</key>
</list>
<key update="true">
</key>
</list>
<key update="true">
</key>
</list>
<key update="true">
</key>
</list>
<key update="true">
</key>
</list>
<key update="true">
</key>
</list>
<key update="true">
</key>
</many-to-many>
</list>
<key update="true">
</key>
</many-to-many>
</list>
not-null="false">
</many-to-one>
</property>
</property>
</property>
</property>
</property>
</property>
</class>
</id>
</version>
</many-to-one>
not-null="false">
</many-to-one>
not-null="false">
</many-to-one>
</property>
type="boolean">
</property>
</class>
table="`authinfo`">
</id>
</version>
</many-to-one>
</property>
</property>
</class>
</id>
</version>
</many-to-one>
</property>
</class>
</id>
</version>
</many-to-one>
</property>
</class>
</id>
</version>
</many-to-one>
</property>
</property>
</property>
</property>
</class>
</id>
</version>
</many-to-one>
</property>
</class>
</id>
</version>
</many-to-one>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</class>
</id>
</version>
<key update="true">
</key>
</list>
<key update="true">
</key>
</many-to-many>
</list>
<key update="true">
</key>
</many-to-many>
</list>
not-null="false">
</many-to-one>
</property>
</class>
</id>
</version>
<key update="true">
</key>
</list>
<key update="true">
</key>
</many-to-many>
</list>
not-null="false">
</many-to-one>
<key update="true">
</key>
</many-to-many>
</list>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
<key update="true">
</key>
</many-to-many>
</list>
</property>
</property>
<key update="true">
</key>
</list>
</class>
</subclass>
</property>
</property>
</property>
</property>
</property>
</property>
</property>
</subclass>
</property>
</property>
</property>
</property>
</property>
</subclass>
</subclass>
</property>
</property>
</property>
</subclass>
</property>
</property>
</property>
</property>
</subclass>
</subclass>
</subclass>
</property>
</property>
Re: Teneo newbi, problems getting started [message #601610 is a reply to message #68849] |
Martin,
eType="#//EnumType"
Mark.
Re: Teneo newbi, problems getting started [message #601616 is a reply to message #68996] |
Mark,
related packages)?
gr. Martin
mark wrote:
> Martin,
> eType="#//EnumType"
> Mark.
The Netherlands
Current Time: Sun Apr 28 11:29:47 GMT 2024
Powered by FUDForum. Page generated in 0.04921 seconds
