Home » Newcomers » Newcomers » how to get library source files Eclipse does not see, e.g. Timer
how to get library source files Eclipse does not see, e.g. Timer [message #67553] Sun, 22 May 2005 21:05 Go to next message
Originally posted by: lyubomir.stanford.edu
when I tried using java.util.Timer or javax.swing.Timer, it showed me
Class File Editor and said "the jar file rt.jar has no source attachment.
You can attach the source by clicking Attach Source below."
Could you please tell me where do I get that source to attach it? or what
else do I do to be able to use timer and other such things that my Eclipse
does not see?
Thanks ahead of time.
Re: how to get library source files Eclipse does not see, e.g. Timer [message #69028 is a reply to message #67553] Wed, 25 May 2005 04:20 Go to previous message
ok, it seems that this problem only happens when running in Debug mode. I
dealt with it by running in Run mode.
There is actually a discussion on the web about some debug-related rt.jar
info not being provided by default, keywords rt.jar, bug, debug
Previous Topic:feature and branding
Next Topic:about hot key
Current Time: Mon Jul 21 21:41:55 EDT 2025
Powered by FUDForum. Page generated in 0.08917 seconds
