Home » Eclipse Projects » SWTBot » JRuby Support
JRuby Support [message #6023] Wed, 03 December 2008 09:27 Go to next message
Hi Ketan,
I'm curious. Have you ever tried SWTBot in JRuby? Are you familiar with
RSpec's new Story Runner (Cucumber)? I'm wondering if SWTBot can be hooked
to it somehow. These are all research projects that I'd like to look into
in the future as they will enable easy functional testing of Glimmer
applications.
Re: JRuby Support [message #6039 is a reply to message #6023] Wed, 03 December 2008 09:38 Go to previous messageGo to next message
Hi Andy,
Since SWTBot is just plain java code, you should just be able to import
the SWTBot class and start using it right away. Just as you would with SWT.
I could probably do a spike around this and post some results.
-- Ketan
On 3/12/08 19:57, Andy Maleh wrote:
> Hi Ketan,
> hooked to it somehow. These are all research projects that I'd like to
> look into in the future as they will enable easy functional testing of
> Glimmer applications.
Re: JRuby Support [message #6099 is a reply to message #6039] Wed, 03 December 2008 12:42 Go to previous messageGo to next message
Great! I may give it a spin myself as well. I'll report about it on my
blog if I do.
Andy
http://andymaleh.blogspot.com
Ketan Padegaonkar wrote:
> Hi Andy,
> -- Ketan
>> Hi Ketan,
Re: JRuby Support [message #8827 is a reply to message #6099] Thu, 11 December 2008 11:19 Go to previous messageGo to next message
Done!!! SWTBot works with Glimmer via JRuby and RSpec.
Check out the initial details over here:
http://andymaleh.blogspot.com/2008/12/glimmers-got-bdd-throu gh-rspec-and.html
Andy
> blog if I do.
> Andy
>> Hi Andy,
>> -- Ketan
>>> Hi Ketan,
Re: JRuby Support [message #8879 is a reply to message #8827] Thu, 11 December 2008 13:50 Go to previous messageGo to next message
Andy,
That's great news.
Perhaps you could blog about how you went about writing the
implementation of the test to wire up with SWTBot etc.
-- Ketan
> Andy
>> blog if I do.
>> Thanks,
>> Andy
>>> Hi Andy,
>>> import the SWTBot class and start using it right away. Just as you
>>> would with SWT.
>>> -- Ketan
>>>> Hi Ketan,
Re: JRuby Support [message #8900 is a reply to message #8879] Thu, 11 December 2008 14:31 Go to previous messageGo to next message
Sure. I am planning to talk about the technical details in my next blog
post. Will keep you posted.
Andy
> Andy,
> That's great news.
> -- Ketan
>> Andy
>>> blog if I do.
>>> Thanks,
>>> Andy
>>>> Hi Andy,
>>>> would with SWT.
>>>> -- Ketan
>>>>> Hi Ketan,
Re: JRuby Support [message #8963 is a reply to message #8900] Fri, 12 December 2008 01:48 Go to previous messageGo to next message
Ok, help! :)
When I attempt to run more than one feature test (story runner test
written with RSpec cucumber,) SWTBot freaks out.
Here is the JRuby code that launches it before each test:
require File.dirname(__FILE__) + "/../../samples/login.rb"
import "net.sf.swtbot.SWTBot"
def startApplicationInAnotherThread(&runnable)
thread = java.lang.Thread.new &runnable
thread.start
end
Before do
startApplicationInAnotherThread do
Login.new.launch
end
@bot = SWTBot.new
end
After do
@bot.active_shell.close
end
I get the following message after the second feature test starts running
(Before and After block executed once, and Before block being executed
again):
java.lang.IllegalStateException: Could not find a display
at net.sf.swtbot.utils.SWTUtils.display(SWTUtils.java:241)
at net.sf.swtbot.finder.ControlFinder.<init>(ControlFinder.java:88)
net.sf.swtbot.finder.ControlFinder.<init>(ControlFinder.java:78)method:
bind and args: #<LoginPresenter:0xddaabc>logged_out
Do you have any idea what it may be? Should I be doing something special
with the Login application related to the Display to prevent this? Am I
not cleaning up correctly by calling @bot.active_shell.close?
