ATL transformation from UML2 to OWL [message #68363] |
Fri, 07 December 2007 09:56  |
Originally posted by: valerio.summo.gmail.com
Hi all,
I'm trying to develop a Java Launcher for an ATL transformation from UML2 to
OWL, but I have some problem in loading the UML2 ecore model.
I have extracted the UML.ecore file from the package
"org.eclipse.uml2.uml_2.1.0.v200706251652.jar" and copied into my project.
My environment is: emf 2.3.0, org.eclipse.core 3.3.0, uml 2.1.0
My code is:
AtlModelHandler emfamh =
AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF);
URL onemmurl = ATLTransformations.class.getResource(
"/metamodels/ecore/UML.ecore");
UMLPackage umlPackage = UMLPackage.eINSTANCE;
ASMModel oneMM_EMF = emfamh.loadModel("UML", emfamh.getMof(),
onemmurl.openStream());
but when I execute it, the last code line causes a long series of identical
WARNING:
Dec 7, 2007 3:15:39 PM org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModel
addReferencedExtentsFor
WARNING: Resource for org.eclipse.emf.ecore.impl.EClassImpl@31a031a0
(eProxyURI:
platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore#//E ModelElement) is
null; cannot be referenced
Thank you in advance!
Valerio
Re: ATL transformation from UML2 to OWL [message #68420 is a reply to message #68363] |
Mon, 10 December 2007 04:02   |
why not loading the uml metamodel by
uml2Mm = emfMh.loadModel("uml", this.emfMh.getMof(),
"uri:http://www.eclipse.org/uml2/2.1.0/UML");
Best regards
Sebastian
Valerio Summo schrieb:
> Hi all,
> My code is:
> WARNING:
> (eProxyURI:
> Valerio
Re: ATL transformation from UML2 to OWL [message #68451 is a reply to message #68420] |
Mon, 10 December 2007 04:36  |
Thank you!
That was my solution!
"bfeater" <sgebhardt1@gmx.de> wrote in message
news:fjivbi$aeg$1@build.eclipse.org...
> Best regards
> Sebastian
>> Hi all,
>> to OWL, but I have some problem in loading the UML2 ecore model.
>> project.
>> My code is:
>> identical WARNING:
>> (eProxyURI:
>> is null; cannot be referenced
>> Valerio
FUDForum. Page generated in 0.05922 seconds
