[teneo] How to specify table generators? [message #67767] |
Wed, 10 January 2007 18:26  |
Originally posted by: user.domain.com
Im trying ot convert an old hibernate appl to Teneo and now I go to the
point were I need to convert a Table generator spec to annotation.
However I get an exception saying that no table generator is defined.
843 [main] DEBUG org.eclipse.emf.teneo.hibernate.mapper.IdMapper - No
GenericGenerator defined under name: BRM_SEQ_STORE
31218 [main] DEBUG
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl - No
table generator found with the name: BRM_SEQ_STORE, name is used in
annotation of element BaseTypedIdentifier/id
however earlier in the appl I get the following suggesting that
something is being parsed???
703 [main] DEBUG
org.eclipse.emf.teneo.annotations.parser.EAnnotationParserIm porter -
Number of parsed typename annotations 5
703 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.ComplexNode
- Converting TableGenerator to EObject
- Primitive child: name: BRM_SEQ_STORE
- Primitive child: table: BRM_IF_GENERATOR
703 [main] DEBUG
Found EReference tableGenerator for TableGenerator
- Converting Id to EObject
703 [main] DEBUG
Found EReference id for Id
- Converting Column to EObject
718 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.ComplexNode
- Primitive child: name: IDENTIFIER_ID
- Primitive child: length: 75
718 [main] DEBUG
Found EReference column for Column
- Converting GeneratedValue to EObject
- Primitive child: strategy: TABLE
- Primitive child: generator: BRM_SEQ_STORE
718 [main] DEBUG
Found EReference generatedValue for GeneratedValue
- Converting SequenceGenerator to EObject
- Primitive child: name: SEQ_STORE
718 [main] DEBUG
Found EReference sequenceGenerator for SequenceGenerator
here is my ID property definition. any ideas why below table gen doest work?
<eStructuralFeatures xsi:type="ecore:EAttribute" name="id"
ordered="false" lowerBound="1" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString">
<eAnnotations source="teneo.jpa">
<details key="value"
value=" 	@TableGenerator(name="BRM_SEQ_STORE&qu ot;)
@Id
	@Column(name="IDENTIF IER_ID" ,
length=75)
	@GeneratedValue(strateg y=TABLE,
generator="BRM_SEQ_STORE")
&#x A;	@SequenceGenerator(name="SEQ_STORE&q uot;)
</eAnnotations>
</eStructuralFeatures>
regards
/anders
Re: [teneo] How to specify table generators? [message #67956 is a reply to message #67913] |
Thu, 11 January 2007 09:31  |
Hi Martin,
Thanks , its seem to work when I add TableGeneration annotation to the
package.
Ive added buzilla entry: 170217 for the feature request.
thanks
/anders
Martin Taal wrote:
> Can you try to specify the tablegenerator annotation on epackage level?
> If it works can you then enter a bugzilla that tablegenerator should
> also be supported on efeature level.
> gr. Martin
> user@domain.com wrote:
>> the point were I need to convert a Table generator spec to annotation.
>> No GenericGenerator defined under name: BRM_SEQ_STORE
>> 31218 [main] DEBUG
>> No table generator found with the name: BRM_SEQ_STORE, name is used in
>> 703 [main] DEBUG
>> 703 [main] DEBUG
>> 703 [main] DEBUG
>> 718 [main] DEBUG
>> 718 [main] DEBUG
>> 718 [main] DEBUG
>> work?
>> @Id
>> length=75)
>> </eAnnotations>
>> regards
>> /anders
Re: [teneo] How to specify table generators? [message #601140 is a reply to message #67767] |
Thu, 11 January 2007 08:12  |
If it works can you then enter a bugzilla that tablegenerator should also be supported on efeature
level.
gr. Martin
> 31218 [main] DEBUG
> 703 [main] DEBUG
> 703 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.ComplexNode -
> 703 [main] DEBUG
> 703 [main] DEBUG
> 718 [main] DEBUG org.eclipse.emf.teneo.annotations.parser.ComplexNode -
> 718 [main] DEBUG
> 718 [main] DEBUG
> 718 [main] DEBUG
> work?
> @Id
> length=75)
> </eAnnotations>
> regards
> /anders
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [teneo] How to specify table generators? [message #601159 is a reply to message #67913] |
Hi Martin,
package.
thanks
/anders
Martin Taal wrote:
> gr. Martin
>> 31218 [main] DEBUG
>> 703 [main] DEBUG
>> 703 [main] DEBUG
>> 703 [main] DEBUG
>> 718 [main] DEBUG
>> 718 [main] DEBUG
>> 718 [main] DEBUG
>> work?
>> @Id
>> length=75)
>> </eAnnotations>
>> regards
>> /anders
FUDForum. Page generated in 0.05563 seconds
