Home » Eclipse Projects » Eclipse Platform » [Debug] Off by one line problem in debugger (2.1)
[Debug] Off by one line problem in debugger (2.1) [message #67582] Mon, 09 June 2003 02:01 Go to next message
Originally posted by: bob.objfac.com
In one particular class, the debugger steps and stops at the line
immediately preceding code line, e.g., on blank lines or comments above
code. It appears to happen only in this one class.
The appearance is what one would expect if debugging a class that does not
correspond to the source, but class is built from source and I have done a
Rebuild All.
Any idea how to stop this from happening?
Bob
Re: [Debug] Off by one line problem in debugger (2.1) [message #67631 is a reply to message #67582] Mon, 09 June 2003 03:09 Go to previous messageGo to next message
Once again I learn, if it looks like a duck, it probably is a duck. Was
debugging another version of the class. I don't know quite how, but a plugin
is grabbing a version out of a Java application project to resolve to!
Moreover, I can't make it stop. Even though there is an explicit dependency
in plugin.xml to the correct (plugin) project and this project is checked in
the build dependency list (and the incorrect project is not), when I debug a
breakpoint in the wrong project gets hit.
To make matters worse, even though there is no visible dependency anywhere
on this application project, I can't close it or PDE won't launch! (I've
reported this bug several times, but it always gets closed "can't
reproduce".)
The only cure is to build a completely new workplace. Grrr.
Bob
"Bob Foster" <bob@objfac.com> wrote in message
news:bc174k$o51$1@rogue.oti.com...
> Rebuild All.
> Bob
Re: [Debug] Off by one line problem in debugger (2.1) [message #68285 is a reply to message #67631] Mon, 09 June 2003 14:43 Go to previous messageGo to next message
Originally posted by: jared-eclipse.mn.rr.com
If you have a reproducible test case for the breakpoint issue, you should
file a bug against JDT Debug.
- Jared
> reproduce".)
Re: [Debug] Off by one line problem in debugger (2.1) [message #70466 is a reply to message #68285] Wed, 11 June 2003 02:47 Go to previous message
"Jared Burns" <jared-eclipse@mn.rr.com> wrote in message
news:bc2kgb$pme$3@rogue.oti.com...
Sorry, got carried away whining. Nah, I can't think how to reproduce this,
short of sending you my projects. I think I'll pass.
Bob
> - Jared
anywhere
> > reproduce".)
Previous Topic:How to include classfiles without the package declaration in the runtime classpath..
Next Topic:How to programatically select an Item in a TreeViewer
Current Time: Sun Jul 13 20:25:48 EDT 2025
Powered by FUDForum. Page generated in 0.05217 seconds
