Home » Language IDEs » PHP Development Tools (PDT) » Status of XDebug Support for PDT
Status of XDebug Support for PDT [message #6033] Tue, 13 March 2007 19:16 Go to next message
Just thought I would post an update about XDebug support for PDT.
I have been waiting for PDT 0.7 to be released (was due end of feb, now appears to be sometime
in march according to the web page) before I released another version as the PDT apis are changing
and that makes it difficult to keep up with integration builds.
The next version will have
1. Support _SESSION super global (present in newer versions of XDebug)
2. fix the issue with JRE 6.0 and NullPointerException with String variables
3. Add an extension point to allow allow path mappers to be provided without having to modify the
base source code
4. provide a simple path mapper example.
Dave Kelsey
Re: Status of XDebug Support for PDT [message #6048 is a reply to message #6033] Tue, 13 March 2007 08:33 Go to previous messageGo to next message
> variables
> base source code
> Dave Kelsey
Sounds Really Good (and Xdebug is the only debugger that really worked..
on my dev machine ....)
:) Keep the good work
Re: Status of XDebug Support for PDT [message #6108 is a reply to message #6033] Wed, 14 March 2007 13:13 Go to previous messageGo to next message
Originally posted by: johan.bobsworld.be
Hello Dave
Glad to hear this. Your XDebug plugin works better for me then the Zend
Debugger.
Keep up the good work.
A happy user
Johan Vandeweerd
> variables
> base source code
> Dave Kelsey
Re: Status of XDebug Support for PDT [message #6183 is a reply to message #6048] Sat, 17 March 2007 01:17 Go to previous message
>> variables
>> base source code
>> Dave Kelsey
Same here...
Thanks in Advance... http://weconsultants.prophp.org
IchBin, Pocono Lake, Pa, USA http://ichbinquotations.awardspace.com
____________________________________________________________ __________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Previous Topic:Broken download link on webpage
Next Topic:Re: php colored syntax (syntax highlighting options)
Current Time: Tue Jul 22 00:46:51 EDT 2025
Powered by FUDForum. Page generated in 0.08466 seconds
