Home » Archived » BIRT » Tree control
Tree control [message #67501] Thu, 11 August 2005 14:53 Go to next message
Originally posted by: frank.backes.centif.de
For representing hierarchical data structures I would need a sort of a
tree control. Somewhere the TOC control has been mentioned, but I cannot
find it in the current BIRT release.
Re: Tree control [message #67523 is a reply to message #67501] Thu, 11 August 2005 16:04 Go to previous messageGo to next message
Hi Frank,
take a look at
http://www.eclipse.org/birt/release20specs/BPS5%20-%20Intera ctive%20Viewer.pdf.
Thats a rough draft, for BIRT 2.0 I believe
Re: Tree control [message #67544 is a reply to message #67523] Thu, 11 August 2005 16:32 Go to previous messageGo to next message
Hi Mike,
many thanks for your reply. The features described in the draft sound
promising. I hope they will be available in an upcoming release.
Best Wishes
Frank
Re: Tree control [message #67608 is a reply to message #67501] Thu, 11 August 2005 18:21 Go to previous messageGo to next message
Frank,
The best source for Release 2.0 candidates is in the Wiki at:
http://eclipse.org/birt/wiki/index.php?n=BPS.BPS
Unfortunately, the TOC did not make the release candidate list. It
looks like what you are requesting is not actually a TOC, but a way to
expand collapse the contents of your report, is that correct? Or are
you talking about a control that would be designed to display tree-leaf
type data?
In either case if you could write up the functionality you are using and
add it to the Wiki, that would be great. You should also check the
BPS-5 Interactive Report Viewer functionality to see if that will give
you what you are looking for.
Scott Rosenbaum
BIRT PMC
> cannot find it in the current BIRT release.
Re: Tree control [message #67844 is a reply to message #67608] Fri, 12 August 2005 16:33 Go to previous messageGo to next message
Hi Scott,
thanks for the information. It created an entry in the Wiki.
Frank
Re: Tree control [message #68189 is a reply to message #67608] Mon, 15 August 2005 17:36 Go to previous messageGo to next message
Hi Scott had a question about the WIKI page you pointed to.
on this page it says
"When entering comments, we would appreciate it if you would put an
"obfuscated version of your e-mail address in the author field, like
"this: user at example dot com
can you explain how this works exactly, was looking at user comment
entries and they don't seem to follow any algorithm related to this.
Thanks.
Scott Rosenbaum wrote:
> Frank,
> type data?
> Scott Rosenbaum
> BIRT PMC
Re: Tree control [message #68200 is a reply to message #68189] Mon, 15 August 2005 19:24 Go to previous message
Mike,
If you scroll down to the bottom of the page, you'll see a form to add
comments. A few folks posted before we requested that people enter
obfuscated e-mail addresses in the author field, but the rest of the posted
comments follow that guideline. There's no automatic function to do the
obfuscation like there is on the PHP web site; you need to do the
translation yourself.
The main page, which is the one that Scott pointed to, is the master list of
potential projects. What we actually like to have happen is for people to
post their detailed comments at the bottom of the page that discusses the
particular project. The comments capability on the main page was intended
primarily as a way to request a major feature that wasn't in the candidate
list.
As you pointed out, BPS5 is the one that talks about report interactivity,
so that one is probably the best place to post comments about the TOC.
Thanks.
Mark
"Mike Boyersmith" <mjboyers@us.ibm.com> wrote in message
news:ddr1th$hb3$1@news.eclipse.org...
> Thanks.
Previous Topic:Relative path for openReportDesign when deployed with Tomcat
Next Topic:How to make dataSet programmatically
Current Time: Tue Oct 28 18:06:50 EDT 2025
Powered by FUDForum. Page generated in 0.05983 seconds
