Home » Language IDEs » Java Development Tools (JDT) » project layout
project layout [message #67484] Wed, 25 June 2003 15:18 Go to next message
Originally posted by: greg.ferguson.americawest.com
I need some pointers/advice/links on how to get Eclipse to successfully
generate a .jar using one .java file and Oracle's JDBC.
I have Oracle's jdbc.jar (actually called "ojdbc14.jar") in my /lib
directory. The project is pointing to that file and including it in both
the "Libraries" and "Order and Export" tabs.
I've tried moving Oracle's jdbc.jar to the root of the project, but that
made no difference when creating the emax.jar.
( http://www.eclipse.org/newsportal/article.php3?id=361&gr oup=eclipse.tools.jdt)
I still get the following message when I try to run the .jar ...
> java -jar Emax.jar com.awa.awt.emax.Emax
Can't register the JDBC class "oracle.jdbc.driver.OracleDriver"
[oracle.jdbc.driver.OracleDriver]
If I compile and build the .jar in JDeveloper 9.0.3.1, using the same
project layout, source and jdbc.jar, I'll get a substantially larger
output .jar file (2,820,661 bytes vs. 1,181,971 bytes). This jar created
by JDeveloper will run without problems.
The project is laid out on the disk like so: (based on the root of my
project)
/src/com/awa/awt/emax/emax.java
/lib/ojdbc14.jar
My .project is:
<projectDescription>
<name>emax</name>
<comment></comment>
<projects>
</projects>
<buildSpec>
<buildCommand>
<name>org.eclipse.jdt.core.javabuilder</name>
<arguments>
</arguments>
</buildCommand>
</buildSpec>
<natures>
<nature>org.eclipse.jdt.core.javanature</nature>
</natures>
</projectDescription>
My .classpath is:
<classpath>
<classpathentry kind="src" path="src"/>
<classpathentry exported="true" kind="var" path="JRE_LIB"
sourcepath="JRE_SRC"/>
<classpathentry exported="true" kind="lib" path="lib/ojdbc14.jar"/>
<classpathentry kind="output" path="bin"/>
</classpath>
My manifest is:
Manifest-Version: 1.0
Main-Class: com.awa.awt.emax.Emax
My jar description is:
<jardesc>
<jar path="C:/Program Files/eclipse/workspace/emax/Emax.jar"/>
<options overwrite="true" compress="false" exportErrors="false"
exportWarnings="true" saveDescription="true"
descriptionLocation="/emax/emax.jardesc"
useSourceFolders="false" buildIfNeeded="true"/>
<manifest manifestVersion="1.0" usesManifest="true"
reuseManifest="false" saveManifest="true"
generateManifest="true" manifestLocation="/emax/emax.manifest"
mainClassHandleIdentifier="=emax/src&lt;com.awa.awt.emax{Emax.java[Emax ">
<sealing sealJar="false">
<packagesToSeal/>
<packagesToUnSeal/>
</sealing>
</manifest>
<selectedElements exportClassFiles="true" exportJavaFiles="false">
<javaElement handleIdentifier="=emax/src"/>
<folder path="/emax/lib"/>
</selectedElements>
</jardesc>
If anyone can point me to what might be wrong I'd appreciate it. I think
Eclipse rocks.
Greg
Re: project layout [message #70665 is a reply to message #67484] Mon, 30 June 2003 23:36 Go to previous message
Just in case someone's wondering ...
I figured out the problem.
Eclipse needs to have the jdbc .jar imported into /lib, and then the class
folder added to the build path.
It's playing nice now.
Greg Ferguson wrote:
> project)
> /lib/ojdbc14.jar
> My .project is:
> <name>emax</name>
> <comment></comment>
> <projects>
> </projects>
> <buildSpec>
> <buildCommand>
> <arguments>
> </arguments>
> </buildCommand>
> </buildSpec>
> <natures>
> </natures>
> My .classpath is:
> <classpath>
> </classpath>
> My manifest is:
> <jardesc>
> mainClassHandleIdentifier="=emax/src<com.awa.awt.emax{Emax.java[Emax ">
> <packagesToSeal/>
> <packagesToUnSeal/>
> </sealing>
> </manifest>
> </selectedElements>
> </jardesc>
> Eclipse rocks.
> Greg
Previous Topic:jar Export with Packages
Next Topic:plugin import does not create the src structure
Current Time: Sat Jul 12 15:56:28 EDT 2025
Powered by FUDForum. Page generated in 0.02791 seconds
