Home » Archived » Visual Editor (VE) » Using Ve with RCP projects
Using Ve with RCP projects [message #67562] Mon, 18 October 2004 21:46 Go to next message
Originally posted by: deadletter.hotmail.com
Greetings!
I'm a real newbie to eclipse but would like to try using VE inside an RCP
project -- are there any examples or tutorials available?
thx
Re: Using Ve with RCP projects [message #67580 is a reply to message #67562] Mon, 18 October 2004 23:50 Go to previous messageGo to next message
Originally posted by: patmc.not_us.ibm.com
CoinOperated wrote:
> Greetings!
> thx
You need to define what you mean by RCP project.
VE depends on the Eclipse IDE and several other layers of feature/plugin
function (GEF, EMF, then VE).
If you mean VE as an editor in and RCP application (usually defined as
less than all of the eclipse base), then probably not.
If you mean VE as an editor to develop UI's that will be part of the RCP
Application, sure - nothing special about that at all.
If you mean things that look/work like the VE in an RCP application, then
you probably need to look at GEF itself.
Re: Using Ve with RCP projects [message #67745 is a reply to message #67562] Tue, 19 October 2004 12:44 Go to previous messageGo to next message
Originally posted by: mendelgili.netscape.net
CoinOperated wrote:
> Greetings!
> thx
You can use VE to create a customed composite in a UI plugin project. VE does not provide tooling for JFace
components, but you can use the customed panels (generated by VE) in the various createXXXX jFace methods.
Re: Using Ve with RCP projects [message #67766 is a reply to message #67580] Tue, 19 October 2004 17:07 Go to previous messageGo to next message
Thx;
Sorry i wasn't very clear as to my intent!... I'm intrigued by the plug-in
and other foundations offered by Eclipse and RCP as an application framework
(particularly the native look and feel)... So i'm looking to do RCP
applications and just want to use a visual environment to perform UI's
layouts for the app... Wasn't sure what the 'recommend' method was to get
the max use from both RCP & VE..
thx again
"Pat McCarthy" <patmc@not_us.ibm.com> wrote in message
news:cl22uh$um1$1@eclipse.org...
> CoinOperated wrote:
>> Greetings!
>> thx
Re: Using Ve with RCP projects [message #67787 is a reply to message #67745] Tue, 19 October 2004 17:12 Go to previous message
Thx,
I'll give it a shot
"Gili Mendel" <mendelgili@netscape.net> wrote in message
news:cl3fuh$s0g$2@eclipse.org...
> CoinOperated wrote:
>> Greetings!
>> thx
> does not provide tooling for JFace components, but you can use the
Re: Using Ve with RCP projects [message #601919 is a reply to message #67562] Mon, 18 October 2004 23:50 Go to previous message
CoinOperated wrote:
> Greetings!
> thx
Re: Using Ve with RCP projects [message #601996 is a reply to message #67562] Tue, 19 October 2004 12:44 Go to previous message
CoinOperated wrote:
> Greetings!
> thx
Re: Using Ve with RCP projects [message #602007 is a reply to message #67580] Tue, 19 October 2004 17:07 Go to previous message
Thx;
thx again
> CoinOperated wrote:
>> Greetings!
>> thx
Re: Using Ve with RCP projects [message #602015 is a reply to message #67745] Tue, 19 October 2004 17:12 Go to previous message
Thx,
I'll give it a shot
> CoinOperated wrote:
>> Greetings!
>> thx
Previous Topic:Comparing to other GUI tool
Next Topic:Eclipse - VE error
Current Time: Sun Aug 31 18:20:56 EDT 2025
Powered by FUDForum. Page generated in 0.04921 seconds
