Re: Workspace and Project Bird's Nest [message #674005 is a reply to message #673864] |
Wed, 25 May 2011 13:40 |
Eric Rizzo Messages: 3070 Registered: July 2009 |
It sounds like you suffer from a fundamental misunderstanding about what
an Eclipse workspace is and an Eclipse project is.
A workspace is a logical container for, among other things, Projects and
Preferences. A Project is a container for source files and other files
related to them. A workspace has a certain physical location on your
file system; Project's can be located in the file system either
underneath a workspace location (the default behavior) or elsewhere.
Remember, the woskpace is a _logical_ container, not necessarily a
physical container, of Projects.
A) When you import a Project into a workspace, there's an option to copy
the project's contents into the workspace.
B) When creating a new project, you can also locate it at some existing
code base in your filesystem.
It sounds like you either overlooked the option in A) or did B) and
pointed both Projects to the same physical location.
It's really hard to say more without knowing the details of what you did
and where your project(s) is/are located.
Eric
On 5/24/11 9:49 PM, Al wrote:
> I defined a new workspace and tried to import all the objects I had from
> my old workspace to begin working on a new version of the project. I'm
> not sure exactly how I created this mess... Once I create a new
> workspace I add new packages and objects to it thinking that this new
> workspace and project will be in its own location on the hard disk (and
> that all my old objects were imported into the new workspace). What I
> find instead is that the new project is simply a renamed version (for
> the most part) of the old project, all new packages and objects are
> being added to the old project and all the old packages and objects did
> not import into the new project - the new project just has reference to
> them in the old project's directory. This is not what I want. How can I
> piece all this back together and get a project that is updating the hard
> drive directories as you would expect (e.g. MyWorkspace =
> C:\Development\MyWorkspace\src\main\java... instead of MyWorkspace =
> C:\Development\SomeOldWorkspacesClasses\src\...).
> I am using MVN to build and was doing fine despite the anomaly until my
> hard drive crashed. On the restore, MVN will no longer find the classes
> it once was finding (the POM being in the new workspace and the
> directories and objects being in the old workspace was building fine
> before the crash). My server jar just comes up empty now - which I did
> not know until I ran the Flex portion of the app and got "NoClassDef"
> errors in the Flex client. I eventually jar tf -myserver.jar and find
> out that it is empty other than the POM...
> Can someone help me force the right changes in the new project to get it
> all organized under the one workspace? If more info is needed, please
> let me know. Sorry... if it was not obvious, I'm an Eclipse novice.
> In case it matters, my original intent was to segregate versions by
> creating new workspaces for each version. Since my new workspace just
> kept adding to and overwriting my old workspace, that purpose has
> already been defeated and I'd just like to bring everything into line
> now under one project without starting over under a new workspace.
> Thanks for your help!
> Al
FUDForum. Page generated in 0.08273 seconds