(btw, in case you didn't already know, JRuby allows calling Java methods
with Ruby's underscored naming convention instead of camel case, thus
active_shell instead of activeShell)
Andy
> Andy
>> Andy,
>> That's great news.
>> -- Ketan
>>> Andy
>>>> blog if I do.
>>>> Thanks,
>>>> Andy
>>>>> Hi Andy,
>>>>> would with SWT.
>>>>> -- Ketan
>>>>>> Hi Ketan,
Re: JRuby Support [message #8984 is a reply to message #8963] Fri, 12 December 2008 03:40 Go to previous messageGo to next message
> again):
> at
This is a small issue with the SWTUtils.display method, it throws an
exception if it does not find a display.
SWTUtils.display() should ideally wait for a display to appear, but it
does not. I think it's high time I fix this issue.
As a workaround, try doing the rest of the initialization(creating the
SWTBot object) a couple of seconds after the app has started.
The waitForDisplayToAppear() is what you'd be interested in on the page
http://wiki.eclipse.org/SWTBot/UserGuide#Getting_started_wit h_SWTBot_for_SWT_applications
-- Ketan
Re: JRuby Support [message #9004 is a reply to message #8963] Fri, 12 December 2008 03:40 Go to previous messageGo to next message
> again):
> at
-- Ketan
Re: JRuby Support [message #10201 is a reply to message #9004] Mon, 15 December 2008 11:20 Go to previous messageGo to next message
Thanks Ketan,
I tried using the wait-for-display function, and I tried adding a sleep
period between every test run. Here is the modified test setup code:
def start_in_another_thread(&runnable)
thread.start
end
def wait_for_display_to_appear(time_out)
endTime = java.lang.System.current_time_millis() + time_out;
while (java.lang.System.current_time_millis() < endTime)
begin
display = SWTUtils.display();
return if (display != nil)
rescue Exception
end
java.lang.Thread.sleep(100);
end
raise TimeoutException.new("timed out");
end
Before do
start_in_another_thread { Login.new.launch }
wait_for_display_to_appear(5000)
@bot ||= SWTBot.new
end
After do
@bot.display.dispose
end
That helped run all scenario tests successfully. However, every once in a
while I got this exception:
Mon Dec 15 10:15:14 andy-malehs-macbook-pro.local java[3302] <Warning>:
CGSResolveShmemReference : reference offset (47216) exceeds bounds (32768)
on shmem obj 0x1b745
Exception in thread "Thread-3" org/eclipse/swt/SWT.java:3803:in `error':
org.eclipse.swt.SWTError: No more handles (NativeException)
from org/eclipse/swt/SWT.java:3695:in `error'
from org/eclipse/swt/SWT.java:3666:in `error'
from org/eclipse/swt/widgets/Widget.java:681:in `error'
from org/eclipse/swt/widgets/Shell.java:512:in `createHandle'
from org/eclipse/swt/widgets/Widget.java:595:in `createWidget'
from org/eclipse/swt/widgets/Control.java:639:in `createWidget'
from org/eclipse/swt/widgets/Scrollable.java:138:in `createWidget'
from org/eclipse/swt/widgets/Shell.java:574:in `createWidget'
... 88 levels...
from features/step_definitions/../../samples/login.rb:68:in `launch'
from features/step_definitions/common_steps.rb:27:in `__cucumber_38'
Complete Java stackTrace
at org.eclipse.swt.SWT.error(SWT.java:3803)
at org.eclipse.swt.SWT.error(SWT.java:3695)
at org.eclipse.swt.SWT.error(SWT.java:3666)
Have you encountered that exception before? Do you know how to prevent it?
Andy
>> again):
>> at
> at
> -- Ketan
Re: JRuby Support [message #10263 is a reply to message #10201] Mon, 15 December 2008 12:06 Go to previous messageGo to next message
Andy,
I've seen this problem before with swt apps. It basically happens when
SWT is no longer able to allocate OS resources to create widgets and
other things.
