Home » Modeling » GMF (Graphical Modeling Framework) » GMF Internationalization
GMF Internationalization [message #68198] Mon, 23 October 2006 16:00 Go to next message
Originally posted by: leonardo.coelho.siliconstrategy.com.br
At this moment, I´m internationalizing my RCP app based on GMF.
And I´m facing the following problem: there are a lot of hardcoded
strings marked by //$NON-NLS-1$
Some of these strings refers to errors and failures. Some of them are
related to interface.
Why is it hardcoded? And what is the best way to surpass this?
Well... I´ve chosen some important files and I´m refactoring them,
moving the references to a resource bundle.
I hope you can give me a better idea.
Leonardo Coelho
Re: GMF Internationalization [message #70252 is a reply to message #68198] Thu, 26 October 2006 10:38 Go to previous message
Leonardo,
Are you referring to strings in generated code or runtime code? Could
you give an example of a string that is causing you a problem?
Cherie
Previous Topic:question on MultiClientContext implementation- includes() true only if ALL children return true?
Next Topic:Re:(Mohammed Mostafa) delete a node including all links start or end at this node
Current Time: Sun Jul 27 08:52:00 EDT 2025
Powered by FUDForum. Page generated in 0.03222 seconds
