Home » Archived » BIRT » Deploying BIRT using WebSphere Commerce/WebSphere Application Server?
Deploying BIRT using WebSphere Commerce/WebSphere Application Server? [message #68317] Wed, 17 August 2005 13:33 Go to next message
Originally posted by: alexluc.ca.ibm.com
The example under "Integrating BIRT" uses Apache Jakarta Tomcat as an
example. Does anyone know how to deploy BIRT using WAS?
Re: Deploying BIRT using WebSphere Commerce/WebSphere Application Server? [message #68338 is a reply to message #68317] Wed, 17 August 2005 15:25 Go to previous messageGo to next message
Alex,
You can get birt.war file from Birt-runtime package and deploy it to
websphere 5.1 or higher.
Also setting the configuration:
Classloader Mode: parent_last
War Classloader policy: appliction
Jun Zhai
Re: Deploying BIRT using WebSphere Commerce/WebSphere Application Server? [message #69717 is a reply to message #68338] Thu, 25 August 2005 17:26 Go to previous message
Thank you for your fast reply, Jun Zhai. I've been away for a few days and
haven't checked this forum.
Thanks again for your help.
Previous Topic:required plug-ins for BIRT
Next Topic:Exception in POJO is not catch
Current Time: Mon Sep 01 02:30:08 EDT 2025
Powered by FUDForum. Page generated in 0.07131 seconds