The problem persists until I reboot. Perhaps you have leaks in your
sample app and it does not dispose() swt objects correctly.
-- Ketan
On 15/12/08 21:50, Andy Maleh wrote:
> Thanks Ketan,
> thread.start
> end
> begin
> rescue Exception
> end
> java.lang.Thread.sleep(100); end
> end
> Before do
> java.lang.Thread.sleep(100); @bot ||= SWTBot.new
> end
> After do
> end
> a while I got this exception:
> (32768) on shmem obj 0x1b745
> ... 88 levels...
> from :1
> Andy
>>> again):
>>> at
>> page at
>> -- Ketan
Re: JRuby Support [message #12160 is a reply to message #8879] Mon, 05 January 2009 14:30 Go to previous messageGo to next message
Done. Here's a first look at some of the code (I will probably post more
info in the future):
http://andymaleh.blogspot.com/2008/12/first-example-of-glimm er-rspecswtbot.html
> Andy,
> That's great news.
> -- Ketan
>> Andy
>>> blog if I do.
>>> Thanks,
>>> Andy
>>>> Hi Andy,
>>>> would with SWT.
>>>> -- Ketan
>>>>> Hi Ketan,
Re: JRuby Support [message #1410313 is a reply to message #12160] Wed, 20 August 2014 07:48 Go to previous message
I am trying to test GUI based application in SWTBot. I am executing the test cases through testng framework. But i am getting following error.Can any one help me so i can go further implementation.
Thanks in advance
at org.eclipse.swtbot.swt.finder.utils.SWTUtils.display(SWTUtils.java:250)
at org.eclipse.swtbot.swt.finder.finders.ControlFinder.<init>(ControlFinder.java:83)
at org.eclipse.swtbot.swt.finder.finders.ControlFinder.<init>(ControlFinder.java:73)
at org.eclipse.swtbot.swt.finder.SWTBot.<init>(SWTBot.java:115)
at org.eclipse.swtbot.eclipse.finder.SWTWorkbenchBot.<init>(SWTWorkbenchBot.java:61)
at temp.NewTest.beforeClass(NewTest.java:22)
at org.testng.internal.MethodInvocationHelper.invokeMethod(MethodInvocationHelper.java:84)
at org.testng.internal.Invoker.invokeConfigurationMethod(Invoker.java:564)
at org.testng.internal.Invoker.invokeConfigurations(Invoker.java:213)
at org.testng.internal.Invoker.invokeConfigurations(Invoker.java:138)
at org.testng.internal.TestMethodWorker.invokeBeforeClassMethods(TestMethodWorker.java:175)
at org.testng.internal.TestMethodWorker.run(TestMethodWorker.java:107)
at org.testng.TestRunner.privateRun(TestRunner.java:767)
at org.testng.TestRunner.run(TestRunner.java:617)
at org.testng.SuiteRunner.runTest(SuiteRunner.java:334)
at org.testng.SuiteRunner.runSequentially(SuiteRunner.java:329)
at org.testng.SuiteRunner.privateRun(SuiteRunner.java:291)
at org.testng.SuiteRunner.run(SuiteRunner.java:240)
at org.testng.SuiteRunnerWorker.runSuite(SuiteRunnerWorker.java:52)
at org.testng.SuiteRunnerWorker.run(SuiteRunnerWorker.java:86)
at org.testng.TestNG.runSuitesSequentially(TestNG.java:1224)
at org.testng.TestNG.runSuitesLocally(TestNG.java:1149)
at org.testng.TestNG.run(TestNG.java:1057)
at org.testng.remote.RemoteTestNG.run(RemoteTestNG.java:111)
at org.testng.remote.RemoteTestNG.initAndRun(RemoteTestNG.java:204)
at org.testng.remote.RemoteTestNG.main(RemoteTestNG.java:175)
Previous Topic:Force flushing of pending UI events
Next Topic:Execute async() followed by sync()
Current Time: Sat Aug 30 21:29:17 EDT 2025
Powered by FUDForum. Page generated in 0.06708 seconds
