Re: Download and Install BPMN [message #6029] |
Thu, 12 February 2009 17:35  |
Originally posted by: atoulme.intalio.com
It looks like a SCA Tools related error. Do you have SCA installed ? Are
you running the BPMN editor or the SCA editor ?
Antoine
sanjay wrote:
> I'm trying to run BPMN sample - Restaurent. I get following error when I
> try to run :
> Exception in thread "main" java.lang.Error: Unresolved compilation
> problems: SCADomain cannot be resolved to a type
> How do I fix this? Do I have to configure additional libs? Any pointers
> to get me started on running samples would help.
> Sanjay
Re: Download and Install BPMN [message #6087 is a reply to message #6073] |
Fri, 13 February 2009 04:38  |
Antoine Toulme wrote:
> That should be it. See Jonathan's message, it should help.
Edit: I meant Stephane. Need more caffeine here...
> sanjay wrote:
>> Hi Antoine,
>> I am new to BPMN world and trying to run my first hello world BPMN.
>> I installed eclipse sdk 3.4.1 and configured:
>> http://download.eclipse.org/stp/updates/releases/1.0.1.20080 9261307/site.xml
>> If you could provide me instructions on how to get started with my first
>> hello world that would be great. I have been googling but unable to get
>> much success.
>> Thanks for all of your help.
>> Sanjay
Re: Download and Install BPMN [message #574353 is a reply to message #6029] |
Fri, 13 February 2009 04:14  |
Thanks Antoine. I think also that Sanjay try to run an SCA sample
provided by SCA Tools.
Sanjay, did you installed Tuscany [0]? It looks like Tuscany isn't in
the build path of your project. The tutorial [1] explains how to install
Tuscany.
You can find information on SCA (Service Component Architecture) here
[2] and on the Eclipse project SCA Tools here [3].
Stephane Drapeau
Obeo
[0]: http://tuscany.apache.org/
[1]:
http://wiki.eclipse.org/STP/SCA_Component/SCA_First_Steps_Wi th_Composite_Designer#Prerequisites
[2]: http://www.osoa.org/display/Main/Home
[3]: http://wiki.eclipse.org/STP/SCA_Component
> Antoine
>> try to run :
>> Thanks,
>> Sanjay
Re: Download and Install BPMN [message #574408 is a reply to message #6073] |
> sanjay wrote:
>> Hi Antoine,
>> much success.
>> Sanjay
FUDForum. Page generated in 0.09635 seconds
