Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo: It is impossible to specify queries order for Hibernate resource
Teneo: It is impossible to specify queries order for Hibernate resource [message #68367] Fri, 19 January 2007 09:15 Go to next message
I load very big model from db.
I have optimized the queries (and their order) for loading model. But
HibernateResource is agnostic to query order cause when it parses URI it
puts queries into HashSet and then cannot restore order of queries.
Can it be solved?
Ilya
Re: Teneo: It is impossible to specify queries order for Hibernate resource [message #68387 is a reply to message #68367] Fri, 19 January 2007 09:29 Go to previous messageGo to next message
Ilya,
Not that I know any of the details, but perhaps if a LinkedHashSet were
used, the order would be more deterministic...
> it puts queries into HashSet and then cannot restore order of queries.
> Can it be solved?
> Thanks
> Ilya
Re: Teneo: It is impossible to specify queries order for Hibernate resource [message #68395 is a reply to message #68387] Fri, 19 January 2007 11:10 Go to previous message
Ilya,
What happens is the following: the parameters in the queryset (of the uri) are put in a hashmap
(keyed on parameter name). The getqueries method then retrieves the query parameters from the
hashmap. I can change this by using a treemap instead of a hashmap. This is a small change and will
make the retrieval order of the queries more deterministic (in order of their parameter name).
Please enter a bugzilla for this as well.
Btw you can override getqueries to implement this yourselve for now.
gr. Martin
Ed Merks wrote:
> Ilya,
>> Can it be solved?
>> Thanks
>> Ilya
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: It is impossible to specify queries order for Hibernate resource [message #601411 is a reply to message #68367] Fri, 19 January 2007 09:29 Go to previous message
Ilya,
> Can it be solved?
> Thanks
> Ilya
Re: Teneo: It is impossible to specify queries order for Hibernate resource [message #601413 is a reply to message #68387] Fri, 19 January 2007 11:10 Go to previous message
Ilya,
gr. Martin
Ed Merks wrote:
> Ilya,
>> Can it be solved?
>> Thanks
>> Ilya
The Netherlands
Previous Topic:Teneo: It is impossible to specify queries order for Hibernate resource
Next Topic:Teneo newbi, problems getting started
Current Time: Tue Nov 04 13:09:27 EST 2025
Powered by FUDForum. Page generated in 0.03973 seconds
