Eclipse Plugin Update Site [message #67427] |
Tue, 07 July 2009 09:00  |
I am trying to create an update site to store my Lua Editor plug-in
(http://luaeclipse.luaforge.net/preview/update-site) and I am facing a lot
of difficulties.
When I try to use an Update Site project, my platform filters prevent me
from building the features for platforms other than mine.
When I try to use the 'Export' from the multi-platform pack, the resulting
update-site simply isn't recognized by the update manager.
Am I doing something stupid here? Is there any literature or documentation
available on deploying plug-ins?
Help would be greatly appreciated.
[]s
Jason Santos
Re: Eclipse Plugin Update Site [message #67471 is a reply to message #67449] |
Tue, 07 July 2009 11:34  |
Chris Aniszczyk wrote:
> Luis Jason Santos wrote:
> Once you have the delta pack, you should be able to export things
> properly using the feature export wizard.
My packages were created using the export wizard of the delta pack.
Although it has successfully built everything, for some reason the site
itself doesn't get recognized as an update-site. I believe fixing this
might be the shortest way to solve the problem.
> If you want to do things
> headlessly via PDE Build, check out this blog:
What you mean by headlessly?
Thnks a lot!
Jason Santos
Re: Eclipse Plugin Update Site [message #599102 is a reply to message #67449] |
Thnks a lot!
Jason Santos
FUDForum. Page generated in 0.02414 seconds
