Home » Eclipse Projects » GEF » Creating child nodes in nested containers
Creating child nodes in nested containers [message #68256] Tue, 04 March 2003 11:38 Go to next message
Originally posted by: m.spork.NOSPAMtpg.com.au
Using the Logic example as a guide - I have been attempting to do a
Circuit like container node where you can create child nodes within
that container node.
The point of difference is that I have a top level container node that
must always contain 2 nested 2nd level container nodes.
So far I have been able to get it working to the point whereby when I
create a model item for the top level container it automatically
creates the two child (2nd level) containers. It will position and
size them so that when the figure factory constructs the figures the
child container figures will be positioned on the top-level container
such that together they cover the entire top-level figure (each child
covers half the top-level container). Hope this makes sense.
The problem I am experiencing is that when I go to drop a node into
the child container - it tries to add it with the top level container
as parent. The top-level container should only ever contain the 2
child containers. The new node needs to be placed into one of the
child containers - depending on which one you actually drop it on.
I have tried both StackLayout and FreeFormLayouts for the containers
without much luck. I found that using StackLayout in the top-level
container meant I couldn't position and size the child containers. So
now I am using FreeFormLayout for both the top level container and the
child containers. This gives me the aforementioned problem - when
attempting to place a new node into one of the child containers the
createCommand gets a Request object with the parent field set to the
top-level container instead of the child container.
Should I be using some other layout class - or doesn't it matter? Is
there something else I'm missing?
Any help would be appreciated.
Thanks very much,
Murray
Re: Creating child nodes in nested containers [message #68268 is a reply to message #68256] Tue, 04 March 2003 11:50 Go to previous messageGo to next message
"Murray Spork" <m.spork@NOSPAMtpg.com.au> wrote in message
news:dhk96vkn2g5itmlnki6l6ll2dvu203ctcf@4ax.com...
Would these 2 2nd level containers happen to be for a UML diagram?
It sounds like your 2 child containers do not get "targeted". They must
have a container editpolicy, such as LayoutEditPolicy, that returns those
containers when getTarget(Request) is called.
The draw2d layout doesn't affect targeting. It is the EditPart's polcies
that determine who gets targeted.
If you are creating a class diagram, you should probably be using the
FlowLayout or ToolbarLAyout in draw2d.
> Thanks very much,
> Murray
Re: Creating child nodes in nested containers [message #68279 is a reply to message #68256] Tue, 04 March 2003 11:51 Go to previous messageGo to next message
On Wed, 05 Mar 2003 02:38:04 +1000, Murray Spork
<m.spork@NOSPAMtpg.com.au> wrote:
Hi again,
Problem solved.
Silly me - shortly after posting I read one of Randy's posts and it
tweaked my memory - I had only added a container role for the
top-level container's edit part - I forgot to do it for the child
containers.
I'm still a little confused about the Layout managers - when to use
the various ones etc. But they had nothing to do with my problem.
Re: Creating child nodes in nested containers [message #68290 is a reply to message #68268] Tue, 04 March 2003 12:00 Go to previous messageGo to next message
On Tue, 4 Mar 2003 11:50:01 -0500, "Randy Hudson" <none@us.ibm.com>
wrote:
Boy - that was quick Randy! I hoped to save you the bother with my 2nd
post but you're way to efficient ;-)
Yes - state chart diagrams - the top level container is a compound
state.
OK - that helps me understand. I didn't know what the mechanism was
here - as I said in my other post all I knew was that I was missing
the container edit policy.
OK - thanks for the tip - I haven't looked at ToolbarLAyout yet - I
will do so now.
Thanks again Randy and sorry for the uneccessary bother.
Murray
Re: Creating child nodes in nested containers [message #68299 is a reply to message #68290] Tue, 04 March 2003 12:05 Go to previous messageGo to next message
Something else you might consider. I don't know about compound state
diagrams, but with a UML class "node", there are two sub-containers. One
for the attributes, and one for methods. It is useful to associate an
EditPart with each container, but it probably is not desirable to allow the
user to interact with the panes. Therefore, the EditParts for the
sub-containers should not be selectable. We added:
boolean EditPart.isSelectable()
just for this purpose. Maybe it applies for you too.
news:rcm96v8o534if71s5udfh7r0tgctkllb0q@4ax.com...
> state.
> will do so now.
> Murray
Re: Creating child nodes in nested containers [message #68307 is a reply to message #68299] Tue, 04 March 2003 21:23 Go to previous messageGo to next message
On Tue, 4 Mar 2003 12:05:59 -0500, "Randy Hudson" <none@us.ibm.com>
Hi Randy,
My container edit part inherits from AbstractEditPart and it appears
that isSelectable() is made final in that class and therefore not
overrideable.
Am I inheriting from the wrong EditPart?
Murray
Re: Creating child nodes in nested containers [message #68326 is a reply to message #68307] Tue, 04 March 2003 22:17 Go to previous message
We were reserving this method for a while. In the more recent builds the
method is not final.
news:1pna6vcsq2kh9fj3q63qeqels73osgb4ct@4ax.com...
the
> Hi Randy,
> overrideable.
> Murray
Previous Topic:getPrintableLayers()
Next Topic:double click seleciton on edit parts
Current Time: Fri Oct 31 11:15:36 EDT 2025
Powered by FUDForum. Page generated in 0.05327 seconds
