Home » Eclipse Projects » Mylyn » How can I preselect an WikiText-Format in RepositorySettings?
How can I preselect an WikiText-Format in RepositorySettings? [message #67493] Tue, 31 March 2009 14:29 Go to next message
Originally posted by: sven.krzyzak.gmx.net
For the Redmine Mylyn-Connector, i would like to preselect the
Textile-Format in RepositorySettingsPage. How can I do this?
And is it possible to hide the other WikiText-Formats?
Sven
Re: How can I preselect an WikiText-Format in RepositorySettings? [message #67641 is a reply to message #67493] Wed, 01 April 2009 15:55 Go to previous messageGo to next message
Sven, you'll find the setting under 'Task Editor Settings' in the task
repository properties dialog.
Mylyn will adopt the markup language that best suits your repository
connector by default. What type of repository are you connecting to?
I'm not sure what you mean by that. Can you elaborate?
Re: How can I preselect an WikiText-Format in RepositorySettings? [message #67660 is a reply to message #67641] Wed, 01 April 2009 17:50 Go to previous messageGo to next message
I'm working at Mylyn-Connector for Redmine.
Currently, if someone edited the settings of repository, he have to
select the right markup language under 'Task Editor Settings'.
But not everyone user knows, that Redmine uses the Textile markup language.
So i want, that users only can select between Plain-Text and Textile.
Is this possible - and how?
Sven
Re: How can I preselect an WikiText-Format in RepositorySettings? [message #67764 is a reply to message #67660] Thu, 02 April 2009 13:06 Go to previous messageGo to next message
adding the following to your plugin.xml should associate Textile with
your repository so that your users do not have to alter this setting:
<extension
point="org.eclipse.mylyn.tasks.ui.taskEditorExtensions">
<repositoryAssociation
connectorKind="redmine"
taskEditorExtension=" org.eclipse.mylyn.wikitext.tasks.ui.editor.textileTaskEditor Extension ">
</repositoryAssociation>
</extension>
Note that you may need to alter the connectorKind to correspond to your
connector.
There's no way that I'm aware of to limit these selections. I believe
that there is a way for connector UIs to alter the appearance of the
repository properties dialog, though I'm the wrong guy to answer on
that. A good place to start is the integrator reference:
http://wiki.eclipse.org/index.php/Mylyn/Integrator_Reference
Re: How can I preselect an WikiText-Format in RepositorySettings? [message #67783 is a reply to message #67764] Thu, 02 April 2009 16:48 Go to previous message
I thank you for your answer
Re: How can I preselect an WikiText-Format in RepositorySettings? [message #597275 is a reply to message #67493] Wed, 01 April 2009 15:55 Go to previous message
Re: How can I preselect an WikiText-Format in RepositorySettings? [message #597287 is a reply to message #67641] Wed, 01 April 2009 17:50 Go to previous message
Sven
Re: How can I preselect an WikiText-Format in RepositorySettings? [message #597329 is a reply to message #67660] Thu, 02 April 2009 13:06 Go to previous message
<extension
</extension>
connector.
Re: How can I preselect an WikiText-Format in RepositorySettings? [message #597335 is a reply to message #67764] Thu, 02 April 2009 16:48 Go to previous message
Previous Topic:An idea
Next Topic:Can't install Mylyn 3.2.0.I20090325-0500-e3x
Current Time: Fri Jul 11 22:36:30 EDT 2025
Powered by FUDForum. Page generated in 0.05205 seconds
