Problem while serializing xsd schema [message #68306] |
Fri, 09 June 2006 03:13  |
Originally posted by: gjx.sdb.cnic.cn
Hi all
I want to construct a schema and save it
My code like this:
saveFile.addSelectionListener(new SelectionListener()
public void widgetSelected(SelectionEvent e)
FileDialog fd = new FileDialog(getShell(), SWT.SAVE);
String filename = fd.open();
if (filename == null)
return;
URI fileURI = URI.createPlatformResourceURI(filename);
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = resourceSet.createResource(fileURI);
resource.getContents().add(newSchema);
try
resource.save(Collections.EMPTY_MAP);
catch (Exception ex)
ex.printStackTrace();
but when I run the application, I get the following error message:
java.io.IOException: The path '/xxx/xxx.xsd' is unmapped
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createP latformResourceO
utputStream(URIConverterImpl.java:376)
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createO utputStream(URIC
onverterImpl.java:306)
at DropTargetTree$5.widgetSelected(DropTargetTree.java:193)
what's the problem?
Re: Problem while serializing xsd schema [message #68318 is a reply to message #68306] |
Fri, 09 June 2006 07:17  |
Jason,
You asked the same question in the EMF newsgroup. It's best when
posting the same question to multiple newsgroups to post a single
message to all groups at once rather than separate messages. With the
former approach, any reply on any newsgroup will appear in all
newsgroups and so creates less work for those answering the questions by
avoiding duplication...
Jason wrote:
> Hi all
> My code like this:
> return;
> try
> at
> at
> what's the problem?
Re: Problem while serializing xsd schema [message #598181 is a reply to message #68306] |
Jason,
Jason wrote:
> Hi all
> My code like this:
> return;
> try
> at
> at
> what's the problem?
FUDForum. Page generated in 0.03422 seconds
