RAP Enabling EMF [message #67531] |
Fri, 28 December 2007 12:55 |
I've been working on
https://bugs.eclipse.org/bugs/show_bug.cgi?id=213988. I've RAPified the
org.eclipse.emf.common.ui and org.eclipse.emf.edit.ui plugins to produce
new versions of them. I also generated and RCP application for the
Library.xsd and modified it to RAPify it. But I can't seem to make it
run. If someone could provide a little bit of hand holding that I could
get it as far as being able to run it, then I could continue to test
what's working and what's not (with the goal being to support generating
a RAP application).
Things like lack of support for cell editors will make the editor not
very functional. Are cell editors planned? We've already added data
binding support for EMF 2.4 so we would be able to make use of forms at
some point. Lack of support for drag and drop will make things like
reordering in a tree impossible without some alternative mechanism...
Any help to get started would be greatly appreciated...
FUDForum. Page generated in 0.04120 seconds
