Home » Eclipse Projects » Remote Application Platform (RAP) » Some questions about RAP limitations
Some questions about RAP limitations [message #67306] Tue, 25 December 2007 23:51 Go to next message
I have several questions about RAP limitations:
1. What I can use instead of it?
2. When it will be implemented?
These questions apply to the following limitations:
1. StyledText widget.
2. ITextViewer, ISourceViewer, IDocument and other things which using
for text editors.
3. IPropertySource, IPropertySheet, IPropertyDescriptor.
Boris Stepanov
Re: Some questions about RAP limitations [message #67426 is a reply to message #67306] Fri, 28 December 2007 08:28 Go to previous messageGo to next message
see comments inline
Boris Stepanov wrote:
> Hello,
1: I think there are several powerful replacements but depends on your
usecase. If you don't care about formatting/etc you should go with the
Text widget + SWT.MULTI. Alternatively you could use the browser widget
to render HTML which is at least for formatting really helpful but only
usable for readonly kind of stuff. An alternative would be to write a
custom widget which integrates one of the famous WYSIWYG editors (eg
FCKEditor) which is only an IFrame with some additionaly style flags and
thus the functionality is provided by the browser.
2: I don't think that StyledText will be implemented soon. But I think
this is a great opportunity for the community to help the RAP team and
contribute something back.
> for text editors.
1: -
2: I think the everything around the text editor framework could be
easily ported as soon as there is a StyledText widget as the editor
framework heavily relies on it. Having a custom widget with the same api
as the styled text widget it could *maybe* work together. As I never
really looked into the details don't see this as an absolute answer.
Take a look at the "org.eclipse.rap.ui.views" bundle. This is where the
property view lives. It is already usable in RAP. I would need to take
closer look at it to tell what's already implemented and what is not.
Just take a look!
Hope I could help you!
Benny
Re: Some questions about RAP limitations [message #67552 is a reply to message #67426] Sat, 29 December 2007 05:41 Go to previous message
Benjamin,
Thank you very much for your answer. It will help me.
> see comments inline
>> Hello,
>> for text editors.
> 1: -
> Just take a look!
> Benny
Boris Stepanov
Previous Topic:How to use Activex in rap?
Next Topic:Asserting component enability
Current Time: Sat Jul 26 09:06:47 EDT 2025
Powered by FUDForum. Page generated in 0.03440 seconds
