Home » Newcomers » Newcomers » Debug: display in tooltip without ctrl+shift+I (3.0.2)
Debug: display in tooltip without ctrl+shift+I (3.0.2) [message #67595] Mon, 23 May 2005 05:00 Go to next message
Originally posted by: mr.smith.vous.etes.dans.la.matrice.com
is it possible to evaluate/display the result of an expression by putting the cursor on it in debug mode without having to type Ctrl+Shit+I?
Or at least, is it possible to assign a shorter shortcut (like F2) to view the display popup?
NB: eclipse 3.0.2 on linux
TIA
Re: Debug: display in tooltip without ctrl+shift+I (3.0.2) [message #68732 is a reply to message #67595] Tue, 24 May 2005 11:06 Go to previous message
If you hover over a variable when debugging, it's value will be
displayed. You can also change the keybinding for Inspect and Display
actions on the "Keys" Preference page (Preferences/General/Keys).
HTH
Kevin
Mr Smith wrote:
> Hello,
> TIA
Previous Topic:Behavior of Java outline view
Next Topic:About bookmark
Current Time: Fri Jul 25 13:21:35 EDT 2025
Powered by FUDForum. Page generated in 0.07644 seconds
